Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Accord & Crosstour (2003 - Current)
Old 12-04-2011, 08:13 AM   #1
student23
2005 Honda Accord
Icon2 Searched, Couldn't Find: Pic of Coolant Drain Plug on Engine Block
Hey everyone,
Changing the water pump on my 05 Accord V-6 and can't find the coolant drain plug on the engine block. Anyone have any pics or helpful advice? Thanks in advance!
student23 is offline   Reply With Quote
Old 12-04-2011, 09:07 AM   #2
redbull-1
redbull-1's Avatar
Default Re: Searched, Couldn't Find: Pic of Coolant Drain Plug on Engine Block
See step number 7 of this engine block heater instructions:
http://www.bernardiparts.com/Images/...r_AII30203.pdf
redbull-1 is offline   Reply With Quote
Old 12-04-2011, 02:05 PM   #3
BLKFLSH
BLKFLSH's Avatar
I used the one on the other side of the block on my 03 V6. It has a nipple on it, to connect a drain hose. It's on the opposite side of the block, on the passenger side of the car.
92 accord EX sedan : sold after 12 great years
03 accord EXV6 sedan: smooth as silk
BLKFLSH is offline   Reply With Quote
Old 12-04-2011, 08:01 PM   #4
student23
2005 Honda Accord
Thanks a lot for the diagram. That was great!
Hey, blkflsh. I really wish I could locate where that one is because I ended up with 4qts of coolant on the floor of my garage. haha If you have/find a picture any where, I could still really use it. Thanks a lot!
Old 12-05-2011, 10:40 AM   #5
student23
2005 Honda Accord
I'm having a hard time getting my new timing belt on. It seems to be really tight (even with the tensioner compressed all the way). I ordered the kit from AutoPartsWarehouse. Any input would be appreciated. Thanks!
Old 12-05-2011, 04:48 PM   #6
BLKFLSH
BLKFLSH's Avatar
Did you compare the new belt with the old belt? The block drain is on the windshield side of the engine, not the bumper side. You may need a light under there to see it. Do you have a shop manual? Did you remove the tensioner, put it in a vise, compress it, then insert a pin to hold it, then re-install? Also, are you using the battery tie down bolt to hold the adjuster? You really shouldn't be guessing on this stuff. Make sure everything lines up (timing marks) before you put everything back together. Rotate the engine a couple times and recheck the timing marks. One tooth off will matter.
Old 12-05-2011, 05:34 PM   #7
student23
2005 Honda Accord
Thanks a lot for the response. I was able to get the belt on...wasn't guessing on anything. I made sure everything was lined up at TDC. With regards to the bolt, I'll look around where you are talking about. I have a Haynes manual but it doesn't show the bolt that you referenced. Is there a nipple directly on the bolt? That sounds more like I was looking for and have heard about. Thanks and I'll let you know how it goes. I'm in the garage working on it right now (reassembling everything). Thanks again for your input!
Old 12-06-2011, 03:32 PM   #8
BLKFLSH
BLKFLSH's Avatar
It looks like a bolt, with a pipe going through the head of it. You only have to loosen it, not remove it. Good luck.
Old 12-07-2011, 04:31 PM   #9
student23
2005 Honda Accord
Found it. Great explanation. I'll post a pic later. Thanks again!
Old 12-16-2011, 10:32 AM   #10
gwiffer
Since you already removed the water pump and the coolant has drained out, you shouldn't have to use the block drain.
Which TB kit did you purchase?
07 AV6-6 SDN (>100K)...rock chips, dings, and rattles!
gwiffer is offline   Reply With Quote
Old 12-20-2011, 12:32 PM   #11
student23
2005 Honda Accord
I hadn't removed the water pump yet when I was originally looking for it. Also, after replacing the water pump, I wanted to run distilled water through the cooling system and then drain all of it out at the end and instead of letting it go all over the floor by unscrewing the front coolant drain plug (which has a MASSIVE diameter) I wanted to drain it in a "clean" manner.
Old 12-20-2011, 12:38 PM   #12
student23
2005 Honda Accord
Default Picture as promised
So I kept searching (thanks for not giving up on me BLKFLSH - haha) and finally found the engine block coolant drain plug with the nipple on the bolt. It is in a location that is pretty tough to get to but you can if you want to. Check out the picture that I took from the rear of the front passenger-side wheel well. If you have any questions, feel free to ask. I hope this helps you as much as it would have helped me!
Old 12-20-2011, 03:50 PM   #13
gwiffer
Did it work? How much coolant did you get out from the drain nipple?
Old 12-20-2011, 03:54 PM   #14
BLKFLSH
BLKFLSH's Avatar
I forgot to put a drain hose on it, when I opened it I got a good splash of coolant. Can't tell you exactly how much came out, but I would guess about a quart. Put it this way, a lot less will come out, when you remove the water pump, if you drain this first.
Old 01-05-2012, 08:08 AM   #15
student23
2005 Honda Accord
It definitely "worked". That's what it's there for. Quite a bit came out actually (much more than a quart). I wasn't flushing the system, just running the car multiple times with distilled water to "clean the system out", so I needed an engine block drain plug to get the coolant/water in the block out.
2005, 2007, accord, acura, block, bolt, civic, coolant, drain, engine, honda, picture, plug, radiator, tl
