Valve spring tool
Old 10-12-2011, 08:44 PM
ill fast's Avatar
Default Valve spring tool
What valve spring removing tool do you guys recommend for removing valve springs when the head is still bolted to the block
Old 10-12-2011, 09:22 PM
cibao2ner's Avatar
Default Re: Valve spring tool
http://cgi.ebay.com/ebaymotors/Valve...ht_3117wt_1165
get that...
Old 10-12-2011, 09:57 PM
nus_dogg's Avatar
Originally Posted by cibao2ner
Do you have that tool? How easy is it to use with head still on the block?
Old 10-12-2011, 10:03 PM
cibao2ner's Avatar
yea i have the bluepoint version...for u to use it with the head still on the block ur gonna need a leakdown tester..and crank up the air pressure to like 150psi so the valves dont drop..
Old 10-13-2011, 04:37 AM
PyroProblem's Avatar
Or you can put some soft nylon rope down the spark plug hole and rotate the piston up to TDC.
The nylon rope will keep the valves closed if you don't want to buy a leakdown tester just for this one job.
Old 10-13-2011, 06:26 AM
GagnarTheUnruly's Avatar
http://www.euroexportinc.com/store/t...ing-tools.html
Old 10-13-2011, 12:03 PM
ill fast's Avatar
Thanks for the recommendations. Just wondering how easy is it to work wit the eBay one
Old 10-13-2011, 12:15 PM
Krut's Avatar
Originally Posted by GagnarTheUnruly
This one is awesome. I wouldn't get anything else.
Old 10-13-2011, 12:45 PM
m_shake's Avatar
Ahhh beat me to it
Old 10-14-2011, 07:36 AM
h2.4's Avatar
no to all of those above. I used the first one for a long time. Pita. Use compressed air as you would with the above tools, to anybody that hasnt used the tool I'm linking, You're gonna save waaaaay more time using the one in this link. Usually takesabout 5 min. per cylinder once cams and stuff is outta way. 20 mins for all four cylinders. Might take you a little while to figure out how to use it properly, but no joke, 20 minutes, 4 valves per cylinder.http://buy1.snapon.com/catalog/item....re&dir=catalog
Old 10-14-2011, 08:18 PM
nus_dogg's Avatar
Oh ok. I have Euro Export valve spring compressor tool that makes life's 10x easier. Thats the tool I used to do my sk2 pro valvetrain.
Old 11-23-2011, 05:11 PM
iwannarace's Avatar
Shinanigans! I've been trying to use the lisle version of this tool which is basically the same thing... I'm not a small guy and compresing the spring enough for the keepers to sit has been frikn impossible... I will now be looking for a different method unless you can teach me how to use it "properly".
Old 11-23-2011, 05:16 PM
I think you're supposed to hit it with a hammer. Are you doing that, or trying to press it with your body weight?
Old 11-23-2011, 05:37 PM
Fink29's Avatar
I use the one in the first link and I like it. Once you set it up you can take off each valve without taking the tool off for each cylinder.
Old 11-23-2011, 05:42 PM
iwannarace's Avatar
It's my understanding you hit it with a hammer to remove the valvesprings, which I've done. i'm trying to reinstall now and using body weight which is frikn impossible... i don't want to buy another tool but i guess i may have to.
Old 11-23-2011, 05:46 PM
Fink29's Avatar
The euro export version looks to be a little easier to use.
Old 11-23-2011, 06:00 PM
iwannarace's Avatar
Who wants to loan or sell me one?
Old 11-23-2011, 06:03 PM
BiggieBert's Avatar
I personally like this tool, worked very well for me.
Old 11-23-2011, 06:05 PM
Fink29's Avatar
If I wasnt on the other side of the usa I would def let you borrow mines. Someone step up and help a fellow member out.
Old 11-23-2011, 06:10 PM
h2.4's Avatar
You just have to make sure it is squared up when you press down on it. Also push it down slowly, just till you hear the keepers "click" into place. If you push past that point, they won't set in. so just push firmly and slowly till they "click" then let up and should both be set. I would never use anything else. way too slow, attach tool, screw down, fiddle with keepers, lose mind, repeat. f that.
Old 11-23-2011, 06:16 PM
crxsirg's Avatar
I have the one in the Ebay link and it worked great. Also, you don't have to put compressed air in the cylinders. With each cylinder at TDC the valves only drop about a 1/4". As long as you make sure each cylinder is at TDC for the given valve stems you're replacing you'll be fine (this is the way I did it and I had no issues).
Old 11-23-2011, 06:51 PM
iwannarace's Avatar
I must just be a weak ***** and can't push it down enough... any one wanna sell me one of their used compressors?
Old 11-23-2011, 07:43 PM
DDTECH's Avatar
Bought the tool listed, both infact. I use them on the cars i work on.. Both ways work.
Bought one from matco and snapon..
Old 11-24-2011, 07:48 PM
JustOneOrTwoPosts's Avatar
I've used this tool on my mr2 and it was super fast and easy. I think the website has video's of how it works too. http://www.toyotool.com/
Old 11-24-2011, 08:18 PM
ill fast's Avatar
In the end I ended up making my tool similar to that eBay one
Quick Reply: Valve spring tool
