Old 10-21-2011, 09:22 AM   #1
Aaron Cayabyab
Aaron Cayabyab's Avatar
http://www.facebook.com/aaron.cayabyab.3
Default Alternator sp sensor fuse keeps blowing 7.5Fuse (Honda Civic LX 98)
My honda civic lx 98 keeps dying and alternator fuse (7.5) keeps blowing nothing else blows besides that one fuse what im thinking is a short (but where should i look) or a new Fuse Box?Any input will be helpful!
1 Tip:Check Engine Light Is On
2 Tip:Lights Flicking Shit Dying Like The Radio
Aaron Cayabyab is offline   Reply With Quote
Old 10-21-2011, 10:35 AM   #2
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
Default Re: Alternator sp sensor fuse keeps blowing 7.5Fuse (Honda Civic LX 98)
Click on the fuse 15 TSB in my signature.
Don't guess, troubleshoot.
Old 10-23-2011, 10:27 PM   #3
Aaron Cayabyab
Before i do this i had a short the other day when installing my amp and burnt the wires (remote wire that connects to amp-cigarette lighter) but all the other fuses was good and in fact the fuse didn't blow out it self did i damage the Fuse Box or should i still follow the direction about fuse 15?
Buy a new fuse box?
Old 10-24-2011, 12:13 PM   #4
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
Check, tape, and cover the wires near the C115 connector as detailed in the TSB.
Old 10-24-2011, 02:04 PM   #5
Aaron Cayabyab
So the short i had couldn't do anything with the fusebox being broken? & Ill check the C115 Connector ASAP
Old 10-24-2011, 03:14 PM   #6
motegicivic
Buy a new fuse box?
Whoa, how did you wire the amp???
Did you go the battery direct?
Did you fuse the power wire about 16 inches from the battery?
motegicivic is offline   Reply With Quote
Old 10-24-2011, 03:37 PM   #7
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
Access the C115 connector and wires from below the car.
Old 10-25-2011, 01:34 AM   #8
Aaron Cayabyab
Nope i had a wiring kit everything was installed fine until i got a new sub and the remote wire kept blowing out my fuses!
Old 10-25-2011, 01:35 AM   #9
Aaron Cayabyab
I did this today and seems to work now wired up all the wires and new fuse!
Old 10-25-2011, 04:34 AM   #10
motegicivic
When you looked at the wires, were any broken or insulation torn?
Old 10-25-2011, 12:28 PM   #11
Aaron Cayabyab
Nope! the electrical tape was just worn out so i took it off and applied new one
Old 04-13-2014, 11:06 AM   #12
Dizzle69
Dizzle69 is offline   Reply With Quote
Old 04-13-2014, 11:08 AM   #13
Dizzle69
Just had same problem and it was the down stream 02 sensor plug to the car hitting body had split wire shorting out
2008, 75, 98, 98hondacivicalternatoroutput, 99, accord, alternator, blowing, blows, civic, cranking, fuse, honda, sensor, speed
Similar Threads
Alternator Fuse keeps blowing 97 EX coupe RedneckRicer Honda Civic/Del Sol (1992 - 2000) 20 04-09-2014 08:19 PM
BrakeLights/Horn Fuse (15) keeps blowing 98 Civic Aaron Cayabyab Honda Civic/Del Sol (1992 - 2000) 6 06-24-2013 06:25 PM
Fuse #24 keeps blowing PGM FI? ThatOne02Accord Honda Civic/Del Sol (1992 - 2000) 6 01-24-2013 02:50 PM
94 Accord Interior Lights Fuse Blowing BSmoov83 Honda Accord (1990 - 2002) 0 10-06-2012 12:00 PM
no. 15 fuse keeps blowing mtownsi Honda Civic/Del Sol (1992 - 2000) 1 09-23-2012 03:48 PM
