Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 02-03-2012, 10:07 PM   #1
88HATCH(:
88HATCH(:'s Avatar
Default hit brakes and car dies on b18a1
like the title says , i slow down or hit the brakes and my car dies out .. takes thirty seconds or so before i can start it again . if im not hitting the brakes my car runs like a rapped ape ..
hit the brakes and good bye . replaced all filters , dizzy , plugs and wires withing the past two weeks .
i have a fuel pressure gaugge and reads 40 psi at idle, so im assuming my fuel pump is in working condition.
any ideas ?
88 ef hatch - sold
93 ej2 -whinning d16y7 sold
88 ef hatch - b18a1 (:
88HATCH(: is offline   Reply With Quote
Old 02-03-2012, 10:14 PM   #2
KINGVEM^^ED6
1991 Honda Civic
My Garage
KINGVEM^^ED6's Avatar
iTrader Rating: (1)
Default Re: hit brakes and car dies on b18a1
Main relay?
Originally Posted by tonylovesjdmEF9 View Post
i would choke my ex it was pretty fun and wild
KINGVEM^^ED6 is offline   Reply With Quote
Old 02-03-2012, 11:33 PM   #3
88HATCH(:
88HATCH(:'s Avatar
already replaced my main relay
88 ef hatch - sold
Old 02-04-2012, 08:33 AM   #4
incucivic
possibly a vaccuum leak at the brake booster...
if you are at a stop, with it running, can you make it kill by hitting the brake pedal? if so, then its the brake booster. my 88 was doing it really bad until i swapped in a GSR booster and master cylinder.
it didnt completely fix my problem though. it wont kill if im at a stop and pump the brakes, but it still kills sometimes when my fuel level is low and i come to a stop. i even went so far as to change the fuel pump and tank, because the old tank had tons of rust clogging up the tray around the fuel pump assembly. my guess is that the fuel is still splashing away and its losing fuel pressure for a second. i have no idea how im going to fix this. everything inside the fuel tank is brand new.
incucivic is offline   Reply With Quote
Old 02-04-2012, 02:39 PM   #5
zrickety
1991 Honda CRX
zrickety's Avatar
iTrader Rating: (1)
zrickety zrickety
Send a message via AIM to zrickety
I have a similar problem when shutting either door, the pump kicks off for a second. I don't know if a bad bump will shut it off, but I think it's a loose wire somewhere. I moved the car earlier to wash it, and then it wouldn't start at all. A minute later, it started.
91 Crx Si (B16 SiR)
http://crxcommunity.com/viewtopic.php?f=26&t=32702
zrickety is offline   Reply With Quote
Old 02-04-2012, 04:19 PM   #6
88HATCH(:
88HATCH(:'s Avatar
id check but unfortunatly ive discovered a pin hole leak in my head gasket .
88 ef hatch - sold
Old 02-04-2012, 05:45 PM   #7
most_hated_crx
most_hated_crx's Avatar
I'd do fuel lines, when I replaced mine, they were pretty bad to the say the least lol, unfortunately with cars as old as ours, these are common things we deal with.
10.66@136 mph
17psi 61mm
CG Racing
most_hated_crx is offline   Reply With Quote
2005, 88, b18a1, brake, brakes, breaks, car, crx, dies, element, hit, hitting, honda, si, time
