Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Civic (2006 - Current)
Old 01-31-2012, 08:50 PM   #1
saeco
Default 06 Civic EX Sedan- Left front clunk after power steering pump replacement
Long time lurker, first time poster here. I'll get straight to the point...
SYMPTOMS: Clunk coming from left front (driver side) when hitting bumps on the road, most noticeable at low speeds (i.e. pulling out of a driveway and dipping over curb). Sound occurs only when left front tire is impacted.
HISTORY: Problem occured right after I changed my power steering pump. The only thing significant that was loosened was the right side torque rod, #6 in the following diagram: ENGINE MOUNTS (2.0L) (MT). Fits: Honda | Sons Honda
As soon as the car was lowered I drove off and heard the rucus non-stop
ATTEMPTED REMEDIES AFTER FIRST OCCURENCE: Changed out power steering rack(unrelated reason), changed out front shocks and strut mounts. I've inspected both sides for any blown sway bar endlinks and/any worn out bushings and found no visible problems.
QUESTIONS: What could cause the clunk when all I did was a simple power steering pump replacement? It was RIGHT AFTER I lowered the car. The only possible part I can think it could be was something related to when I loosed the torque rod. Also, what component could have failed when weight is removed from it (i.e. when lifted).
saeco is offline   Reply With Quote
06civic, 2006, acura, blew, civic, clunk, clunking, driver, fit, front, honda, integra, motor, mount, power, pump, replacement, steering
