need help! 1993 accord dies while driving
Old 12-18-2011, 06:44 PM
boostedh22fag's Avatar
Default need help! 1993 accord dies while driving
My girls 93 accord suddenly dies while its driving and just coasts with all the electrical stuff on. Then it will just crank over but not start. She said to get it to start she disengaged the shift lock and put it in neutral, took the key out of that then it started right up. In the past when it was rainy it wouldn't start it would just crank over but it has been a few months since it did that. I haven't noticed and cracks in the distributor or Ive heard it may be a problem with the ignition module. Please if anyone may know anything about this.
Old 12-19-2011, 06:36 AM
GhostAccord's Avatar
Default Re: need help! 1993 accord dies while driving
Could be the main relay needs to be soldered/replaced. There is a lot of information online related to diagnosing and fixing the infamous Honda main relay issue.
I have never personally had to deal with the main relay issue. However, I did have an issue with my ignition control module. It wouldn't start at all after it quit. No spark. Seems as though your issue is more of an intermittent problem, main relay or maybe a coil issue.
Old 12-19-2011, 12:17 PM
StreetsideStig's Avatar
As usual, I agree with Ghost. Main Relays go out all the time, and really start to act up in when the weather changes, because that's when the soldering comes loose. The part is about 50 bucks at a parts store, or you can resolder it yourself.
Pull it out and take the cover off. If you have carbon scoring around the solder points, it needs work.
Old 12-19-2011, 01:00 PM
Bruce Banner's Avatar
Could it be his dizzy?
Old 01-16-2013, 01:33 PM
Rainydrought's Avatar
My 93 Honda accord died on me while driving and will not restart. I changed the plugs and wires but the plugs are not getting fire, please help
Old 01-16-2013, 05:28 PM
Crxh22ajdm's Avatar
^^ maybe a bad coil, or something in the distributotr.
Old 01-16-2013, 05:36 PM
Crxh22ajdm's Avatar
That happen to me and guess what, it was my timing, I dont know how but the tensioner was losed, I had a missing bolt in there, and only somethimes the car star, then while driving it the car will died, I part out the engine and tranny and got ab H22A with only 59xxx on it
Old 01-16-2013, 06:28 PM
SlowDA9teg's Avatar
Same problem I'm having. I decide to have my battery,and alternator checked at the parts store and bought a new ignition control module and got a backup main relay at the junkyard. All I have to do now is hookup everything up and hopefully it starts .ill let you know how it goes so I can hopefully give you an idea of what it was in case you don't find it before me
Old 01-16-2013, 07:20 PM
More than likely the ignitor (Ignition Control Module) inside the distributor.
Old 01-18-2013, 12:30 AM
ozmannnnn's Avatar
before jumping the gun try cleaning your battery terminals, grounds, etc
jayzeno
06-10-2012 04:32 AM
culinaryjeremy
03-21-2009 07:15 AM
chad olson
01-23-2009 02:01 PM
nissmoser
08-12-2008 05:44 PM
mrnicolas
06-29-2003 08:41 AM
Quick Reply: need help! 1993 accord dies while driving
