| Welcome to Honda-Tech! | ||
#1 |
Hey all,
Sometimes when i try to turn over my honda it makes a buzzing sound from what sounds like under the dashboard below the steering wheel. I turn the key off and sometimes it cranks just fine. I tested the battery and its fine. I'm pretty sure its not the selenoid or the starter though its been a very long time since i've had starter issues from a car and this is my first 4 cylinder. it does not turn over the motor when it makes the buzzing noise. I tried researching it on the web and seem to come to the conclusion that it is my Main Relay? buzzing but when i try to research it deeper i seem to find alot of people blaming the main relay for not delivering fuel to the fuel pump. will the main relay cause it to make a buzzing noise and not turn over? the noise kind of sounds the same as when u try to crank the car if its already running. any suggestions will help. i'll try to record a video of the sound it makes. thank you for reading my post.
#2 |
Yeah, sounds like the main relay went bad. They gets pretty hot while the car is on then cools once it's turned off. This constant hot-cold cycle eventually wears out the solder connections.
Is the check engine light on? Can you get any codes read? Last edited by lazlong; 01-11-2012 at 05:54 PM. |
#3 |
THERES ALSO A RECALL ON THE TUMBLER SYSTEM IN THE IGNITION/GEAR SELECTOR
#4 |
So would i order a main relay? the light does come on every once in a while but goes off. i guess i should find out what the code is.
#5 |
Ill check on that recall too. thanks for bringin that to my attention.
| Tags |
| 2003, battery, buzz, car, element, good, honda, it, restart, smoke, sound, start, turn, turning, wanting |
