Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Element & CR-V
Old 01-16-2012, 02:15 PM   #1
sinkoman
Default 2000 CR-V Motor Mounts?
Hey guys, I need some help cross referencing motor mounts for my first gen 5spd AWD CR-V. Mine are BLOWN, and i'd like to replace them with aftermarket mounts, cause I do plan on boosting this motor in the future, i'm just having trouble finding ones that'll fit. I've definitely been searching around here, and have so far only found OEM replacements.
Help greatly appreciated!
sinkoman is offline   Reply With Quote
Old 01-16-2012, 03:24 PM   #2
94EG8
Honda-Tech gave me this lousy title
94EG8's Avatar
Default Re: 2000 CR-V Motor Mounts?
Hint, think '96 - '00 Civic.
Both use basically identical mounts.
"Bacon tendercrisp chicken, the most powerful sandwich in its class."
Per ardua ad astra
My F/S thread -> http://hondamarketplace.com/showthread.php?t=2900962
Originally Posted by Knightsport View Post
Hello,
This is Knightsport, from the internet. I will be out of the internet from June 2 and returning on June 11th. In my absence I suggest you pray as there can be only one Knightsport from the internet.
Thank you and God Bless,
-Knightsport
94EG8 is online now   Reply With Quote
Old 01-16-2012, 04:16 PM   #3
qwrty
qwrty's Avatar
except for the driver side mount... im using avid mounts, i just put in torque mounts when
i found out that theres no aftermarket ones for the driver side...
.....under pressure
" taking/moving the other "side" of the [H]onda game......... "
qwrty is offline   Reply With Quote
Old 01-16-2012, 06:17 PM   #4
94EG8
94EG8's Avatar
The driver's side is the same too. When we did my buddy's B20 swap in a '99 Civic we used the CR-V fluid filled driver's side rubber mount in the civic since it seemed to be a little stronger.
Per ardua ad astra
Hello,
-Knightsport
Old 01-17-2012, 05:47 AM   #5
qwrty
qwrty's Avatar
i had a hard time bolting it up... its too low or off, may be on a civic itll bolt up up i never had
the chance to try it again, thats why i used torque mounts just to support the whole rigidity
of the engine, but everything just bolted right up!
anyway its nice to have that little play coz after the torque mounts, i felt the whole vibration of
the engine, i thought i did it wrong but i remember everything i stiff now!
.....under pressure
Old 01-17-2012, 08:56 AM   #6
94EG8
94EG8's Avatar
Hmm, we also used the CR-V timing belt 2 post mount/bracket as well, which is a different length than the '99 - '00 Si version, I wonder if that's why.
Per ardua ad astra
Hello,
-Knightsport
Old 01-17-2012, 11:41 AM   #7
ihaterust
ihaterust's Avatar
im sure there is a combination of factory brackets that will work. i have also used the b20 bracket into an ek. it might be as simple as a few 1/4" spacers
ihaterust is offline   Reply With Quote
Old 01-17-2012, 12:05 PM   #8
fast2camciv
fast2camciv's Avatar
Send a message via AIM to fast2camciv
the rear mount on 1st gen crv, is the same as eg/ek/dc
the trans mount on 1st gen crv (5spd) is same as ek. (the actual mount itself, the brackets are different...an ek bracket will NOT work on a crv)
the 2 lower tq mounts on 1st gen crv are same as eg/ek/dc
However I personally have NOT found a solution to the drivers side mount. i've put a 99-00 SI mount next to my crv mount and they are different heights. I didnt have access to the actual engine side motor mount bracket, so that might be the solution.....but I highly doubt a 99-00 SI mount bracket would work without lifting the drivers side of the engine up. same difference as putting a CRV mount in a CIVIC...it would drop the motor in a civic. (I should say, "in theory". Sounds like some of you have done it....but from what I saw, I cant see how, but I also didnt have both brackets, from both motors, in front of me)
My mounts are shot, and i've been looking for a solution for a while now....i'm going the DIY route unless something comes up before I get to the point where I NEED to have the mounts stiffened up.
1998 CR-V 5spd, boost soon!
94 Integra GSR 4dr 11.1 @ 130 490whp -sold-
93 Civic 4dr Vitara'd SOHC 11.43 @ 127 405whp -sold-
fast2camciv is offline   Reply With Quote
Old 01-17-2012, 12:46 PM   #9
94EG8
94EG8's Avatar
Here's my buddy's old '99 Civic with B20 swap, all parts of the driver's side mount came from a CR-V. As you can see it sits perfectly level.
Per ardua ad astra
Hello,
-Knightsport
Old 01-17-2012, 01:29 PM   #10
OneBadTurboCRV
OneBadTurboCRV's Avatar
Actually that doesn't look level at all. It is hard to tell from the angle though...
'98 CRV EX
'13 Civic Si
OneBadTurboCRV is offline   Reply With Quote
Old 01-19-2012, 08:24 PM   #11
fast2camciv
yea it is hard to tell from that pic...can you maybe get a pic with the camera sitting on the radiator support maybe? i sure get that feeling from the pic that the drivers side is higher than it should be...
another b20 swap in an ek
Old 01-20-2012, 02:03 AM   #12
94EG8
94EG8's Avatar
It's level, trust me. And no I can't get another pic, car has been sold for a while.
Per ardua ad astra
Hello,
-Knightsport
Old 06-21-2012, 12:06 PM   #13
davojuri
I bought a set of 5 pieces.
Some are aluminium with solid rubber (front ones).
Here is the link:
http://www.onlinewholesaleparts.com/
davojuri is offline   Reply With Quote
Old 01-10-2013, 03:34 PM   #14
HaleStormPhotos
The Crv mount is the same as the civic mount only difference is the crv mount is heavy duty compared to the civic mount. No higher no lower. Part numbers are different do to heavy weld vs light weld. I will supply part numbers if you need them.
HaleStormPhotos is offline   Reply With Quote
Old 01-16-2013, 11:22 AM   #15
stuartmilner
I have had great experience buying low mileage JDM Honda Engines from http://www.usedjapanmotors.com and http://www.allhondaengines.com.
They are nice people, they will definitely help you if you have any questions.
stuartmilner is offline   Reply With Quote
2000, b20, b20a, belt, civic, cr, crv, driving, ek, honda, motor, mount, mounts, replace, swap
