Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Prelude
Old 11-09-2011, 03:13 PM   #1
PreludeMatt
Default Creaking sound while turning steering wheel
Hey guys, I've got a creaking sound coming from the front end somewhere when I turn the steering wheel. When the road is wet and it's raining it doesn't seem to do it (or it's significantly quieter). It also doesn't seem to do it when the car is jacked up and the wheels are off the ground.
Has anyone had problems liek this before? I'll have time this weekend to investigate, but just wondering if anyone had an idea of where I should start or what might be causing it.. Thanks
PreludeMatt is offline   Reply With Quote
Old 11-09-2011, 04:04 PM   #2
bigblue7t6
2001 Honda Prelude
Default Re: Creaking sound while turning steering wheel
Hmmm, creaking sound is hard to place, are you sure it isn't the power steering pump whining? Does the sound change with the rpms as you rev the engine at a stand still and turn the wheels? For it not to do it while jacked up or not as bad when the roads are wet sounds like the ailment is load sensitive, just a wild guess though. Good luck
bigblue7t6 is offline   Reply With Quote
Old 11-09-2011, 05:28 PM   #3
PreludeMatt
yeah it's def not the pump whining or belt slipping.
Old 11-09-2011, 09:15 PM   #4
1funryd
1funryd's Avatar
Its your lower ball joints. Listen to which side its coming from and that will be the side to fix.
Project Manager for the new Aftermarket for the 3rd gen Prelude(88-91) www.1funryd.com
Email: 1funryd@comcast.net
Ksport & Cometic Dealer.
1funryd is offline   Reply With Quote
Old 11-09-2011, 11:45 PM   #5
1grex
LBJs
'86 CRX Si 16.51 @81 DD since '94 RIP 327K
'90 Prelude 2.0 Si 16.32 @83 the new DD 7/11 back from the dead
'95 Integra LS sportsman all motor coming 201X
1grex is offline   Reply With Quote
Old 11-10-2011, 03:21 AM   #6
Hawkze_2.3
Hawkze_2.3's Avatar
Yep, probably lower ball joints. They must support a load and rotate frequently, so they can go bad faster than other stuff...
'95 Prelude--intake, windshield washer lights, rear body kit, carbon fiber windows. '86 Mazda RX7--Chevy & Borg-Warner powered. '99 Honda CRV--Jurassic Park tour vehicle. '98 Chevy Lumina--what is that thing?
Hawkze_2.3 is offline   Reply With Quote
Old 11-10-2011, 04:19 AM   #7
BergRacing21
1992 Honda Prelude
BergRacing21's Avatar
Bryan Bergesen bryberg19 bberg21 bberg21
I think i have a similiar problem lol i get a loud creaking noise only when i turn it to the left. But if it's cold, or rainy you never hear it. If it's hot it sounds like hell. Guess i found my problem....LBJ's
Bryan/Berg Racing/WOLFEBUILT/Triangle, VA
T/S Prelude F22A4 Turbo, doing it for the single cams in a heavy *** car
SHE'S ALIVE! as of 8/5/13 F/H Series Enthusiast and Firm Believer of the SOHC!
BergRacing21 is offline   Reply With Quote
Old 11-12-2011, 09:33 AM   #8
PreludeMatt
Thanks guys, i'll give that a shot. It was actually in the back of my mind. I'll report back
Old 11-14-2011, 05:15 AM   #9
H22a1Prelude
1994 Honda Prelude
Thanks for keeping us up to date. I developed the same issue recently after lowering my car this spring. I'm pretty sure it's my drivers side front LBJ, but confirmation would be leet.
~Peace
H22a1Prelude is offline   Reply With Quote
Old 11-14-2011, 05:41 PM   #10
BergRacing21
1992 Honda Prelude
~Peace
haha same here dude, it sounds awful when i turn just bought me some today...will be replacing them wednesday ill keep you guys posted too
Old 11-20-2011, 06:57 AM   #11
BergRacing21
1992 Honda Prelude
so like i said i'd keep you posted....so i got my whole spindle off to replace the LBJ's and i found out my wheel bearings were shot. So i replaced those while i was at it, and SINCE i had to do all that work i went ahead and bought some ARP extended lug studs too lol But after all that putting all that stuff back together i noticed on my driver side my sway bar end link was completely torn....hell it didn't even have any bushings on the bottom. So i went ahead and bought Polyurethane bushings for it...and now no more noise. So not exactly sure what it was from by my guess is that end link rubbing metal to metal. But am glad i replaced all that stuff it was much needed. I think those wheel bearings were the factory ones still had Nissin printed on it.
Old 03-06-2013, 02:25 PM   #12
Ninefootsix
I just wanted to say thank you to everyone who shared their knowledge on this particular issue. My 1990 Civic was suddenly creaking so loudly that it was scary and embarrassing. After doing a little research on the forums here, I replaced both the upper and lower ball joints and now it is completely silent when I steer. Thanks!
Ninefootsix is offline   Reply With Quote
Old 03-06-2013, 07:12 PM   #13
1funryd
1funryd's Avatar
Your welcome.
car, civic, creaking, creaks, crx, forum, honda, noise, sound, sqeaking, squeaking, steering, turing, turn, turning, turnong, wheel
Similar Threads
Help diagnosing a creaking sound (video inside) geoken Acura RSX DC5 & Honda Civic EP3 3 05-12-2014 05:14 AM
99 Civic steering creak zipthehuh Honda Civic/Del Sol (1992 - 2000) 5 10-01-2013 11:32 AM
suspension squeaking? YuckyCorpse Suspension & Brakes 11 01-11-2013 06:24 AM
creaking sound on left and right turn on civic Cameron k. Honda Civic/Del Sol (1992 - 2000) 31 10-21-2012 01:19 PM
96 Accord Creaking Sound from driver front side accord96lx Honda Accord (1990 - 2002) 9 09-22-2012 01:53 PM
