Shift lock has to be realeased manually & no brake lights
Old 10-24-2011, 01:57 PM
l Anito's Avatar
Icon2 Shift lock has to be realeased manually & no brake lights
Hey y'all
My 2000 crv will not shift out of park unless I manually release it via the key hole in the steering console. The brake lights are also out. I replaced the brake light switch and the throttle position sensor.
Does anybody know if a bad shiftlock solenoid would disable your brake lights?
Any suggestions to continue troubleshooting?
Old 10-24-2011, 04:00 PM
Project Phoenix's Avatar
Default Re: Shift lock has to be realeased manually & no brake lights
Id wager a broken circuit in the brakes over an additional sytem. Check for continuity at the brake switch and chase that circuit 1st. Typically brake lights tend to be wired independently to minimize unrelated failure
Old 12-21-2011, 09:43 AM
eeandersen's Avatar
What was your resolution, l Anito? My '04 Accord does exactly the same thing???
(Doesn't mean it's the same solution, but it's a start)
Old 12-21-2011, 10:46 AM
DO IT ON ALL FOURS
OneBadTurboCRV's Avatar
Most likely the Brake Light Switch is bad or something to do with it.
Suspension & Brakes
06-20-2013 02:57 PM
ihonda
21
05-31-2012 09:53 AM
keywest407
02-14-2012 11:29 AM
musclehead954
02-27-2008 10:28 AM
Project JDM CRX
02-07-2007 05:00 PM
Quick Reply: Shift lock has to be realeased manually & no brake lights
