got cel p1298 please help
Old 01-12-2012, 12:11 PM
midoriek4hatch's Avatar
Default got cel p1298 please help
ok yesterday my little cousin got a flat tire and after she lowered the car back down the jack slipped and took out the o2 sensor thats after the cat on her 96 civic lx automatic and then got a check engine light. i plugged in my obd2 scanner and it showed p1298, p0501, p0135, p0141. well i changed the broken o2 sensor and cleared the cel. but the p1298 code showed up right away. and after i did some research on here. i went to h auto and changed out the eld sensor under the fuse box. but the code is still there. i'm at a lost right now. should i just change out the whole entire fuse box? h auto had the eld for $35 and the wholse fuse box for $55 the eld was easy to change but i still have the problem. someone please help me
Old 01-12-2012, 12:22 PM
Former User's Avatar
Default Re: got cel p1298 please help
7.5A dash fuse 15 is probably blown.
Old 01-12-2012, 12:41 PM
all the fuses inside the fusebox under the hood are good. didn't check the ones inside the car yet
Old 01-12-2012, 12:44 PM
Old 01-12-2012, 02:00 PM
cool thanks for the help ronj got it fixed
Old 01-12-2012, 02:05 PM
If fuse 15 blows again, then there's a short in the circuit.
Old 01-12-2012, 04:44 PM
ok cool thanks for the heads up. i think when the jack slipped and broke the o2 sensor its cause a short which blew the fuse
Old 01-12-2012, 04:47 PM
yep
Keevin77
10-28-2011 06:18 PM
jrami020
10-18-2009 02:24 PM
suzuki1211
12-30-2008 11:33 AM
Brent S
09-07-2003 09:46 PM
Quick Reply: got cel p1298 please help
