Old 12-08-2011, 06:42 PM   #1
theguy22
theguy22's Avatar
Default what kind of oil should a 97 civic ex with 200k miles use?
Ok, here's my situation. I have a 1997 civic ex coup and i need to do MY first oil change. I am not sure what kind of oil was used. i know since i got high mileage i should use thicker oil like 1040. but should i use synthetic or conventional/normal? would it damage the engine if i used conventional? a lot of people say to use either one but would using synthetic really make a difference? i bought a gallon of castrol GTX motor oil so i dont know if i should return it for full synthetic or just go with what i have. by the way, i got a D16y8 vtec engine. it has 211k on it.
theguy22 is offline   Reply With Quote
Old 12-08-2011, 06:47 PM   #2
hannslebo
hannslebo's Avatar
Default Re: what kind of oil should a 97 civic ex with 200k miles use?
No need to use synthetic...use what you have
hannslebo is offline   Reply With Quote
Old 12-08-2011, 06:49 PM   #3
furious94ls
furious94ls's Avatar
Use 5w30 oil. I've been using Penzoil High Mileage 5w30. My car has 188k. After I install a new oil pan I'll be running Penzoil Platnium full synthetic 5w30.
Just make sure you don't have any existing oil leaks before switching to synthetic. I changed the valve cover gasket, spark plug grommets, valve cover bolts/gaskets, and distributor gasket. Engine is nice and sealed up now. Oil pan is seeping and it's shitty, so I'm gonna replace it in the spring.
Don't use 10w40. If you engine is in good shape stick to the 5w30.
-2003 Honda Accord EX-L V6-6MT
-1998 Honda Civic HX 5MT (work car)
furious94ls is offline   Reply With Quote
Old 12-08-2011, 09:48 PM   #4
Texas4door
1998 Honda Civic
Texas4door's Avatar
5W-30 Valvoline Maxlife with Lucas Oil Stabilizer Heavy Duty.
(and that Maxlife is Synthetic Blend, NOT full syn, so you get better protection than conventional, but less expensive than a full syn oil)
That outta keep your motor running for a long long time
Texas4door is offline   Reply With Quote
Old 12-08-2011, 10:09 PM   #5
TOO MUCH TORQUE
TOO MUCH TORQUE's Avatar
dont put any additives especially lucas in your motor. it doesnt NEED it
Any 5w-30 high mileage will keep your engine running well: valvoline, castrol, pennzoil, mobil, supertech, quakerstate
TOO MUCH TORQUE is offline   Reply With Quote
Old 12-08-2011, 11:20 PM   #6
Texas4door
1998 Honda Civic
Texas4door's Avatar
What's wrong with Lucas?
Seems to work pretty good for me (but I use the full syn with full syn high mileage oil)
oO
Old 12-09-2011, 01:25 AM   #7
HondaPartsHero
Technical Hero
HondaPartsHero's Avatar
5w30 regular oil. No need for synthetic or high mileage. If your car leaks oil fix the leak, if it burns oil the high mileage isn't going to do that much depending on the condition of the part that's failing.
OBD1/2 SOHC/DOHC VTEC HARNESS
MINI ME SUBHARNESS
02 EXTENSION HARNESS
Hondapartshero.net
HondaPartsHero is offline   Reply With Quote
Old 12-09-2011, 07:25 AM   #8
motegicivic
No synthetic try to stick to 5w 30, don't want to go too thick, 10w 30 max. High mileage oil can't hurt, it has some additives in it like seal conditioners etc.
motegicivic is offline   Reply With Quote
Old 12-09-2011, 07:52 AM   #9
HondaPartsHero
Technical Hero
It's not like it's magic potion, it has a burn inhibitor and a chemical that basically swells seals. If its not burning or leaking just use a plain ol 5w30 oil.
MINI ME SUBHARNESS
Hondapartshero.net
Old 12-09-2011, 09:06 AM   #10
Blacknight117
1995 Honda Civic
Blacknight117's Avatar
iTrader Rating: (1)
My EJ1 has about 300K on it, and I use Castrol High Mileage. 5w-30 during the colder months, and 10w-30 in the warmer months.
EG/EJ Sideskirt removal: http://honda-tech.com/showthread.php?t=3043855
Nottin but OEM: www.hondapartsunlimited.com
My build: MY EJ1 Build
Blacknight117 is offline   Reply With Quote
Old 12-09-2011, 09:09 AM   #11
motegicivic
Originally Posted by Blacknight117 View Post
My EJ1 has about 300K on it, and I use Castrol High Mileage. 10w-30 during the colder months, and 5w-30 in the warmer months.
Shouldn't that be the opposite?
Old 12-09-2011, 09:11 AM   #12
Blacknight117
1995 Honda Civic
iTrader Rating: (1)
Yea...my bad haha..edited
Old 12-09-2011, 01:57 PM   #13
furious94ls
Curious as to why you guys are against Synthetic oil? In all my cars I noticed quicker cold starts, cleaner oil longer, and longer change intervals. Penzoil Platnum is $25 for 5 quarts at Wallmart. With an OEM filter your looking at $30 every 5k or 5 months.
Old 12-09-2011, 04:00 PM   #14
motegicivic
Only if you start off new use it, or relatively new. Basically for a older cars that never used it is a no no, may promote leaks.
Old 12-09-2011, 06:23 PM   #15
furious94ls
Thats kind of a myth. I do know that some "older" cars with seepage seep a lil more with synthetic. My father's TSX with 100k just switched over and he has always used Honda motor oil, and the car starts quicker and even has a lil better fuel economy.
I say if you aren't leaking or seeping its fine. Even if it did, then you can always switch back. It's kind of rare to have a car leak just because of switching oil.
Burning oil is another issue, some motors are sensitive to what oil and how much they consume.
Old 12-09-2011, 11:10 PM   #16
mrprofits1
1997 Honda Civic
mrprofits1's Avatar
iTrader Rating: (1)
The China-men built the railroad The Indians saved thr Pilgrim And in return the Pilgrim killed em They call it it Thanksgiving, I call your holiday hellday Cause I'm from poverty, neglected by the wealthy-NAS
mrprofits1 is offline   Reply With Quote
Old 12-10-2011, 07:42 PM   #17
furious94ls
Lol, good luck with the tranny with "any ATF"
Old 12-10-2011, 07:51 PM   #18
cetcivic
cetcivic's Avatar
mazola
cetcivic is offline   Reply With Quote
Old 12-10-2011, 10:17 PM   #19
mrprofits1
1997 Honda Civic
mrprofits1's Avatar
iTrader Rating: (1)
200, 200k, 97, 98, change, civic, h22, high, honda, kind, mileage, oil, put, switch, synthetic
