Wife's 1st Gen CR-V Build, Work in Progress/DD. Omaha NE.
#27
1 Post
Re: Wife's 1st Gen CR-V Build, Work in Progress/DD. Omaha NE.
18Jan12'
Lift is Basically all Done, only thing left Buddy Logan is having a Problem w/ is the Passenger Side Front Axle C Clip is be'n a Pain in the Butt. Guess the 98' CR-V had 2 Different Axles to Choose from, Earlier Year Model 97'-98' was a Slightly Longer Axle while the Late Year 98' was Shorter. I'll have to do some more Research, might just Order a New Axle tomorrow just to get it Done&on the Road. Drove it around&it really didn't seem to be as much of a Dog as i thought it was go'n to be. Rubbing if not any wasn't Bad either, need to Trim a Few areas other then that it was Perfect. Also Order'd a OEM Honda Optional Skid Plate, should be here Monday or Tuesday. Well enough Chat'n it up, onto the Pictures =]
#30
1 Post
Thanks Guys!!! Son's Birthday Today so i didn't get some Day time Shots but here is one during Dinner time.
20Jan12'
It's driving Great so Far, lots of New Suspension Noise&Road Tire but it was Excepted.
Definitely needs some Lighter Rims or more Power be still gets its own on the Highway at least.
20Jan12'
#31
it really looks badass!!!
its a head turner/shocker when they see that your wifey is driving this...
up for your build!
up for your build!
#32
1 Post
Thank you, yes she has already told me a few Guys have been Staring her down look'n Confused ha
22Jan12'
Finally got some Free time to take some Better Pictures on my Mothers Land.
22Jan12'
Last edited by 4NLINE UNLIMITED; 01-23-2012 at 02:58 PM. Reason: Broken Picture Link
#36
1 Post
Here's a couple Pictures of the CR-V, Sorry about the Smallness.
#37
1 Post
Just a Small Update since i haven't in a while.
30Jan12'
Install'd Wifey's Spare Tire while she was work'n Today =] Order'd a Curt Cargo Roof Basket along w/ HD Cargo Net. Lots more Room inside the Back now.
Should be here sometime this week then i'll transfer the Spare Tire to the Roof&take off the Factory Spare Tire Holder.
30Jan12'
#38
Id say leave the tire where it is. The added wind resistance of it being on the roof will negatively effect wind noise and fuel economy. To each their own though.
#40
1 Post
Thanks Mike.
The Basket i bought for her CR-V has a Wind Deflector which will some what Help w/ Resistance.
As Far as Excessive Noice, these Tires are already Loud Road wise so there really isn't a Problem.
I have some Special Plans for the Factory Spare Tire Mount area will i'll hopefully get Done End of Feb.
Example Pictures from "pathfin9" on HondaSUV.com
#41
lifted CRV's look great....too bad they dont have a good 4wd system...Wait a second...ive got a spare CRV body...and a 4x4 dodge raider frame with a shot body....
#42
1 Post
1Feb12'
Her Curt Cargo Roof Basket+HD Cargo Net came in Today.
Put it all together already then install tomorrow+Spare Tire in Basket.
Pictures below.
#43
Hi i have an ironman lift kit on order and i see you are wanting to do a 1.5in coil spacer. the oem struts only have about 2in of sag on them so the ironman lift is already 1.4in in front and rear so dont you think the struts will max out resultings in a very uncomfortable ride with an additional 1.5in. I was personally thinking of ordering a 1in spacer and grinding the bottom down to make it .5 giving me 1.4 in front and 1.9 in the rear. Also if you had ordered the correct back spacing are spacers really nessecary? because if not it would save me the effort of adding extended lugs if i just get like a higher back spacing around a 7 probably. Also my crv looks identical to that one except mine has a fully built ls-v in it on 14 lbs =P
#44
1 Post
If you order the Correct Backspacing the Aggressive Spacers are not Necessary. I just need'd them to Clear the Front Calipers.
2Feb12'
Removed the Factory Spare Tire Mount+Test Fit the Spare in her Roof Basket yesterday&install'd the Cargo Basket+Spare Tire today. Definitely need to get my Plan in Motion about the Rear ASAP, kinda looks Plain now imo.
#45
Ah I had misread upon back reading I noticed you said its a lift springs +1.5 strut spacers combo. My springs should be here any day and I didnt see that combo or are you buying the spacers from jcwhitney or another 4x4 website?
#47
1 Post
Made a Rough Template then had my Machinist make a Precision Product (No he doesn't want to Manufacture them)
Side by Side Picture Below, Template vs Precision Product.
Yes her CR-V came w/ the Sport Trim when we bought it. The Sides have been Discontinued but you can still order the Rear.
http://www.handa-accessories.com/crvext01.html
3Feb12'
Whad up Rain
#48
[QUOTE=4NLINE UNLIMITED;46796151]No Company makes these Strut Spacers, they are Custom Pieces.
i cant see this photo in the post i dunno why but could you message me the specs for the spacer? as far as the thickness, inner diamiter, outter diamiter, and spacing of the holes? I will probably have them made out of a very hard plastic/poly
#50
yes i can see it now thank you. i dont suppose you would be willing to part with the 4 temporary ones he made for you? Also im having my wheels made to order and I really want to have it to where i dont need spacers. i know the wheels rub on a +6mm offset would you have any idea what it would need to be to not rub? I know other people have used 10 mm spacers but im not big into wheel specs so i have no idea what that would equate to for additional off set.
