Go Back   Honda-Tech > Community Forums > General Discussion and Debate
Old 12-28-2011, 08:41 AM   #1
fsp31
fsp31's Avatar
Default Advice on small 4x4 (ext cab) pickup
I'm looking for a used 4x4 pickup, preferably 2005+. I won't be using this vehicle for "extreme" off-roading, but it will see quite a lot of time in the mountains (snow, jeep trails, etc.). For this reason (and for better gas mileage), I'm leaning toward a compact rather than full size truck. I'm assuming that a smaller truck would handle better in these conditions. However, that's just an uninformed assumption on my part, so please correct me if that isn't the case.
Based on what research I've done, the Toyota Tacoma is the "be all end all" of small trucks... and they better be considering how much they seem to cost.
So I was wondering... are there other small 4x4 trucks worth considering besides a Tacoma? I'm just not finding much reliable information. Do y'all have any particular recommendations?
Thanks!
fsp31 is offline   Reply With Quote
Old 12-28-2011, 08:43 AM   #2
Flav
Honda-Tech Attention Whore (Sirius)
Flav's Avatar
Default Re: Advice on small 4x4 (ext cab) pickup
I did the research recently b/c my dad needed a new truck after Toyota bought his back. Final answer.....he got another Tacoma. They are that good is my opinion.
Flav is offline   Reply With Quote
Old 12-28-2011, 08:46 AM   #3
Tennobanzai
Tennobanzai's Avatar
Tacos ftw. I like the models before 05
Tennobanzai is offline   Reply With Quote
Old 12-28-2011, 08:49 AM   #4
Flav
Flav's Avatar
Me too. I found my dad a minty 1 owner 85k mile TRD 4-Door. He loves it.
Old 12-28-2011, 08:55 AM   #5
hapexamendios 2.0
R.I.P.
2002 Lamborghini Gallardo
hapexamendios 2.0's Avatar
What did he pay for it if you don't mind my asking?
“Life is like a movie, if you've sat through more than half of it and it’s sucked every second so far... No one should blame you for walking out early.”
hapexamendios 2.0 is offline   Reply With Quote
Old 12-28-2011, 08:56 AM   #6
bad-monkey
bad-monkey's Avatar
Send a message via AIM to bad-monkey
i owned one for about 14 months. 2007 Tacoma V6 Prerunner 6spd.
in the midsize truck world (the 05+ are no longer "compact"), the tacoma is the best option. but that doesn't mean it's a great truck. gas mileage won't stun you, 18mpg mixed no matter how hard you try to hypermile. the interior is the cheapest interior i've ever seen--it's like they salvaged plastic from an 80's daihatsu and mixed it with trash to create the lowest quality HDPE possible. It's simultaneously hard and soft--starting at it the wrong way will gall the interior pieces. Interior has that cheap toyota smell, aka the smell of the cheapest interior plastic and cheapest upholstery offgassing to create that distinct aroma of cheapness. Sit in a 5 year old corolla or a 8 year old camry and you'll know that stench.
Engine performance isn't bad, the 236/260 is more than enough engine for most duties other than towing. the 6 spd driving experience left alot to be desired. throws were longer than my arm. flywheel was probably 65 lbs since anything faster than a 4 second shift would not be smooth. acceleration was decent, for a truck. overall driving experience was what you'd expect from a truck. the HDPE (higher quality than the interior, or, at the very least thicker) bed was cool to me, made it easy to install additional anchors to facilitate motorcycle hauling, but may not be suitable for people looking for a work truck--doesn't look like the bed would survive too many trips hauling CMU/gravel/etc. Off-road performance is typically Toyota, with good ground clearance and no-frills but effective 4wd. reliability is hit and miss...the pre-08 trucks had a bunch of TSB's out on them for issues ranging from rear suspension problems (not enough spring in the rear to prevent bottoming out; failing leaf springs--which are sometimes NOT covered under warranty by ToA) to tailgates that were snapping in half with loads as little as 150 lbs on it (aka, someone sitting on their gate, making taco's out of their tacos) and other minor issues that can really **** off owners.
That being said, it's an OK truck. I was happy to see mine get replaced by my F150, which i felt wasn't nearly as cheaply built. if you can get one for a decent price used (which you can't) i'd think it's certainly worth your money, but in the end, the main issue is value. Paying 19K for a 4 year old truck with 50k miles that sells 23,500 OTD new makes no sense to me. Would rather pay 3.5K for a Ranger V6 4x4 and spend a small portion of that 15.5K on a lift kit, bigger wheels and repairs. or, get a 98-04 tacoma which is smaller, and down on power, but way better built. still overpriced for what they are (10 year old used trucks) but less of a "Taco Premium" than the 05+ trucks.
bad-monkey is offline   Reply With Quote
Old 12-28-2011, 08:58 AM   #7
Flav
Flav's Avatar
$11,000.00. It's an 01. All records. Rhino liner. Soft toneua cover. Super nice condition.
Old 12-28-2011, 09:01 AM   #8
Tennobanzai
I also had a TRD 4 double cab. Best thing was I bought it brand new and put on around 35-40k miles and ended up selling it 2-3 years later for only 2.5K less then I paid for it.
This is the only car/truck I have ever owned that NEVER had any problems at all. Probably got lucky but I was shocked that I never got any minor problem with mine.
Old 12-28-2011, 09:08 AM   #9
Gustav129
1981 Ford Mustang
Gustav129's Avatar
gustav129
I don't know what you have for Mountains down there in Okie, but for "alot of time in the mountains (Snow, Jeep trails, etc)" around here, you wouldn't want to have a 2005+. It will be scratched and dented in no time. If you were around here, I'd say an older Tacoma, like 90's. "Extreme Wheeling" to us is Moab. Normal "Jeep trails" to us might be considered "extreme" wheeling where you are.
#129
1981 Mustang - 129cp
1987 CRX Si - 129gs
Gustav129 is offline   Reply With Quote
Old 12-28-2011, 09:08 AM   #10
chris_c
chris_c's Avatar
small and mid-size pickups... all the drawbacks of a fullsize with no additional benefits...
http://images.honda-tech.com/set1/smile/emwink.gif
YJ-7: wrangler frame and tub, cj-7 front clip, scout II dana 44's, 350hp 327ci corvette engine, no tranny, no t-case...
chris_c is offline   Reply With Quote
Old 12-28-2011, 09:14 AM   #11
Flav
Flav's Avatar
Not at all. Meneuverability. Parking. Ease of entry/exit. Better on gas (even if slightly).
My dad wanted something that fit in his garage too. full size extra or dble cabs wont.
Midsize trucks definately have their upside.
Old 12-28-2011, 09:21 AM   #12
fsp31
fsp31's Avatar
Sorry about the misleading sig... I'll be moving to Billings MT within the next few months, and I'd like to buy a truck here (in the south) before heading up there where they tend to be more expensive.
Those are awesome pics, but a bit more "aggressive" than I had in mind!! I do a lot of fly fishing, hiking, and general exploring with the fam. This won't be a vehicle for the sake of 4 wheeling, but more for getting me through some rough stuff if my objective lies on the other side.
Old 12-28-2011, 09:28 AM   #13
fsp31
fsp31's Avatar
Originally Posted by bad-monkey View Post
i owned one for about 14 months. 2007 Tacoma V6 Prerunner 6spd...
WOW, great post!! I think you did a better job than I did describing exactly my dilemma!
I have about given up on Tacoma's due to the ridiculously high prices, and the fact that I'm having a very hard time finding anything from 98' - 04'. People must keep those and drive them into the ground.
Regarding your comment about the Ranger, what would you consider the best candidate for sort of thing? I'm very comfortable working around cars. Don't own a hoist, but suspension work, timing belt, etc. is no problem. I would hesitate to do much of a lift though. I'd like to drive this truck daily...
Old 12-28-2011, 09:31 AM   #14
chris_c
chris_c's Avatar
what is your price bracket?
Old 12-28-2011, 09:38 AM   #15
hapexamendios 2.0
R.I.P.
Nice.
Old 12-28-2011, 09:40 AM   #16
Gustav129
1981 Ford Mustang
Gustav129's Avatar
gustav129
Most of those pics are near the Idaho/Montana Border. Billings is flat. You wouldn't hit mountains until almost Bozeman. Everything west of Butte looks like the pics posted.
#129
1987 CRX Si - 129gs
Old 12-28-2011, 09:43 AM   #17
Chief Brody
Asst to Mod in Training
Chief Brody's Avatar
1995.5+ Tacoma gets my vote.
If it doesn't HAVE to be a pickup, look into a Cherokee.
Originally Posted by BauleyCivic View Post
I did the same thing with the Miata...got into a serious relationship, moved, and the car didn't make sense anymore.
Originally Posted by 90hatch94dsm View Post
Because the relationship was with a woman?
Chief Brody is offline   Reply With Quote
Old 12-28-2011, 09:47 AM   #18
fsp31
fsp31's Avatar
I'd like to keep at $10k or under. May not be realistic though...
Old 12-28-2011, 09:48 AM   #19
fsp31
fsp31's Avatar
It's flat right in Billings, but the Beartooth highway, Red Lodge ski area, etc. are less than 60 miles west... where I'll be spending my weekends.
Old 12-28-2011, 09:54 AM   #20
Belmont
Belmont's Avatar
Get a TJ with a trailer.
Belmont is offline   Reply With Quote
Old 12-28-2011, 10:03 AM   #21
bad-monkey
bad-monkey's Avatar
i'm no expert on the ranger, but from what i can gather, they are prone to bad heater cores, spotty auto locking 4wd hubs, and some front suspension issues. all sound like PITA issues, but rangers are generally so cheap that I think i could probably live with those issues for the price. i know some people with rangers and they don't complain, but they either own heavily modified pre-runners, or 2wd 4cyl moto haulers that get driven 3x a month.
i will say, skip the colorado or the S10, i've seen nothing but problems for those trucks.
Old 12-28-2011, 10:58 AM   #22
__oversea
__oversea's Avatar
You mean 97+ v6 Tacoma's
__oversea is offline   Reply With Quote
Old 12-28-2011, 11:26 AM   #23
Danza
2007 Acura TL
My Garage
Danza's Avatar
Send a message via AIM to Danza
why?
22RE is king.
Comments or Statements made using this screen name are frequently made in jest. These statements do not represent the position of any organization or entity and should not be taken as factual commentary on any topic, to include the author.
Danza is offline   Reply With Quote
Old 12-28-2011, 11:49 AM   #24
1990CamaroRS
1990CamaroRS's Avatar
Tacoma
you were saying???
2002 Silverado 2500HD, Duramax/ZF6. clutch/PT76-PT106 compounds/built dual CP3/50% overfuel injectors/tune - 903rwhp, 1500+rwtq (maxed dyno by 1700rpm). the "sleeper" service truck.
1990CamaroRS is offline   Reply With Quote
Old 12-28-2011, 11:51 AM   #25
__oversea
__oversea's Avatar
Originally Posted by Danza View Post
why?
22RE is king.
Is okay for daily driver, but when you have to tow or haul something, you will hate it.
1990CamaroRS what is the point of posting that picture?
Ford SVT Raptor have same problem.
4x4, 9, 94, aftermarket, lift, mobil, parts, pick, powered, samurai, sport, suzuki, trac, vbulletin
