Go Back   Honda-Tech > Community Forums > General Discussion and Debate
Old 12-28-2011, 12:34 PM   #1
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
Default What is a four-wheel alignment?
So I took the 2005 Odyssey EX to the Honda dealer for an alignment this morning. The steering wheel was rotated about 10° when I took it in. I get it back about 1.5 hours later, start driving home, and notice the the steering wheel is still cocked. So I take it back. I look at the sheet and notice that the front camber is slightly out of spec (printed red) on both wheels. They did not mention this before I left.
So I explain that the steering wheel is still cocked and they agree to take the vehicle back. I asked about the front camber and they state that they cannot correct the front camber. I mention that it is outlined in the Helm manual where you can replace the strut bolts with adjustment bolts.
So I get the van back. They do not provide the current alignment specs and say that they cannot correct the alignment.
I call the service manager and explain the situation. At first he said that they cannot adjust it. I mention the Helm manual. He then states that they do not carry the alignment bolts in stock. He says that he will look into it and call me back. This was two hours ago.
So, what exactly is a four wheel alignment? I just paid about $75 for a front toe adjustment, which takes about 15 minutes.
Cliffs: Honda dealer says that they cannot adjust the front camber on an 05 Odyssey and the Helm manual says otherwise.
Edit: I attached the spec sheet for the van. Notice the red.
404: Care not found.
Dogginator is offline   Reply With Quote
Old 12-28-2011, 12:39 PM   #2
the comanche
I would like my name to be Cattinator
the comanche's Avatar
Default Re: What is a four-wheel alignment?
Good lord sounds like a bunch of asshats at that Honda dealer.
the comanche is offline   Reply With Quote
Old 12-28-2011, 12:40 PM   #3
94EG8
Honda-Tech gave me this lousy title
94EG8's Avatar
I used to do alignments at my Honda dealer. All we could adjust was toe. No one ever mentioned that adjustment bolts to me. Also, it took us the better part of an hour to do an alignment, mostly due to out shitty alightment hoist, and the fact that we always had to the vehicle for a test drive when we were done (company policy, anything besides an oil change must be test driven)
"Bacon tendercrisp chicken, the most powerful sandwich in its class."
Per ardua ad astra
My F/S thread -> http://hondamarketplace.com/showthread.php?t=2900962
Originally Posted by Knightsport View Post
Hello,
This is Knightsport, from the internet. I will be out of the internet from June 2 and returning on June 11th. In my absence I suggest you pray as there can be only one Knightsport from the internet.
Thank you and God Bless,
-Knightsport
94EG8 is offline   Reply With Quote
Old 12-28-2011, 12:42 PM   #4
the comanche
I'm texting my friend who works at a reputable Honda dealership over in the Northwest to see what his take is on it
Old 12-28-2011, 12:43 PM   #5
H22Ej1
Shenanigans
H22Ej1's Avatar
Send a message via AIM to H22Ej1
Turn the wheel all the way to the bumpstops and give it a good slam, it will skip some teeth and be spot on.
Four wheel alignment includes any factory adjustment, if they need to install extra parts like the adjustable bolts parts and labor for install of the bolts will be extra, then in the future they will adjust (if they notice them) with a regular four wheel alignment. It really is a ripoff, I always ask for a toe set only, unless camber is out significantly it will not affect wear or driveability nearly as much as toe.
<S2000> <J32A2 EG>
having one cam is like having one nut, you need two to get the job done right
H22Ej1 is offline   Reply With Quote
Old 12-28-2011, 12:44 PM   #6
the comanche
He said that only the s2000 comes with the hardware to adjust camber. I'm guessing you can get off brand camber bolts for the Oddysey and have someone besides a Honda dealership adjust them. Your synopsis is correct, you paid 75$ for a front toe adjustment only Why it's called a four wheel alignment?
Old 12-28-2011, 12:47 PM   #7
hapexamendios 2.0
R.I.P.
2002 Lamborghini Gallardo
hapexamendios 2.0's Avatar
Isn't the point that they should be able to make it right with whatever is on the car already?
“Life is like a movie, if you've sat through more than half of it and it’s sucked every second so far... No one should blame you for walking out early.”
hapexamendios 2.0 is offline   Reply With Quote
Old 12-28-2011, 12:53 PM   #8
chris_c
chris_c's Avatar
A 4 wheel alignment is exactly as it reads. Measurements and adjustments to all 4 wheels. Some vehicles are engineered with this adjustability (IRS for example) where other cars with solid axles won't have 4 wheel adjustability...
http://images.honda-tech.com/set1/smile/emwink.gif
YJ-7: wrangler frame and tub, cj-7 front clip, scout II dana 44's, 350hp 327ci corvette engine, no tranny, no t-case...
chris_c is offline   Reply With Quote
Old 12-28-2011, 12:54 PM   #9
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
Honda carries the camber bolts. They replace the two lower strut bolts where the hub connects to the strut. It is p/n 90120-SHJ-A00. They are part 13 in the diagram.
Old 12-28-2011, 12:55 PM   #10
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
They should be able to do it unless something is bent. They did not inform me that the camber was incorrect at all. I had to read the sheet.
The adjustment bolt range could put it back into spec.
Old 12-28-2011, 01:02 PM   #11
H22Ej1
Shenanigans
H22Ej1's Avatar
They are not going to add in the adjustment bolts free of charge, parts and labor to install will cost more than a standard alignment. Which is why they didn't do it. Why they didn't bring that up to you is beyond me...young inexperienced tech/service advisor or either with an idgaf attitude probably.
<S2000> <J32A2 EG>
Old 12-28-2011, 01:04 PM   #12
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
I think that I may send an email to the dealer using a honda-tech.com email address.
Is that an abuse of power? :philosoraptor:
Old 12-28-2011, 01:08 PM   #13
hapexamendios 2.0
R.I.P.
Right, the fact that they cannot make it right with what they have makes them seem incompetent.
No way, do it!
Old 12-28-2011, 01:10 PM   #14
Professor15
Professor15's Avatar
Send a message via AIM to Professor15
Most techs wont get into adjusting camber when it comes to your run of the mill vehicle. All they will do is toe and go, adjusting the camber and replacing camber bolts can get expensive if they want to charge you for all that labor. How bad is your camber?
Professor15 is offline   Reply With Quote
Old 12-28-2011, 01:23 PM   #15
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
I added the spec sheet to the first post.
Old 12-28-2011, 01:29 PM   #16
Tim2179
eight equals equals equals D
1963 Buick Riviera
Tim2179's Avatar
iTrader Rating: (2)
Stumpjumper Pro
I have lost faith in any place that claims to do alignments properly. At least you get a print out. I swear when i drop mine off, they don't do a damn thing to the car.
unless you're speaking McNuggets into my hand, I don't want to hear it
Tim2179 is offline   Reply With Quote
Old 12-28-2011, 01:29 PM   #17
the comanche
It just irks me that they didn't even suggest the camber bolts with those specs, I mean aren't they in it for extra work/sales/labor?
Old 12-28-2011, 01:31 PM   #18
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
You would think. They could have sold me $28 of bolts.
Old 12-28-2011, 01:32 PM   #19
the comanche
and bullshitted you the time of installation and charged you for labor they can't even justify... that's just weird. It is the techs responsibility at Honda dealerships to upsale and suggest things though. Maybe your tech was a new guy
Old 12-28-2011, 01:38 PM   #20
Dual-500
Dual-500's Avatar
Exactly.
TEAL HATCH CLUB (THC) #57
Dual-500 is offline   Reply With Quote
Old 12-28-2011, 01:46 PM   #21
H22Ej1
Shenanigans
H22Ej1's Avatar
As an ex-service sales I would always bring up the problem and depending on how busy we were or how much corpo was up my *** to get sales, push the sale or downplay it. A lot of times techs get pissed doing bs like this (I don't know why, its like double labor and alignments pay big compared to the time it takes) and a pissed tech just fuxors my day. With these measurements though I would have brought it to your attention and pushed for a sale. If cross camber was in spec I would have probably down played it (as it is less likely to be a problem) and leave the decision up to you the customer.
<S2000> <J32A2 EG>
Old 12-28-2011, 01:50 PM   #22
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
Yeah, the cross camber is way off. The tires are feathering on the outside.
Old 12-28-2011, 01:50 PM   #23
Evs-One
Solbros Owns Me
Evs-One's Avatar
Send a message via ICQ to Evs-One Send a message via AIM to Evs-One
ITT: arm chair alignment specialists
OP, pic doesn't show up. Can you list the before and actual specs?
Edit- now it works ...
Evs-One is offline   Reply With Quote
Old 12-28-2011, 01:51 PM   #24
Dogginator
Daisy... Daisy...
1997 Acura Integra
Dogginator's Avatar
The picture is an attachment. I'm not sure why it is not showing up.
Old 12-28-2011, 01:51 PM   #25
Evs-One
Solbros Owns Me
Evs-One's Avatar
looks like the subframe has shifted, causing pos camber on one side and neg on the other.
2010, alignment, civic2005wheel, group, hoda, honda, misalignment, odyssey, powered, rear, s2000, sex, vbulletin, webcam, wheel
