Go Back   Honda-Tech > Honda and Acura Technical Forums > All Motor/ Naturally Aspirated
Old 10-29-2011, 01:22 PM   #1
nelson9994
Default resurface head
okay guys I have a resurfaced head and block but I have taken the head off about 4 times (and torqued down) and put about 30 miles at the most on the motor. I'm about to put a new HG because the one in there is leaking. Do you guys think I will need to resurface the head or should I be good?
nelson9994 is offline   Reply With Quote
Old 10-29-2011, 02:51 PM   #2
N/A
Purpose Built
1992 Honda Civic
N/A's Avatar
Default Re: resurface head
Fail
My All Motor EH
13.9@98- Stock B18c, AEBS IM, RMF Narrow, Stock Cat/Catback, Stock ECU.
???@??- Stock B18c, PerX IM, RMF Narrow, Spoon N1 , Tuned on Neptune
N/A is offline   Reply With Quote
Old 10-29-2011, 06:36 PM   #3
mouab18c1
1997 Acura Integra
mouab18c1's Avatar
iTrader Rating: (5)
No need to resurface the head.
Neptune RTP - HrTuning.com
www.Xenocron.com
95 GSR Partout http://hondamarketplace.com/showthread.php?t=3028136
mouab18c1 is offline   Reply With Quote
Old 10-29-2011, 07:44 PM   #4
PyroProblem
1998 Honda Civic
My Garage
Facebook = too much drama and a waste of time
If you blew 4 headgaskets in the last 30 miles, I think you should at least have it checked. Something obviously isn't right...
B16B powered 98 Civic hatch. 2.1L build on hold again...
LS2 powered 07 Trailblazer SS. 400 hp grocery getter...
PyroProblem is offline   Reply With Quote
Old 10-30-2011, 10:09 AM   #5
nelson9994
I didnt blow 4 HG.... heres the story
i did a 1 layer first time then cr was goonna be at like 12:8 so i took it out and did the other 2 layers
then i said f it took it off again and put a new one in
i put it on upside down so it was leaking alot
then i took a used one i had and put it in this one looked ok but it had hella miles
and is leaking too
oil (alot)
so i ordered a brand new one this time
Old 10-30-2011, 10:27 AM   #6
TheShodan
TheShodan's Avatar
iTrader Rating: (6)
Send a message via AIM to TheShodan Send a message via Yahoo to TheShodan
and is leaking too
oil (alot)
Wow. Unfortunately that seems as though there was lot of effort that was rather wasted
“Don't let the opinions of the average man sway you. Dream, and he thinks you're crazy. Succeed, and he thinks you're lucky. Acquire wealth, and he thinks you're greedy. Pay no attention. He simply doesn't understand.” -Robert G. Allen
TheShodan is offline   Reply With Quote
Old 10-30-2011, 11:21 AM   #7
mouab18c1
1997 Acura Integra
mouab18c1's Avatar
iTrader Rating: (5)
Aka NOOB
www.Xenocron.com
Old 10-30-2011, 12:54 PM   #8
PyroProblem
1998 Honda Civic
My Garage
Practice makes perfect!
If the head and block have been milled, make sure your dowel pins aren't keeping those corners of the head from seating all the way (can cause oil leaks)...
Check them to see if they need milled down too...
Old 10-30-2011, 06:44 PM   #9
nelson9994
im going to mill them down a bit anyways. my question is do you guys think the head needs to be resurfaced or should i be good
Old 10-30-2011, 07:04 PM   #10
h2.4
h2.4's Avatar
put a precision straightedge on it and see what feeler gauges can go under it if any. I think factory manual says .002" is max warpage. but if there is any warpage, I just get it decked anyways.
h2.4 is online now   Reply With Quote
Old 11-02-2011, 07:57 PM   #11
nelson9994
I dont have a straightedge or the money to buy it right now... I will eventually check it when I get the money...
BTW... how do heads lose their straightness??? is it once is torqued down, or if it over heats or the miles or what.... because even though I am not sure... after 40 miles it doesn't sound like alot of miles for it to need a resurfacing or does it because it has been torqued 4 times or what?
2005, acura, block, body, excessively, head, honda, milled, paint, resurface, resurfaced, resurfance, send, surface, tl
