Rough idle problem! then dies after it warms up?
Old 11-22-2011, 08:58 PM
  #26
01oemTeggy's Avatar
Default Re: Rough idle problem! then dies after it warms up?
Originally Posted by kchungb17a
Wow! Good luck man... And Happy Thanksgiving.
BTW, where in CA are you?
thanks! and happy thanksgiving to everyone as well! located in 805 area
Originally Posted by mouab18c1
Correct all B series OEM injectors are 240 cc. The only differences between obd1 and obd2 are the injector clips.
Since you don't have a wideband I would check for fuel pressure as stated above when the problem usually occurs.
defs going too.
Old 11-23-2011, 04:53 AM
  #27
TheRealTegger's Avatar
This is the relevant excerpt from Acura Service News from February 2002:
Wrong Injectors Cause DTC P0172
If you have a ’98–01 Integra GS-R with DTC
P0172, check to see if the injectors have been
replaced recently. The current parts catalog lists
the wrong fuel injectors for GS-R models. Using
the wrong injectors will set DTC P0172. The
correct injector is P/N 06164-P2J-000.
Acura Service News and Honda Service News are monthly publications issued by American Honda for use by their dealers. If a problem or update isn't serious or major enough to warrant a TSB or recall, it goes in ASN or HSN.
Old 11-23-2011, 05:06 AM
  #28
95tegbuild's Avatar
If they were so rough that they cracked the intake manifold i would be very weary of any other work they did and check everything over for leaks and what not. Good luck man i hope it ends up being something easy for you!
Old 11-28-2011, 01:00 AM
  #29
01oemTeggy's Avatar
couldn't be better said as i'm doing this now. long process with shitty hrs and no money. By the way checked the fuel injectors work pristine, and are oem, and are the right p/n got the next two days off time for some diagnosing!
planning on -
vacuum leak check
new ground wires
check all fuses
buy new radiator cap
Old 12-13-2011, 08:22 PM
  #30
01oemTeggy's Avatar
*UPDATE*
replaced pcv valve and while i was at it i noticed this wasn't plugged in. and i can't find any where to plug it? anyone kno what this is? its combined with three other wires all electrical taped together. found it laying around unplugged under the im. all other problems are still persisting haven't had much time to try anything. Also when i turn off the car, sometimes smoke comes out the exhaust long after it had been turned off.
Old 12-15-2011, 11:49 PM
  #31
01oemTeggy's Avatar
TTT!
Old 12-17-2011, 03:23 AM
  #32
01oemTeggy's Avatar
up top!
Old 12-21-2011, 08:32 PM
  #33
01oemTeggy's Avatar
:UPDATE:
for those who have been keeping up with this thread to see if it'll help ya, it was a clogged cat. shop told me they had a test pipe installed but another isssue i have to deal with later with this shady shop.
Old 12-02-2018, 08:05 AM
  #34
Humberto Gamino's Avatar
Originally Posted by 01oemTeggy
:UPDATE:
Did this fix you're problem Im having the same issue with mine for about. Month
UK_Luder
07-24-2007 09:08 AM
j spec
06-06-2006 06:36 PM
MenaceL.A.671
02-20-2006 11:00 PM
H22A1CivicEG
03-30-2004 02:06 PM
PSU-TEG
01-28-2003 02:45 AM
Quick Reply: Rough idle problem! then dies after it warms up?
