Dual Plenum Intake Manifolds
#26
Re: Dual Plenum Intake Manifolds
Gti-r ITBs are pretty small for a race car that new manifold should show some nice improvement.
Offtopic - bill@dentsport what is the that Roush composite can coming on the PCV system? Fan?
#27
The Roush tank is a catch can mainly for condensation, the alu tank being a air/oil separator.
#30
The main challenge with the computer simulations(CFD - Computational Fluid Dynamics), is the way in which internal combustion enignes work. You'll see a lot of CFD images that demonstrate how evenly the air is flowing through all four runners...The problem is, these tests are treating the intake runners as if they're wide-open and flowing 100% of the time. This is ok if you just need to get a general idea of how well the design is performing, but it's not very accurate when you're trying to hammer down an awesome design that you want to put into production(or even just spend the money/time cutting a one-off on a CNC, etc).
In order to properly test the design, you need to simulate the rest of the engine(intake valves, cam profile, engine RPM, etc) and the airflow through each individual runner throughtout the 720* cycle of the engine...This is where it gets complicated and time consuming. Here's a youtube video demonstrationg what I mean:
Ahh, the joys of engineering. :D
#31
Just seems like a lot of the applications that this is used on is road race application, and from what I've been seeing mostly is that the overall whp increase is minimal on the top end, but mid range gets a pretty nice fat increase. Haven't seen much on big turbo drag cars though.
You'll see these manifolds really shine on forced induction cars that are limited to engine size, turbo size, turbo restrictors, etc. I learned about them due to my interest in rally racing. In the Rally America Open class(The one Ken Block, Higgins, Pastrana, etc run), they're limited to no greater than a 3L engine with a 34mm restrictor in front of the turbo. In order for them to go as fast as possible, they need to get the turbo spooled up quickly and make as much use of that limited amount of air as early as they can. The dual-plenum intake is great here because it improves efficiency/consistency between cylinders(allows for them to tune more aggressively), and improves mid-range torque and power. When it all comes together, you have a small turbocharged 4-cylinder that acts like it's a big, torquey V8.
#33
I see them as kind of unnecessary on 'most' drag cars.(edit: Although, they could be beneficial in classes that limit turbo size, engine combinations, etc)
if it works for rally racing the way you say, it would work for others as a base design if it were allowed by the sanctioning body.
a "drag" manifold would just be a higher flowing version of the same thing tuned for a different powerband.
