D16y7 intermittent misfire
Old 11-29-2011, 09:48 AM
hyperblu's Avatar
Default D16y7 intermittent misfire
So I was going to work the other day and almost to work then my check engine light started flashing and started misfiring really bad. I pulled 2 codes with my obd2 scanner and it was p1399 and p0320 I think. I finally got to work and started it and drove it on my lunch without any trouble and even drove it a couple more days. Well, it did it again. Same symptoms. If I let it sit, no problems for a while. Just wondering what everyone thinks it could be. It hasn't had a tune up since I got it, just replaced the wires with a good used set of ngk's. It only seems to do it when it is fully warmed up. Could this be the ignitor in the dizzy? I'm off tomorrow so I will look at it then, just want some advice on what to look for specifically. Thanks.
Old 11-29-2011, 09:52 AM
Former User's Avatar
Default Re: D16y7 intermittent misfire
P0320? Check again.
Old 11-29-2011, 09:55 AM
hyperblu's Avatar
Originally Posted by RonJ@HT
P0320? Check again.
The code went away the next day and no cel popped up the second time it happened. It may not have been 0320 but when i googled it it was two misfire codes... i think 0320 is the cat....
Old 11-29-2011, 09:59 AM
kyden's Avatar
i would go ahead and do a tune up anyway. when was the last time it was done? oem cap/rotor and ngk plugs.
Old 11-29-2011, 10:00 AM
When the problem happens again, pull the codes and post them. A tune up^ is a good idea though.
Old 11-29-2011, 10:05 AM
hyperblu's Avatar
Im fixing to go to work, so if it happens again, i'll pull them. Moneys kinda tight with christmas right around the corner, I just need this engine and trans to last till spring, so i'm not really looking to do more work than I have to, just need a few more months out of it.
Old 11-29-2011, 10:51 AM
hyperblu's Avatar
The only hidden code is p0302... No cel but that code is stored. Just got to work and had no issues yet
Old 11-29-2011, 10:52 AM
Check spark and fuel spray for cylinder 2. If those are fine, a compression test is next.
95civicproblems
11
07-23-2011 06:23 PM
dogbiscuit
06-11-2009 07:26 AM
Mires
07-03-2003 07:37 AM
badasssi
01-20-2003 10:30 PM
Damon B.
03-02-2002 08:58 PM
Quick Reply: D16y7 intermittent misfire
