jdm gsr not shifting in smooth and misses shift please help
#26
Re: jdm gsr not shifting in smooth and misses shift please help
Take it back to the guy who rebuilt it for you, and have him look at it again. There are specifications for the clearance of the shift forks, gears, syncros...every little tiny bit and piece has a specification is is supposed to be within. Not shifting into 4th still sounds like the shift fork is out of spec. If you ask him if he checked the specs on the shift forks and he acts like he doesn't know what you're talking about, chances are you should find a new transmission guy. Will it go into 5th?
FUBAR bushings wouldn't stop it from shifting into gear at all - it would just make shifting feel mushy as hell.
#27
here are some more.
i dont know what a slide hub is but i will assume you meant the synchronizer hub.
http://imageshack.us/photo/my-images...ftdiagram.png/
http://imageshack.us/photo/my-images...bservicea.png/
http://imageshack.us/photo/my-images...ngtesting.png/
#28
you could also remove the shift linkage and manually engage the trans into gear using a screw driver. thats what i did before i put my rebuilt trans back into the car. go into each gear and spin the wheels.
#30
#31
its the transmission, ****.....my.....life...........I'm gonna drop it sometime this week, sigh -_- .....
#32
Update I put the new bushing on and still the same, loose shifter and wont into gear 4th and reverse. I drop the transmission but got the service Manuel for a 1997 gsr and give t to my friend to look over. He said he is goin to rip it up on tmr, I'll let you guys know what happens when I get it back and pop it back in.
#34
yeah I'm sure I put it in right lol I pop the tranny back in, It WORKS!! Turns out the trans had three wrong bolts in it and it was loose as ****! That's on the shift selector that hooks up to the shift fork lol My friend caught it can but the right bolts in. I'm lucky as **** the bolt didn't come off when i was driving it before and float around and f*** **** up lol but another thing i found was that I'm missing thrust washer underneath the car on the shift linkage, Imma get those and put em on. so no more loose shifter and goes in all gear smooth lol other the that found out that the wobbling of the car wasn't the axles but the alinement cause when I drop the jdm gsr tranny in its heavy as **** and droped my front end so i just lowered the back end to level the car but that must of threw the alinement off and bad wheel bearings. So still need a idle air control valve, new wheel bearing, camber kit, do my wheel alinement and get my valve clearance adjusted but I got it from here LOL But Thanks alot for your help, learn alot! lol Thanks bro!
#35
Thanks for helping out guys! I wish I could show you guys my project but idk how to post pictures up here....lol but thanks, you guys helped BIG TIME!
#36
Rules, Thread Titles, Car Information, and Picture Posting in this Technical Forum
You'll find how to do it there.
#37
I just read over this thread very briefly, if the sloppyness is not fixed by new bushings then it may be the springs inside the transmission that give the shifter that "resistance" when moving it left and right.
stevenDAtegra
Transmission & Drivetrain
12
05-03-2010 10:57 PM
kihun_cha
12-19-2005 02:34 PM
