ef rear disc brake swap
Old 11-23-2011, 05:19 PM
89civicstd's Avatar
Icon2 ef rear disc brake swap
need help
am planing on doing a rear disc brake conversion on my civic
but wont to see if i can use a 91 ex proportioning valve i also got the
ex setup for big brake
Old 11-23-2011, 05:39 PM
chris riz's Avatar
Default Re: ef rear disc brake swap
Check for the "4040" stamp on the prop valve
Old 11-23-2011, 07:41 PM
89civicstd's Avatar
I got both the 4040 and the 3540 but I wanna keep my booster and run the 1516 master clyinder
Old 11-24-2011, 01:28 AM
Clipsed's Avatar
need to find an EX mc if you want to keep your booster.
Old 11-24-2011, 08:34 AM
89civicstd's Avatar
Well I got two a 91 ex mc and 90 si mc so it don't matter if I use the 3540 valve
Old 11-24-2011, 08:47 AM
Clipsed's Avatar
you can use the 3540 if you don't want to install the 4040
Old 11-24-2011, 09:03 AM
apexi_rsx's Avatar
he can but will definitely go thru rear pads fast.
Old 11-24-2011, 10:19 AM
89civicstd's Avatar
Doesn't the 3540 valve shoot a bit less fluid then the 4040. Why will waste the rear pads faster
Old 11-24-2011, 11:14 AM
DCRB's Avatar
why would the 3540 wear pads faster? it's sending less pressure to the rears, so technically wouldn't the rears last longer? and the car would be more front biased?
Old 11-24-2011, 11:43 AM
89civicstd's Avatar
if I use the 4040 will it lock up my brakes
Old 11-24-2011, 04:50 PM
Clipsed's Avatar
Yes.
Old 11-24-2011, 08:18 PM
89civicstd's Avatar
So the best way to go is the 3540
Can I use my stock camber arm?
Old 11-24-2011, 10:03 PM
Clipsed's Avatar
You will only use the trailing arm itself, all the arms will need to be from your civic.
lonesomepride
Honda Civic (2001 - 2005)
09-18-2017 08:58 AM
kirkland08
14
03-17-2011 08:58 PM
Hondacivic90ed
04-24-2008 08:29 AM
coot_er
17
01-27-2007 11:22 AM
alterdcreations
09-20-2006 02:13 PM
Quick Reply: ef rear disc brake swap
