91 Accord F22A1 Ignition Timing
Old 12-31-2011, 10:45 AM
gacinaz's Avatar
Default 91 Accord F22A1 Ignition Timing
I am trying to set the Ignition timing on a 91 F22A1. Looks simple enough except when I open the plug the pointer is there but there are not any timing marks on the flywheel. On the front of the engine, pulley end, there is not a pointer or any grooves cut in the pulleys.
What am I missing?
Old 12-31-2011, 11:09 AM
holmesnmanny's Avatar
Default Re: 91 Accord F22A1 Ignition Timing
It's on the flywheel. Sometimes if the flywheel is rusted the marks are harder to see. You can turn the wheels all the way to the left and get a wrench on the crank pulley bolt and with the tranmission in neutral you can have someone turn the bolt COUNTERCLOCKWISE until you can see the marks. Then use a black sharpie to make marks on the flywheel so you can see them better with the timing light on it.
Old 12-31-2011, 01:02 PM
gacinaz's Avatar
Am I correct that when cylinder number 1 is at the top of it's stroke I am either at TDC or 180 degree off TDC?
Old 12-31-2011, 02:02 PM
gacinaz's Avatar
Ok, I turned the wheels out and turned the crank pulley nut CLOCKWISE and watched the flywheel. Still no marks. I took out the number 1 spark plug and watched as the piston started coming up. I turned very slowly and watched with a flashlight still no marks so I brought the number 1 cylinder around to the next iteration and did the same thing but still nothing. I took a rag and some brake cleaner and cleaned the flywheel surface to a clean silver color and tried again. Still nothing.
My Haynes manual shows a fairly noticeable mark and I don't even have a scratch.
Help.
Old 12-31-2011, 03:26 PM
It's there it's just kinda hard to see. It's more of a slight scratch than a clear mark. There will be two sets. You will want the set with more marks. It will have -15 degrees and one mark ahead and one mark behind it, like I said, more of a scratch. And remember, they are not on the teeth, they are to the right of it.
Old 01-01-2012, 07:04 AM
gacinaz's Avatar
Ok, I checked again and there just are not any marks. I am wondering if some changed the flywheel and used one that was not marked.
Is there any way to mark the flywheel short of replacing it? Does anyone have pictures of a flywheel with the marks that I can use to mark mine closest enough to get through emissions?
ayavner
05-28-2008 03:07 PM
fastludeh22
09-25-2006 08:25 AM
preluda92
10-24-2003 09:41 AM
dallandra
04-13-2002 07:00 PM
boomslang
11-30-2001 06:48 AM
Quick Reply: 91 Accord F22A1 Ignition Timing
