Hazard button turns on fuel pump
Ok, so i replaced my hadard button/clock, radio, climate control, basically the whole center dash area in my 2001 Accord EX Coupe but now i can push the hazard button and turn the key back and remove it while the car remains on, if the car is already off i can hear it engage the fuel pump and light up the whole dash but the hazards do not blink and i have to manually use my turn signal lever to make my blinkers flash, the only light out is the one in back window and the light and hazard fuses are all good.
Re: Hazard button turns on fuel pump
I have the same problem man but I did a manual swap I have a 98 accord and put a 2002 dash in with all the wiring from a 2002 have u solved it yet
Hey I have this problem for 98 honda accord lx and when I hit the hazard button the blinkers don't work all it does is chime the dash on like I've turned the key into the 2nd stage... what fixes this?
odane403
06-06-2018 08:55 AM
Destin1
02-03-2012 11:41 AM
slowteg550
07-15-2008 03:11 PM
