poor acceleration
Old 01-30-2012, 12:17 PM
efstunnin's Avatar
Default poor acceleration
ok so thisjust started happening
in first gear going it kind of dies and feels like im dragging abot 1000 punds then about 2000 rpms it kicks in fully then by about 3500 its kinda lags again
my cel is on and showing code 43
this is on my dohc zc in my 89 si hatch
if anybody knows anything please help
Old 01-30-2012, 01:21 PM
Keyboard Humorist
4drEF's Avatar
Default Re: poor acceleration
Ignition system component like cap, rotor, wires, and plugs can cause this code - but it's not as likely as the the other parts I list in the next paragraph.
However, since yours is acting strange it almost sounds like it could be ignition components.
Most often the 43 is caused by a faulty O2 sensor or an aftermarket fuel pressure regulator.
If it's neither of them, then check EVERYTHING fuel related.
i would start by doing a fuel pressure check and then make sure the injectors are all good,
Old 01-30-2012, 02:17 PM
efstunnin's Avatar
the dizzy is made a month old
could it still be causing it?
Old 01-30-2012, 02:38 PM
Keyboard Humorist
4drEF's Avatar
Depends... Were you getting the same problem before you changed out distributors?
Old 01-30-2012, 02:54 PM
efstunnin's Avatar
no. everything was running fine with the old one
Old 01-30-2012, 03:03 PM
Keyboard Humorist
4drEF's Avatar
so there you have it.
something went wrong with your distributor change out.
maybe the plug wires aren't in the correct order, check the rotor to make sure it's on tight, maybe a spark plug wire bacame damaged... etc.
Old 01-30-2012, 03:04 PM
efstunnin's Avatar
alright
ill rip it out and check everything
thanks man
ill be back later and check in
Old 01-31-2012, 11:34 AM
efstunnin's Avatar
alright so its still haviing the same problem
mostly on when the car is warmed up all the way
Old 01-31-2012, 11:51 AM
DO IT ON ALL FOURS
OneBadTurboCRV's Avatar
Sooo... What did you do to actually troubleshoot?
Old 01-31-2012, 12:04 PM
efstunnin's Avatar
cracked open the dizzy
checked all the plug wires to make sure they were in and checked the cam sensor wires
everything seemed fine
vedha
09-30-2013 02:10 PM
thirteen_20
12-13-2010 07:45 PM
ludehatchridder
10-27-2010 06:14 AM
92jdmhatch
04-26-2008 05:10 PM
lamsv
11-23-2005 10:13 AM
Quick Reply: poor acceleration
