Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 01-23-2012, 07:48 PM   #1
jake12ryder
Default how do i know what obd my b18b1 is sorry new to this
idk if its obd0, obd1, obd2 please help
jake12ryder is offline   Reply With Quote
Old 01-23-2012, 07:54 PM   #2
88HATCH(:
88HATCH(:'s Avatar
Default Re: how do i know what obd my b18b1 is sorry new to this
looks to be obd0.
88 ef hatch - sold
93 ej2 -whinning d16y7 sold
88 ef hatch - b18a1 (:
88HATCH(: is offline   Reply With Quote
Old 01-23-2012, 07:55 PM   #3
wreckin-rex91
wreckin-rex91's Avatar
It's all in the dizzy! Check your ECU type too ... That makes it easy
91 CRX in progress.....
wreckin-rex91 is offline   Reply With Quote
Old 01-23-2012, 08:17 PM   #4
jake12ryder
alright thanks guys appreciate it
Old 01-23-2012, 08:33 PM   #5
alex14
the valve cover is OBD2, if the motor has a vin number on it, its OBD2.
B18b1 was only made in OBD1 and 2, not 0
the dizzy and ECU can all be changed to work with the motor. You can have a motor from the 96+ (obd2) cars and be running obd1 or obd0
If you are asking if your car is set up to be OBD0,1, or 2, then check the ECU.
alex14 is offline   Reply With Quote
Old 01-25-2012, 07:12 AM   #6
jake12ryder
how can i tell on the ecu... the ecu is a pr4
Old 01-25-2012, 07:20 AM   #7
OneBadTurboCRV
OneBadTurboCRV's Avatar
Just look at the plugs...
'98 CRV EX
'13 Civic Si
OneBadTurboCRV is offline   Reply With Quote
Old 01-25-2012, 07:25 AM   #8
jake12ryder
thanks man i will have to check it out when i get off
Old 01-25-2012, 08:28 AM   #9
codybuRr
1990 Honda Civic
codybuRr's Avatar
you realize b18a and b18b have the same internals, you can convert up and down between obd0 thru obd2.
its all in the wiring and ecu that you use.
codybuRr is offline   Reply With Quote
Old 01-25-2012, 08:33 AM   #10
alex14
Of coarse.
Old 02-14-2014, 04:31 PM   #11
myownworstenemy
i have a b18a1. no sure what obd it uses but i could just use a obd1 harness and and ecu and it'll all work out?
myownworstenemy is offline   Reply With Quote
Old 02-15-2014, 06:43 AM   #12
Spug
1990 Honda CRX
Spug's Avatar
You would need an OBD1 Dizzy and ECU, as well as the ECU jumper harness if you choose to use one.
Paintball's Homepage
Spug is offline   Reply With Quote
b18b1, car, civic, cover, honda, number, obd, obd0, obd1, obd2, valve, vavle, vin, wat, year
