Turbo B20 VTEC BUILD!!
#26
Re: Turbo B20 VTEC BUILD!!
12:! is being done on boosted cars lol but on those sleeves i woudlnt attempt. i beleive that the effect that boosting has on sleeves is safer then building an all motor high cr and running them sleeves.
at this point yes you can port your head, and no you wont see too much of a differance, save your money. a good valve job, maybe performance valve job is good for you. no need to mill your head. do a 10:1 cr, a skunk2 tuner cam or just type R if you want to save money. dont jump on all these band wagons of having to use certain parts. from my experiance and the experiance of others i have talked to and friends with, it way easier than people put into it. if you are worried about your block send it to benson they are good sleeves fro what you need and will be very reliable and wont break your wallet, im saying benson because they are not as pricey as others. GL
#27
#28
Your correct, higher compression all motor engines put more stress on the cylinder walls than lower compression and turbo. Its a more linear rise in pressure and force on the thrust postions of the wall with turbo than with all motor. Yes you can do 12:1 with boost but not on pump gas unless its e85 and on the b20 block i wouldnt trust it
#29
You will be fine with the sleeves. People really underestimate these motors. They might not be as strong as the other honda motors. but they do just fine with a good tune. a lot of the cracked sleeves happened before we had all these cool tuning options, and people were tuning with fmu's
horizongreyEJ1
12-15-2004 05:50 PM
