Go Back   Honda-Tech > Community Forums > General Discussion and Debate
Old 11-15-2011, 08:45 PM   #1
Spoolinls
Spoolinls's Avatar
Default vw tranny on honda motor
looking to drop a honda motor in my sandrail. i know the b series rotate backwards for a vw, what do i need to make it work with the vw tranny or should i just put a s2000 motor in. what do you guys think
Spoolinls is offline   Reply With Quote
Old 11-15-2011, 08:53 PM   #2
xtrac1
rookn00b
xtrac1's Avatar
iTrader Rating: (2)
Default Re: vw tranny on honda motor
If an LSx fits, why not? Cheap hp and lots of it.
Lightly blown S2K (or k20) on E85 sounds nice.
Injector Dynamics = garbage. If you must:
2000cc injector part number = 0 280 158 821
1000cc injector part number = 0 280 158 040
xtrac1 is offline   Reply With Quote
Old 11-15-2011, 08:54 PM   #3
328FTW
328FTW's Avatar
use a honda transmission? Odds are you just need custom axles then. Even then if they are for the right track width just throw honda hubs to match on it with the original shafts
By the time you make adaption plates, custom clutch plate (or at least buy a new one that fits the vw spline and is the right diameter for the honda flywheel) then work out your throwout arm and bearing carrier it's easier to just do the axles. Get the end resplined or just get them made, whatever works
328FTW is offline   Reply With Quote
Old 11-15-2011, 08:55 PM   #4
slomofo
GDD Member
1991 GTR .
slomofo's Avatar
iTrader Rating: (1)
solbrothers xtrac1 George Knighton ILcrxsi1 uncle_ben
Send a message via ICQ to slomofo Send a message via AIM to slomofo Send a message via MSN to slomofo Send a message via Yahoo to slomofo Send a message via Skype™ to slomofo
Counterclockwise engines aren't going to work.
You need to find out what your transmission can support before you go jumping into this highly unlikely scenario because those VWs did not put down a lot of power from the factory and their transmissions might not be able to support the power you're looking to get out of them.
Also, google: Porsche G50
Also... why do you need a longitudal transmission anyhow? What's wrong with stock?
Lastly... if you really really really want a longitudal mounted Honda counterclockwise engine, then it's cheaper to get a corvair transmission because the corvair engine also spun counterclockwise. I actually dropped a Honda Accord engine into the back of a corvair a few months ago and it went in just fine.
Originally Posted by turbohatch96y7 View Post
I love a good creampie!
slomofo is offline   Reply With Quote
Old 11-15-2011, 09:08 PM   #5
boredumb
Can't be Tamed
2011 Lamborghini Reventon
boredumb's Avatar
Counterclockwise engine will work. Just need to run it upside down. My uncle did that on his and its never broken down.
boredumb is offline   Reply With Quote
Old 11-15-2011, 09:08 PM   #6
TRAY
2005 Subaru Legacy
TRAY's Avatar
Send a message via AIM to TRAY
there is a ton of honda powered sandrails and they are mostly using factory trans
I know the acura V6 is VERY popular for this
When we look at modern man, we have to face the fact that modern man suffers from a kind of poverty of the spirit We've learned to fly the air as birds, we've learned to swim the seas as fish, yet we haven't learned to walk the Earth as brothers and sisters
TRAY is offline   Reply With Quote
Old 11-15-2011, 09:14 PM   #7
xtrac1
rookn00b
xtrac1's Avatar
iTrader Rating: (2)
Yes, the Honda V-6 is very popular.
Old 11-15-2011, 09:15 PM   #8
Spoolinls
Spoolinls's Avatar
A honda motor will fit without having to refab it but if I go with a sbc ill have to refab it to fit I already have a built type 1 trans and axles jus need a motor
Old 11-15-2011, 09:28 PM   #9
slomofo
GDD Member
1991 GTR .
slomofo's Avatar
iTrader Rating: (1)
You need to figure out the proper way to say it. Upside down is not the correct jargon to use but everyone always says it that way
I'll explain why saying upside down makes you sound like a retard.
Imagine a wheel spinning clockwise.
Okay, I'm going to turn this image upside down. Brace yourself because this one's going to be a doozy...
Ready?
Prepare yourself now because bricks will definitely be shat.
POW MUTHUFUKKA! What direction is the wheel spinning now?
Wait a second.... is it just me or is it spinning in the same direction?
Old 11-15-2011, 09:32 PM   #10
boredumb
Can't be Tamed
boredumb's Avatar
It just looks like the same direction cause its going really fast.
It also makes it way easier to do Oil changes since the drain plug will be facing up towards you.
Old 11-15-2011, 09:59 PM   #11
slomofo
GDD Member
1991 GTR .
slomofo's Avatar
iTrader Rating: (1)
It started out as me trolling you, but now you're trying to troll me because you really have no clue how transmission flipping works.
Guess I'll explain...
The VW engine sits behind the transmission, so the transmission's bell housing is facing rearwards. Some people require a mid engine setup and need the engine in front of the transmission. Simply turning the transmission around isn't going to work because the wheels will then spin backwards, so they turn the transmission upside down and the wheels will subsequently turn forwards since the axles are coming directly out of the side of the transmission.
That's one way to get a VW transmission to have the bell housing facing forward. The other way is more in depth. The VW's ring gear only has teeth on one side, so if you flip it over, the teeth will be on the opposing side of the pinion and the transmission will then spin backwards, wel sort of. The wheels will be spinning counterclockwise while the input shaft and all the gears are still spinning in the same direction they always were. The only benefit to flipping the ring gear is that you can have a forward facing bell housing without having your transmission upside down.
Old 11-15-2011, 10:13 PM   #12
Spoolinls
Spoolinls's Avatar
how hard is it to flip the ring gear
Old 11-15-2011, 10:20 PM   #13
slomofo
GDD Member
1991 GTR .
slomofo's Avatar
iTrader Rating: (1)
Flipping the ring gear is easy, but I don't think you understand.
You flip the ring gear and you still need a clockwise turning engine to run it. The wheels will spin counterclockwise, but the input shaft still needs to spin clockwise.
If you want to run an F20, K-Series, J-Series, or other clockwise turning Honda engine, you can do a ring gear flip and run the VW transmission behind the engine, but it will not work with a counterclockwise spinning engine.
All these stories you hear that start off with my uncle, my brother, my friend, my cousin, my neighbor, my mechanic, my dad's friend, etc. and end with "is running a Honda engine with an upside down VW transmission... are all bullshit, every single one of those motherfukkers is a god damned liar. A lot of these people also have stories about how their brother in law's uncle's friend's neighbor's grandson put a Porsche 911 engine in the back of a beetle because that seems to be a popular fabricated story to throw out there as well.
Old 11-16-2011, 04:11 AM   #14
integra15
integra15's Avatar
Just do it and install the steering wheel and seats facing backwards. Problem solved.
integra15 is offline   Reply With Quote
Old 11-16-2011, 04:51 AM   #15
951parts
951parts's Avatar
you can build another crank shaft in your garage
or you could rip the mainshaft out of the VW trans, shove a honda b series one in there and then do w/e it was in your nonsensical mind to mount the that bell housing/transaxle on the b, probably a back yard redneck mounting plate
Garage Sale - Socal, K24, rear discs, turbo manifolds, ECU's CHEAP!!!!
http://hondamarketplace.com/showthread.php?t=3132824
951parts is offline   Reply With Quote
Old 11-16-2011, 06:35 AM   #16
TerribleToo
1993 Honda Civic
TerribleToo's Avatar
TerribleOne
Engine needs to run clockwise, its been done. In fact if I recall there is a big class of buggies that run this setup in the Netherlands. Clockwise b16 to a VW T2/T3 gearbox
Vids on youtube as well
TerribleToo is offline   Reply With Quote
Old 11-16-2011, 07:47 AM   #17
Spoolinls
Spoolinls's Avatar
Ok thanks for the help
Old 11-16-2011, 09:08 AM   #18
acmoc
acmoc's Avatar
https://www.facebook.com/profile.php?viewas=100000686899395&privacy_source=timeline_gear_menu
What bout all the VW guys saying Honda is crap
Originally Posted by xtrac1 View Post
I don't think I've ever had a poptart
Mint
acmoc is offline   Reply With Quote
Old 11-16-2011, 12:07 PM   #19
beeseries
beeseries's Avatar
How much do you want to spend?
http://kennedyenginc.com/default.aspx
I would go with a Twin Turbo LS7 with a mendeola or albins lol
07 Dirtymax 4x4 CCSB Cognito'd.
On a farm, or in the Desert.
beeseries is offline   Reply With Quote
Old 11-17-2011, 07:24 AM   #20
Spoolinls
Spoolinls's Avatar
[quote=beeseries;46365007]How much do you want to spend?
I would go with a Twin Turbo LS7 with a mendeola or albins lol[/QUOTE
i don mind spending money but a ls7 and mendeola is a little to much. would like to keep it within 2-3k
Old 11-17-2011, 09:31 AM   #21
Maverick
Team Purple
Maverick's Avatar
you still need a clockwise turning engine to run it. The wheels will spin counterclockwise\
Make the front the back and the back the front and you're all set Problem solved.
Legendary status.
Originally Posted by doctorake View Post
Do you eat anywhere sober Maverick?
Maverick is offline   Reply With Quote
Old 11-17-2011, 10:43 AM   #22
Gustav129
1981 Ford Mustang
Gustav129's Avatar
gustav129
There's two VW trans to use....
In a Chumpcar here...
VW Beetle Trans....
Saab 900's use the same style trans as the beetle for their front wheel drive...
The trans is in front of the engine, with the front of the engine at the firewall.
As for gears, you'd have to get custom gears, If you have a counter clockwise engine to spin the trans opposite of the direction it's supposed to (take the "engine behind" trans, and put it behind the engine) then you have four (or more) reverse gears, and one slow forward gear. But you would be putting pressure on the wrong side of gears and wearing them out faster.
My best bet would be use the Beetle trans (I saw many at the local Pull-N-Save last time I was there) and have the Honda Engine (same rotation as the 1600 Boxer engine) behind the trans for weight distribution.
#129
1981 Mustang - 129cp
1987 CRX Si - 129gs
Gustav129 is offline   Reply With Quote
Old 11-17-2011, 11:20 AM   #23
Spoolinls
Spoolinls's Avatar
i already have a vw type 1 trans just need a motor for it
Old 11-17-2011, 12:58 PM   #24
mouab18c1
1997 Acura Integra
mouab18c1's Avatar
iTrader Rating: (5)
lulz
Neptune RTP - HrTuning.com
www.Xenocron.com
95 GSR Partout http://hondamarketplace.com/showthread.php?t=3028136
mouab18c1 is offline   Reply With Quote
Old 11-17-2011, 01:35 PM   #25
Gustav129
1981 Ford Mustang
Gustav129's Avatar
gustav129
I'm not a VW guy, so I don't know what a "Type 1 trans" is I'm assuming that's the one in the Beetle?
If so and you have the engine behind (furthest to the rear) the trans, and it rotates the same direction as the original VW engine, then I doubt you will have problems...
#129
1987 CRX Si - 129gs
900, engine, fit, flip, gear, hard, honda, motor, pull, put, ring, run, saab, sandrail, trans, type, vw
