Go Back   Honda-Tech > Honda and Acura Technical Forums > Forced Induction
Old 11-15-2011, 06:17 PM   #1
dE.fUsEd
1993 Honda Civic
dE.fUsEd's Avatar
Send a message via ICQ to dE.fUsEd Send a message via AIM to dE.fUsEd
Default Catch can setup...Is this right? (pic)
I have 2 catch cans, the valve cover holes go in to the catch cans, and the catch cans drain back to the block plugs.
Is that right?
LostPower.com
dE.fUsEd is offline   Reply With Quote
Old 11-15-2011, 06:24 PM   #2
Freshdot
Default Re: Catch can setup...Is this right? (pic)
i'm not a fan of draining back to block because of the condensation that occurs within the can..some people are into it though.
Freshdot is offline   Reply With Quote
Old 11-15-2011, 06:28 PM   #3
dE.fUsEd
1993 Honda Civic
dE.fUsEd's Avatar
I just have straight lines running to and from, the can is baffled and filtered.
Do I need any sort of check valves or anything?
Also, I wasn't sure what to do with my smog canister, but we have emissions here so I just ran the hose to the intake manifold. That ok?
LostPower.com
Old 11-15-2011, 07:02 PM   #4
DelSolMarine
DelSolMarine's Avatar
That setup is good...
I have had drain back on my car for over 3 years and daily drive it... Tony Palo has drain backs on his 1000+ whp integra running 8's and hasnt had problems... I think the pros clearly outweigh the cons.
84mm 6265 Del Sol 635whp w/ c16 @ 28psi 8600rpm (ran out of fuel)
435whp w/ pump gas @ 13psi (wg) 9400rpm
S&M Auto Built & Matt Shue Tuned
DelSolMarine is offline   Reply With Quote
Old 11-16-2011, 06:15 AM   #5
dE.fUsEd
1993 Honda Civic
dE.fUsEd's Avatar
Thanks! This will be my first turbo build. Actually bought the motor from someone here.
Hoping it is what I was told it is.
LostPower.com
Old 11-16-2011, 06:40 AM   #6
Freshdot
ever drain a filtered catch can? it's not pretty and I wouldn't want that going back into my engine, i'd rather keep adding oil when it gets alittle low.
side note: i'm pretty sure tony palo is changing his oil after every track day.
Old 11-16-2011, 11:45 AM   #7
mechanix619
mechanix619's Avatar
Having a drain back on a race car is drastically different than having one on a daily driver. When racing the oil gets changed after after every event, possibly even between runs.
Depending on how I drive the car my blow-by ranges from decent-to-nasty. I definitely don't want the nasty stuff back into the engine.
mechanix619 is offline   Reply With Quote
Old 11-16-2011, 02:47 PM   #8
Freshdot
right and are you sure he runs a drain back and not a slash cut to the exhaust?
something about letting milkshake back into my motor doesn't sit right with me.
you are better off using those plugs on the back of the block to relieve more pressure as there is way more crankcase pressure in well, the crankcase.
Old 11-16-2011, 05:20 PM   #9
EsotericImage
RIP Honda Tuning Magazine
1999 Honda Civic
EsotericImage's Avatar
iTrader Rating: (8)
Originally Posted by Artikgrau325is
People try so hard to be unique, they lose their sense of style
http://www.hondatuningmagazine.com/e...013_road_rage/
http://www.hondatuningmagazine.com/t...ode_checklist/
EsotericImage is offline   Reply With Quote
Old 11-17-2011, 01:18 AM   #10
m3tech95
m3tech95's Avatar
m3tech95@facebook.com
x2^
*New Best Time 11.94 @ 114mph 0.00 Reaction Time 1.7 60ft* 100% bone stock B16a2 Motor + 50 Trim Turbo + 15lbs http://www.youtube.com/watch?v=1CKTuCG7JuQ 7th Gear Racing/Morris Tuned/I drive
m3tech95 is offline   Reply With Quote
Old 11-17-2011, 10:40 AM   #11
ekcoupeh22
ekcoupeh22's Avatar
iTrader Rating: (2)
why are you running 2 catch cans? if its a mild build you dont need 4 lines coming off the valve cover just 2 and 2 off the block ditch the whole drain back thing. imho its stupid. i would spend the money and get a T1 catch can and call it a day!
01 PY ITR drag car in progress forward facing 42r next year
ekcoupeh22 is offline   Reply With Quote
Old 11-17-2011, 01:13 PM   #12
dE.fUsEd
1993 Honda Civic
dE.fUsEd's Avatar
It's a benson sleeved gsr block, pauter rods, cp 9.1 pistons, fully ported b16 head, skunk2 stage 1 cams, blah blah.
Plan to be around 500hp with a gt35r. Motor made 690 on race fuel with the previous owner.
LostPower.com
Old 11-17-2011, 01:32 PM   #13
ekcoupeh22
ekcoupeh22's Avatar
iTrader Rating: (2)
Yeah ok it's not a mild build lol I would just do a T1 catch can with the 4 on the valve cover and the 2 to the block and be done! Same setup I just picked up!
Old 11-17-2011, 02:11 PM   #14
dE.fUsEd
1993 Honda Civic
dE.fUsEd's Avatar
Really didn't feel like relocating my battery.
I have drain valves for these cans. I may just use them for awhile and see what kind of blow-by I get. Would probably end up having to get another catch can though for the block or just T'ing my valve cover lines.. lol
Appreciate all the info!
LostPower.com
Old 11-17-2011, 02:13 PM   #15
dE.fUsEd
1993 Honda Civic
dE.fUsEd's Avatar
I will post a pic tonight. Car goes to in to get the motor tested and a quick N/A tune tomorrow. Have to wait a couple weeks for the rest of the turbo setup.
LostPower.com
97, back, block, catch, civic, drain, draining, forced, good, honda, hondatech, induction, oil, set, setup
