F22a6 head - Enlarging CC bore to match f23a1 block
Old 01-04-2012, 03:24 PM
gjlude's Avatar
Default F22a6 head - Enlarging CC bore to match f23a1 block
So...the reason I have put this topic in the hybrid section is that the motor will use the f23a1 block with the f22a6 head.
I've done some research trying to find more information about enlarging the combustion chamber to match the bore of the f23a1 block of 86mm. I'm not a machinist so excuse me if I have the terminology wrong.
I've read that the "sharp" edge overlap can potentially cause detonation because it will become a hot spot. I couldn't find any technical papers on this, just forums. Has anyone had any experience with this phenomenon?
If this is not a factor, would it still be advantageous for me to enlarge the combustion chamber to match the block bore? I don't mind the extra work on the head, I just don't want to pay for something that is not critical in the motor's longevity.
Also, if it is critical that I match the bore, is that a task that any reputable machine shop could do? Or is it more of a specialty type work?
Thanks for any help.
Old 01-04-2012, 08:01 PM
gjlude's Avatar
Default Re: F22a6 head - Enlarging CC bore to match f23a1 block
This is the thread I am "more or less" referencing...
http://cb7tuner.com/vbb/showthread.php?t=170763
Found one more link from h-tech. I've read a lot from this guy that is responding, he seems quite knowledgeable.
http://ht-archive.org/showthread.php?p=44445182
Anybody else have any hands-on experience? I feel like I've almost answered my own question. Haha.
Old 01-05-2012, 07:11 AM
gjlude's Avatar
Found yet another discussion on this, and after reading it, it seems that it is just a "yes vs. no" argument that no one can come to the same conclusion.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/mismatched-head-bore-cylinder-suggestions-2358965/
I guess another question would be, does Honda match precisely the combustion chamber volume bore to the block bore?
Still looking for some feedback...
Old 01-05-2012, 01:12 PM
hondasdohc's Avatar
Maybe not this guy on here did that head swap to his f23 and he didn't mention the enlarging of the combustion chamber bore.
Old 01-05-2012, 02:22 PM
gjlude's Avatar
Yeah, I talked to my local shop here and I was told that it wasn't necessary, but it would be a good idea to.
Old 01-05-2012, 02:39 PM
hondasdohc's Avatar
I don't even think they do it either my boy did an lsv b16 head b18 block no problems so far. My setup has a 85mm f22a1 block and a 85mm f20b head and i was lucky to have this head it has the same bore instead of putting a h22 87mm head on it.
Old 01-29-2012, 09:16 PM
jonina's Avatar
don''t want to get off topic but i have a question for you, why are people swapping f22 heads on thier f23 blocks? i am doing some research because i a planning on a f23 swap into my ek and i noticed that a few people swapped their f23 heads out for f22a6 heads
Old 01-29-2012, 10:41 PM
wolve's Avatar
f23 head flow sucks
f22a head flow out of the box is quite impressive, but porting potential is enormous!!!
swapping f23 for f22aX head is like swapping a LS with a vtec head flow wise!
Old 01-30-2012, 07:02 AM
jonina's Avatar
ooh, ok thank you
Old 02-03-2012, 09:38 PM
gjlude's Avatar
Originally Posted by PirateMcFred
Be leery of people offering you advice with incomplete picture. Pre-ignition and detonation doesn't really matter when you've not said what octane rating fuel, spark plug/heat range, compression ratio or ingnition timing you intend to use, or even if you intend to keep it naturally aspirated. Just that you want to put a F22A6 head on an F23A1 block.
If you do nothing else you're looking at 9.5:1 CR and that's very very low for any NA engine running EFI anymore. You don't need to worry about hotspots or detonation commuting around with a water-cooled aluminum head and block, conservative compression, conservative ignition timing, conservative rpms, low loads etc. Tuning IS important but there are so many other things that you should be more concerned about than a .5mm stepover around the periphery of your chambers, like bearing clearances, piston to wall and ring gaps and oil pressure for instance.
Just my 2¢.
-P
Thank you for the information and insight.
You are correct, I have not specified my intentions for the build. It will be NA, and I am using k20z3 pistons. They have the same 4.25cc dome as the k20a2 type-s. This should give me a CR of around 12.3:1. I'm 500ft. above sea level, and I have access to 93 octane but will tune on 91 since only one gas station offers 93. As for spark plug/heat range and ignition timing...you got me there. I have not thought that far through. I'll do more research on those.
To be honest, I'm new at building engines, but I am being adventurous on this build. I'll take it slow - learning as much as I can. I also have access to a nice set of Starrett micrometers and dial bore gauge, but I realize that won't do me any good if I don't know what I'm doing.
I'm sure I will have several more questions as I go along. I've read through your engine build threads (except the k24 hybrid) and they have answered several of my questions. So, thank you for your knowledge.
Old 02-04-2012, 03:15 PM
ApexiChild's Avatar
IMHO i'd perfer to have a smaller camber size vs. matched to piston size.
i would think the smaller the camber the better the fuel burn and more power.
just because the compressed air on the upstroke is crammed in smaller volume camber up top, fuel is injected, and power is unleashed downward.
a larger chamber would just mean fuel has to mix with air in a larger area of quence space.
maybe i'm just simplifiying it too much but imho you shouldn't waste money trying to open up the camber and spend money on nice injectors like ID/fic/bosh/ect..
Old 03-07-2012, 12:49 PM
ivan93egreppin210's Avatar
good stuff. this never even crossed my mind when i decided to put the a6 head on my f23. good to know.
Old 10-08-2012, 02:54 PM
KPDSM's Avatar
Hey guys
I've been online the past 3.5 hours looking - I know the rules to the forum(s) and have been searching for a pretty basic answer - I'm sure someone here knows...
Will the f22 head bolt directly to the f23 block with no modification? If there is a modification, what is it?
I'm working on a 5g accord - obd1, crome pro, (havent decided on p72 or p28 yet) - once I get this figured out I can either grab another f23 head or f22 head with ARP fasteners
thanks
Old 09-11-2015, 10:24 AM
unuselectus's Avatar
We need to bring this thing back from the dead!
I have been following all things F-series for a while, but when ivan93egreppin210 built his motor, I was sold!
I hadn't even considered matching the block with the head... There really isn't any decisive answers on this build, unlike the unlimited LSV and K20/K24 threads.
If anyone has anymore thorough assembly and machining guidelines for this setup, PLEASE let me know. I'm about to purchase my parts, and I want to get this right the first time. ;-)
Old 09-13-2015, 07:55 PM
No F-Series build love...?
Old 11-26-2015, 06:37 PM
I never enlarged the combination chamber on my head. Never had any problems either.
Old 11-26-2015, 06:42 PM
And for the guy asking why we swap heads, this is mine with very little porting.
Old 11-30-2015, 06:19 AM
hondamark35's Avatar
I matched mine just for peace of mind. it was very easy... if you're handy with a Dremel and have a steady hand.
I used the ball-shaped carbide burr and then cartridge roll to clean up.
marked out the material to be removed with paint pen using the original F23A1 head gasket positioned with the dowel pins. once the paint was gone, i just blended the cut into the chamber removing as little as possible.
I left the old gasket in place while cutting to protect the machined surface of the head from damage. also taped off the valves (removed rocker assembly so they would all be closed) to make clean up easier.
grimey civic
08-07-2008 09:15 PM
BLK JDM
12-10-2007 08:45 AM
ITRnorway
11-16-2006 01:54 PM
Bnjmn
05-12-2003 09:45 AM
Quick Reply: F22a6 head - Enlarging CC bore to match f23a1 block
