> All Motor/ Naturally Aspirated
Old 11-29-2011, 12:22 PM   #1
cibao2ner
cibao2ner's Avatar
Default BUILT lSVTEC oil leak...from headgasket...
i have a fully built lsvtec...all new gaskets...arps torqued in 3 steps to 80ftlbs....
i have a medium oil leak from the corner of headgasket...near the vtec solenoid....but oil looks clean and its just in the front of the engine...new gsr headgasket...new vtec solenoid gasket...i went to street tune and had to stop early cause rad fan went out...
cibao2ner is offline   Reply With Quote
Old 11-29-2011, 08:21 PM   #2
ek3turbo
Default Re: BUILT lSVTEC oil leak...from headgasket...
maybe try the golden eagle HG?.. and see wat happens..
ek3turbo is offline   Reply With Quote
Old 11-29-2011, 08:37 PM   #3
mouab18c1
1997 Acura Integra
mouab18c1's Avatar
iTrader Rating: (3)
You sure it's the HG and not from Vtec solenoid, cam plug, or distributor?
Neptune RTP - HrTuning.com
www.Xenocron.com
95 GSR Partout http://hondamarketplace.com/showthread.php?t=3028136
mouab18c1 is offline   Reply With Quote
Old 11-29-2011, 08:48 PM   #4
Fink29
Fink29's Avatar
Send a message via AIM to Fink29
I would first re-torque the head and make sure you use some rtv on the cam seal above. Sometime after a few heat cycles you need to re-torque the arp studs.
Rocket Motorsports, RLZ Engineering, DD Tech Tuning, Endyn Roller Waves, Twm and much more !!!
Fink29 is offline   Reply With Quote
Old 11-29-2011, 09:18 PM   #5
mouab18c1
1997 Acura Integra
mouab18c1's Avatar
iTrader Rating: (3)
I have the same problem right now, I narrowed it down to the cam plug. GL
www.Xenocron.com
Old 11-29-2011, 09:33 PM   #6
TheShodan
TheShodan's Avatar
iTrader Rating: (1)
Send a message via AIM to TheShodan
Could easily be cam seal or Vtec solenoid gasket
“When you go into this sort of electronic war,.....The electronics do a given situation, and no matter who you put in the car, the electronics will do the work and not the driver. and I don’t think that is really what you want to have...”–Aryton Senna, ‘92
TheShodan is offline   Reply With Quote
Old 11-29-2011, 09:58 PM   #7
chingpo05
chingpo05's Avatar
it has been a prob for me for as long as ive been building these motors even with freshly decked heads and blocks. copper spray was my go to for the fix and since then every motor ive built havent had a leak
chingpo05 is offline   Reply With Quote
Old 11-29-2011, 10:15 PM   #8
acexxxoasis
1995 Honda Accord
You can also whipe up the oil clean it up then baby powder around where it was leaking and start the car drive it for a minute and it should reveal where your oil is escaping from...
acexxxoasis is offline   Reply With Quote
Old 11-30-2011, 08:08 AM   #9
Furyof4
Furyof4's Avatar
I always put a little hondabond on the oil drains for lsvtec's. If not they always seem to leak like you're describing. Double check the other possible sources though like others have mentioned.
Innovative MotorWorks
Question Everything, Worship Nothing, Think for Yourself.
Furyof4 is offline   Reply With Quote
Old 11-30-2011, 08:30 AM   #10
93egSLEEPER
1970 Chevrolet Classic
My Garage
93egSLEEPER's Avatar
Andy Racus
That leak I have come to know as the "vtec leak" I see just about every car with an LSV or that has had the head split from the block has that leak. I use honda bond around all the oil ports as an extra seal and have defeated it. The first rebuild I did I had the same problem.
Originally Posted by kevinm1981 View Post
10/10 that is a dope *** car. Props.
Selling my baby http://hondamarketplace.com/showthread.php?t=3010607 *1970 Chevy Chevelle 500whp SB355 www.speedfactoryracing.net
93egSLEEPER is offline   Reply With Quote
Old 11-30-2011, 09:44 AM   #11
cibao2ner
cibao2ner's Avatar
i used ultra grey around the oil returns on the head gasket.....and the cam seal is one of those 3 o-ring aftermarket ones that i also went over with ultra-grey...and everthing on the head side is clean...under cam seal and distributor and vtec solenoid...also head was resurface and so was the block...
i dont mind cleaning it up once in a while...i just dont wanna blow something...
if it can last till spring im ok with it so i can retorque the head...if i have to take of the head im gonna go with copper spray..
Old 11-30-2011, 12:16 PM   #12
per4mance
per4mance's Avatar
iTrader Rating: (1)
did you atleast install the plug into the bottom of the head? I know its a dumb question but you would be suprised how many people do not tap and plug the hole. I for one have never had an ls/vtec or b20/vtec leak anywhere when built. Sounds like a problem from the engine builder
Nothing
per4mance is offline   Reply With Quote
Old 11-30-2011, 03:55 PM   #13
93egSLEEPER
My Garage
Andy Racus
Since it hasn't been asked or put out there, what HG did you use?
Old 11-30-2011, 03:56 PM   #14
cibao2ner
cibao2ner's Avatar
i made that mistake once already...installe the plug without any sealant....this time i did it right...
compression was even on all 4 cyl..so it cant be a bad headgasket...also the oil is clean not milky...
95, cam, cap, civic, gasket, head, honda, leak, leaking, leaks, ls, lsvtec, oil, solenoid, vtec
