Old 10-19-2011, 10:20 PM   #1
Eddy562
http://www.facebook.com/Eddy562 Eddy562
Default OBD2 port not working
I put a b16a jdm engine into my 97 civic ex. I want to get it bar'dm but my obd port isn't working. Can it be that that I have a jdm ecu? (p2t).
That is the only thing holding me back....
any help is appreciated! ( and yes i am a noob, trying to learn!)
Eddy562 is offline   Reply With Quote
Old 10-20-2011, 06:15 AM   #2
b16a2ek
b16a2ek's Avatar
Default Re: OBD2 port not working
what year is the b16? i have a b16 from the 2000 si and am running a jdm p2t with no problems but i did need a jumper harness to go from obd2a to obd2b due to the wiring harness for the car being different
b16a2ek is offline   Reply With Quote
Old 10-20-2011, 06:18 AM   #3
grumblemarc
The Grumpiest
1996 Honda Civic
grumblemarc's Avatar
iTrader Rating: (4)
Send a message via AIM to grumblemarc Send a message via Yahoo to grumblemarc Send a message via Skype™ to grumblemarc
Originally Posted by Eddy562 View Post
...a b16a jdm engine...
This is your problem.
FAQs!--How to Turbocharge your Civic--Want a faster Civic?--DIYs
Originally Posted by wantboost View Post
I wish more parents would beat their children, then maybe most of them wouldn't be total spoiled, self absorbed *********.
grumblemarc is offline   Reply With Quote
Old 10-20-2011, 07:05 AM   #4
apexi_rsx
Send a message via AIM to apexi_rsx
I have a jdm ecu? (p2t).... this is the problem that ecu dont support the diagnostics port
06 Rsx Type S I/H/E ...14.0@101
97 civic 4dr turbo
apexi_rsx is offline   Reply With Quote
Old 10-20-2011, 01:53 PM   #5
Kista20
Kista20's Avatar
I'd say you hit the nail right on the head there. You will need to run a usdm ecu.
Originally Posted by Knightsport View Post
I've never wanted so painfully with every fiber of my being to blugeon someone to death with a big bag of rubber ******.
Kista20 is offline   Reply With Quote
Old 10-20-2011, 10:14 PM   #6
Eddy562
the engine is from 99/2000 si
how much was the harness and what kind?
Old 10-20-2011, 10:15 PM   #7
Eddy562
Will my d16 ecu work on the b16? it is a usdm p2p?
Thanks again
Old 10-20-2011, 10:24 PM   #8
Eddy562
Old 10-21-2011, 04:00 AM   #9
grumblemarc
The Grumpiest
1996 Honda Civic
iTrader Rating: (4)
Nope. Did you not research this before you did the swap?
Old 10-21-2011, 07:20 AM   #10
dpetro1
dpetro1's Avatar
b16civiccx
Send a message via AIM to dpetro1
The car should run. Just not properly. Probably won't pass BAR that way
dpetro1 is offline   Reply With Quote
Old 10-21-2011, 11:28 PM   #11
Eddy562
So should I try and get the ecu of the b16a2? what would be the difference?
Old 10-21-2011, 11:29 PM   #12
Eddy562
What do you recommend for me to be able to pass?
Thanks
Old 10-22-2011, 06:13 AM   #13
apexi_rsx
get a usdm b16 ecu from a 99-00 si or a b16 del sol
97 civic 4dr turbo
Old 10-22-2011, 06:51 AM   #14
Eddy562
Alright, just out of curiosity, how would it change by switching ecu's, performance wise, should I still use the jdm ecu after I get everything bar'd?
Old 10-22-2011, 07:03 AM   #15
apexi_rsx
switching ecu's will not do much both usdm b16 makes similar power to the jdm b16. the jdm ecu redline is 8200 vs usdm 8000 and vtec engagement for the jdm is 5800 and usdm is 5600. just little ecu tweaks are the differance. the jdm motor just has a slight bump in compression over the usdm b16. 10:6 vs 10:2
97 civic 4dr turbo
Old 10-22-2011, 07:20 AM   #16
jayWknight
iTrader Rating: (3)
Jdm ecus do not communicate with usdm scan tools that is the reason behind your issue. Also since you are trying to bar your car, try to find a 96-97 p30 from a 96-97 del sol dohc vtec. The bar techs wont take kindly to jumper harnesses and the wrong ecu.
My for Sale thread: http://www.hondamarketplace.com/show....php?t=2667830
jayWknight is offline   Reply With Quote
Old 10-22-2011, 03:47 PM   #17
Eddy562
Thanks everybody! I will try to buy everything on my next check and let you guys know how it went
2002, 96, accord, civic, connector, honda, isnt, lx, obd, obd2, odb, p2t, port, responding, working
