Wife's 1st Gen CR-V Build, Work in Progress/DD. Omaha NE.
Old 02-03-2012, 03:14 PM
  #51
superfastb20a's Avatar
Default Re: Wife's 1st Gen CR-V Build, Work in Progress/DD. Omaha NE.
also was it required to use extended lugs with the spacers or would the wheels of fit with stock lugs and different lug nuts?? im trying to figure out what specs i will need to not use spacers because i dont feel like replacing my lugs basically because the previous owner had them all replaced after he snapped some off after moving back from germany less than 2 yrs ago
Old 02-03-2012, 05:05 PM
  #52
single cam fan's Avatar
looks good with that basket!
Old 02-05-2012, 07:05 PM
  #53
4NLINE UNLIMITED's Avatar
Thanks "single cam fan"
Originally Posted by superfastb20a
yes i can see it now thank you. i dont suppose you would be willing to part with the 4 temporary ones he made for you? Also im having my wheels made to order and I really want to have it to where i dont need spacers. i know the wheels rub on a +6mm offset would you have any idea what it would need to be to not rub? I know other people have used 10 mm spacers but im not big into wheel specs so i have no idea what that would equate to for additional off set.
Going to be using 2 of the 1.5" Strut Spacers for the Lift Coils Springs when they get here so i'll need to get 2 more 1.5" made from my Machinist. I want her CR-V to be High of the Ground for more Clearance. "pathfin9" on HondaSUV.com runs 215/75-15 BFG's w/ no Rubbing issues.
http://www.hondasuv.com/members/show...=55111&page=13
Also here's "OSX2000" from HondaSUV.com, gives you more information about Rim/Caliper/Hub Clearance Details.
http://homepage.mac.com/OSX2000/CR-V/
I bet if you go w/ a 4" Backspacing you might get away w/o using 1 or have a Tiny Rim Spacer, Nothing Serious.
4Feb12'
Bought a 99' Honda CR-V EX RT4WD for myself over the weekend. 8 Hour Drive but well worth it, see the No Snow to Snow Pictures Weak Sauce ha
Old 02-06-2012, 05:05 PM
  #54
4Feb12'
Yeah I have read osx2000's write up's and have his page book marked for reference but i could never find if people had used extended lugs or just stock but since it wasnt mentioned by most i figured stock but I can get them from a fastenal for cheap. my wheels should be here any day so i will know soon enough
On the strut spacer situation I was thinking and the idea hit me like a rock in the face my buddy is the foreman for a big hydraulic and they got a beast lathe he is just gonna turn me down 4 blocks of aluminum to the same with and hole measurements as an oem top hot. So essentially your spacer but solid and I will have to installed extended lugs. Since I can make them whatever height I want but havnt decided yet I was thinking .75in front-1.25 back since the ironman already does 1.4in of lift but does not correct the reverse rack of the cr-v but to much could cause a problem with the axles I would imagine.
also congrats on another cr-v!
Old 02-06-2012, 05:16 PM
  #55
FRANKENSTIEN813's Avatar
Pretty Cool CRV's
Old 02-07-2012, 11:33 AM
  #56
Thanks everyone. My Wife entered her CR-V into a Picture Contest, she needs as much Help as she can get =]
If the Like Button doesn't Show up then that means you need to Like Midwest Exclusive's Page 1st and then the Like Button should Appear on her Picture.
Be sure to Share the Picture too
http://www.facebook.com/photo....eater
Old 02-07-2012, 09:41 PM
  #57
Bro...Paint it Black! Would look Sick!
Old 02-08-2012, 10:17 AM
  #58
She likes the Current OEM Red Color right now. She has her CRX to do some Crazy Colors on ha
Thanks for the Help everyone, Keep them Votes coming!!!
8Feb12'
Recent Purchase for her CR-V, still needs to be Pick'd up in San Antonio TX. JDM OEM Honda Bumper Brush Guard+PIAA OEM Fogs.
Old 02-08-2012, 06:11 PM
  #59
turbodcivic510's Avatar
are you running the strust spacers with the oem springs now or have you installed your lift springs? and are you gonna run both lift springs and spacers???
Old 02-12-2012, 08:14 PM
  #60
indeed, just using the OEM Strut/Coil Springs w/ the Custom Strut Spacers Currently. Once i get the Ironman Lift Coils, i'll still Run a Set of Strut Spacers but not as Aggressive has the Set i have on her CR-V now.
Thanks for all your Support Guys, she really needs them Like Votes to Keep the Lead =] Please Keep the Likes and Shares coming
12Feb12'
Wife felt a little Spontaneous today&Driving through the Parking Lot she Rolls up a Snow Bank to Park ha Rear Tire was Slightly off the Ground but not by much at all. Our Son had the Toughest time trying to get out L0L.
Old 02-25-2012, 07:31 PM
  #61
lotz6996's Avatar
looks awesome. getting me motivated to keep my wife's crv. could you give us some of the dimensions for your spacers. mostly just the top or bottom mounting plate and what size pipe was used.
Old 02-27-2012, 05:56 PM
  #62
She Won!!! Thanks everyone for your Support =]
It'll be more Cost Effective to get the Ironman Lift Coil Springs from Camel4x4.com
http://store.camel4x4.com/category/pre-2001.html
Old 03-19-2012, 06:07 AM
  #63
1997vcr's Avatar
I have a 97 crv and lookin for a some lift options. Could you email me the specs of the spacers?
Old 03-19-2012, 06:18 AM
  #64
1997vcr's Avatar
I would also like the specs of those. I'm Gavin troubles looking for lift options for my 1st gen crv
Old 03-19-2012, 07:39 AM
  #65
qwrty's Avatar
what sway bars did they give to you??
is it thicker than the addco/whiteline ones??
Old 03-21-2012, 04:34 AM
  #66
D-RAYMAC's Avatar
The rim and tire combo is a great look. Any MPG loss with those tires? Or so small it isn't noticeable?
Old 03-22-2012, 06:30 PM
  #67
1997vcr's Avatar
Could you email me the specs for those strut spacers so I can make them at my school for my crv? Pretty please?
Old 04-02-2012, 10:01 PM
  #68
ShoebK's Avatar
Any chance you could post the specs for those strut spacers.
Please and Thank You.
Old 04-19-2012, 08:40 PM
  #69
2000crv sport's Avatar
How bout now? Just Upload'd w/ Photobucket.
hey i know some of the guys have already asked for the specs on the strut spacers but no respose but i know i seen your specs somewhere but i cant find them....
so can i please have the specs of the strut spacers?
and is there a reason why you got them machined professionallly ?
id like too weld some up for my self so i can run some bigger tires but im just wondering why you didnt use the ones you made ?
Old 05-02-2012, 08:27 PM
  #70
slowesteg's Avatar
so i guess u never finished the h2b swap?
Old 09-05-2012, 06:49 AM
  #71
gtiw's Avatar
Anything with the H2b?
Old 09-05-2012, 07:27 AM
  #72
H2B Project was Scrap'd, would have to make a Whole New Adapter Plate since the Starter is on the Front of the Transmission w/ the RT CR-V.
Old 10-30-2012, 07:45 AM
  #73
yup still waiting for the strut spacer specs.....
Old 11-05-2012, 11:28 AM
  #74
oh every one who was dissapointed in not getting specs from "4nline unlimited" here they are go nuts http://www.hondasuv.com/members/show...9&postcount=12
Old 11-26-2012, 08:13 PM
  #75
^^^^ anyone want to make me some??? Lol I has cash
Quick Reply: Wife's 1st Gen CR-V Build, Work in Progress/DD. Omaha NE.
