Thought you guys might like this - offenhauser 4 cyl 16 valves twin cam
Old 10-11-2011, 03:37 PM
vtec8200's Avatar
Default Thought you guys might like this - offenhauser 4 cyl 16 valves twin cam
Offenhauser was a company that built 4 cylinders DOHC 16 valves, 4 per cylinder from 1930 until the 1980s. These engines were known as "Offy" and were built upon the principle of a 1913 peugeot's race car engine.
" In 1930, a four-cylinder 151 cu in (2.47 l) Offy/ engine installed in a race car set a new international land speed record of 144.895 mph (233.186 km/h). Miller developed this engine into a twin overhead cam, four cylinder, four valve per cylinder 220 cu in (3.6 l) (3.6 L) racing engine. This would be used in midgets and sprints into the 1960s, with a choice of carburetor or Hilborn fuel injection"
"One of the keys to the Offenhauser engine's success was power. A 251.92 cubic inch (4,128.29 cm³) twin-cam four-cylinder racing Offy with a 15:1 compression ratio and a 4.28125-by-4.375-inch (108.744 × 111.1 mm) bore and stroke, could produce 420 hp (310 kW) at 6,600 rpm (1.77 hp per cubic inch (81 kW/L). Other variants of the engine produced up to 3 hp per cubic inch (137 kW/L). Another reason for the engine's success was reliability; unit construction (no separate cylinder head) meant the engine was not vulnerable to head gasket or cylinder stud problems and allowed for higher cylinder pressures."
"Before turbo boost limits, over 1,000 bhp (750 kW) could be attained using around 120 in Hg (44.3 psi (305 kPa)) boost. The final 2.65 litre 4 cyl Offy, restricted to 80 in Hg (24.6 psi (170 kPa)) boost pressure, gave 770 bhp (570 kW) at 9,000 rpm."
The b-series of the 30's!
Old 10-11-2011, 07:06 PM
h2.4's Avatar
Default Re: Thought you guys might like this - offenhauser 4 cyl 16 valves twin cam
pretty impressive back in the day. Would love to disassy. one of those. Look at the valve angle. wow, didn't read your post thouroughly (spelling) one piece head and block! Must have removeable combustion chambers similiar to some two strokes! Crazy!
Old 10-11-2011, 07:41 PM
bauergold's Avatar
Awesome!
Old 10-11-2011, 07:48 PM
HdeucedeuceA's Avatar
Nice to see a "real" engine from that time period.
Old 10-11-2011, 08:40 PM
m_shake's Avatar
One of the old mechanics at my work has one in what's basically a 2 seater version of the car above and it's street legal still haven't ridden in it though
Old 10-12-2011, 04:35 AM
N/A
Purpose Built
N/A's Avatar
16 valves per cylinder??? Id love the see inside that thing
Old 10-12-2011, 08:05 AM
m_shake's Avatar
Haha, think thats a typo!
Old 10-12-2011, 06:28 PM
vtec8200's Avatar
Yeah corrected it
Would love to hear one of those, must sound mean as hell!
Old 10-12-2011, 09:48 PM
m_shake's Avatar
Haven't seen it in person yet, efi needs tuning bad!!! Same guy had a salt flat car running close to 80psi w/ an offy
Not related but have u ever seen the lancia triflux engine?
http://avs.spot-mate.com/images/triflux/Triflux.jpg
****in rad!
Old 02-01-2012, 05:00 PM
coltonarnol's Avatar
jus wanna say for the honda people who hate the gm quad 4 , that the Offenhauser is the design base for the quad 4 thats what usdm is capable of
Old 02-01-2012, 05:33 PM
Uncle Dave's Avatar
I have been lucky enough to work on some of these engines they just have such a great induction and exhaust note.Everytime I had one booked in to dyno it we would have a crowd of onlookers turnup.
Old 02-02-2012, 08:00 AM
m_shake's Avatar
Did you join just to post that?
Old 02-02-2012, 08:56 AM
Mr. EG's Avatar
Cool story
Old 02-07-2012, 02:02 PM
97mm_EH3's Avatar
A bit more work than most on here would do.
http://home.earthlink.net/~roygmisc1...tartoffy1.html
OnDaBottle
10-20-2004 12:10 PM
Turbo-Honda
10-12-2004 06:26 PM
Gump
09-20-2004 03:09 PM
mickey513
04-17-2004 07:07 PM
Mr.Integra
02-25-2003 11:22 PM
Quick Reply: Thought you guys might like this - offenhauser 4 cyl 16 valves twin cam
