Weird metal scraping sound coming from front right wheel?
Old 12-09-2011, 11:19 PM
dwkt's Avatar
Icon2 Weird metal scraping sound coming from front right wheel?
My Car: 2000 Honda Civic SiR (canadian SiR = usdm Si)
Mods: Cold air intake, slightly lowered with lowering springs on OEM struts (coils coming in Spring), and its got rear camber kits and alignment is good.
So today I got in my car and pulled out of its parking space. As I slowly drove forward and turned right I heard a sound coming from the front right wheel area. It sounded like metal on metal scraping. It lasted for about 2 seconds then happened again when I made another right turn then a left. The first time I heard this noise was about 2 months ago shortly after I replaced my rotors. I hear it maybe once every 2 weeks and it only seems to happen when driving after its been parked for a while and at slow speeds while turning. After the first time I heard this noise I jacked my front end up and tried shaking my wheels, everything was tight. While the front end was up (on jack stands) I turned the steering wheel from all the way left to all the way right and back again and nothing sounded wrong. My brother, who is a mechanic, was under the drive-shaft and said everything sounded and looked good. I'm having troubles diagnosing this issue, if anyone has suggestions please help me out. If you need any info on my car just ask and I'll try my best to answer. Thanks.
dwkt is offline
Old 12-09-2011, 11:48 PM
Ak-Civic's Avatar
Default Re: Weird metal scraping sound coming from front right wheel?
Wheel bearing
Ak-Civic is offline
Old 12-10-2011, 04:10 AM
Retired Moderator
EsotericImage's Avatar
Its not the wheel bearing..
I would look into loose brake pad.. Did u clean/wire brush the sliders and re-lube them along with the caliper pins? Did you accidently hit the shielding? Did u use the rotor set screws?
I would start there.
EsotericImage is offline
Old 12-10-2011, 03:47 PM
dwkt's Avatar
should I be concerned about what I'm hearing?
dwkt is offline
Old 12-10-2011, 03:50 PM
Texas4door's Avatar
It's your rotors scraping on your heat shield.
You probably bumped it on accident and bent the edge down slightly, or didn't readjust it if you got thicker than normal rotors.
Easy confirmation: take the wheel off and spin it slowly, and watch the gap between the heat shield and the rotor. If it scrapes, you know that's the problem, and it's easy to simply re-bend it out of the way.
No offense, but just because your brother didn't see anything, doesn't mean YOU might not see something he accidentally missed.
Good luck!
Texas4door is offline
Old 12-10-2011, 08:22 PM
dwkt's Avatar
Good luck!
thank you
dwkt is offline
Old 12-10-2011, 10:19 PM
jdmdomo's Avatar
LOL...
jdmdomo is offline
Old 12-11-2011, 05:58 AM
Resident Gearhead
BryanM.'s Avatar
Good luck!
You mean brake dust shields, (Honda calls them spash guards).
This is want I think is causing the noise too. Check it out.
BryanM. is offline
Old 12-11-2011, 08:10 AM
bchin86's Avatar
Check that first, when I first got my 99 ex the wheel bearing was bad and cause the front of the axle to rub the hub or the wheel bearing causing noise that sounds similar to the backing plate touching the rotor. The rotor touched the backing at times because of this also. So check both.
Good luck!
It never hurts to double check things, especially when diagnosing.
bchin86 is offline
Old 12-11-2011, 11:01 AM
dwkt's Avatar
Originally Posted by jdmdomo
LOL...
what is funny?
dwkt is offline
Old 12-11-2011, 11:19 AM
Resident Gearhead
BryanM.'s Avatar
Recent posts by "jdmdomo"
lol
BryanM. is offline
Old 11-15-2014, 09:27 AM
Jennifer M's Avatar
Maybe this will help someone out. I have an 09 Honda Civic Ex 2 door. I started hearing a metal on metal scraping noise. It was intermittent. Sometimes when I was going slow and sometimes when I was going fast. Then it started getting worse. It sounded like something was bent & scraping when I made turns or at different times. Sometimes if I turned my wheel a certain way it would stop. My conclusion... I took my car to Tire Kingdom & it was my back brakes. I knew it was the back because I could tell by the sound location. Anyway I hope this helps someone because after reading dofferent stories on these forums I never came up with a definite answer. It was always a guess so if you hear this check your brakes.
Jennifer M is offline
jelyman
04-21-2015 12:53 PM
Sean @ ESG
Honda S2000
07-24-2010 09:01 PM
1_slow_crx
09-01-2006 09:46 AM
ZipTieGUy
03-03-2006 12:46 AM
ilikemyaccord
04-07-2004 10:04 PM
Quick Reply: Weird metal scraping sound coming from front right wheel?
