Fuel Pressure Regulator bad??
Old 11-23-2011, 11:42 AM
knuxx's Avatar
Default Fuel Pressure Regulator bad??
Hi guys.. a little question here..
can u tell me if my Fuel Pressure Regulator id bad??
i make that question because if the engine is running and i disconect the vaccum hose attached to it, nothings happen.. the engine still running and nothing change.. is it bad?
Old 11-23-2011, 01:28 PM
The Grumpiest
grumblemarc's Avatar
Default Re: Fuel Pressure Regulator bad??
Why are you messing with the FPR?
Old 11-24-2011, 08:16 PM
knuxx's Avatar
because i hav a very serious problem with my idle and i dont know what more to do... :S i have replaced EACV, FITV, TPS, my ecu is new, ECT, clean Throttle body, good PCV, no vaccum leaks and i still getting very very low idle speed and my car is eating a lot a lot!! of fuel.. i do a video about the idle, look it
http://www.youtube.com/watch?v=_2oSV...layer_embedded
Old 11-25-2011, 04:45 AM
The Grumpiest
Did you do any of the things suggested in this thread?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/civic-95-coupe-idle-deceleration-c-mpg-problems-pls-help-2997880/
Specifically "Check the timing with a timing light"? I don't see where you mentioned that you did that. Replacing random parts hoping to fix the issue is not smart and very expensive.
Old 11-25-2011, 05:25 AM
apexi_rsx's Avatar
why don't you adjust and turn your idle screw up on the T/B.
Old 11-25-2011, 05:37 AM
knuxx's Avatar
yes i do the timing, and the idle screw, if u loose it the idle dont go up, ..
Old 11-25-2011, 05:38 AM
The Grumpiest
Bleed all the air out of the cooling system.
Old 12-05-2011, 06:57 PM
knuxx's Avatar
i already do that, but my question is, why the low idle only happen when the engine warm up, if it cold and A/C is turn off it run very nice.. but when it gen warm the low idle appear
Old 12-06-2011, 03:35 AM
Retired Moderator
EsotericImage's Avatar
u sure you used a meter on the TPS sensor to properly calibrate it?
Old 12-19-2011, 04:05 PM
knuxx's Avatar
Yes!! i used a a multimeter, 0.5 throttle close and 4.8 WOT, it is ok..other thing i say adove is that my idle screw dont work, if you unscrew it nothing happen with my idle :S
Old 12-19-2011, 04:10 PM
Retired Moderator
maybe Ron will chime in and help out on this one.
digital sol
08-06-2007 05:10 PM
jetlude
07-07-2007 09:16 AM
saikouEF8
06-16-2006 05:47 PM
ActiveAero
11-13-2003 09:35 AM
s o h c
06-05-2003 07:49 PM
Quick Reply: Fuel Pressure Regulator bad??
