Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 10-03-2011, 06:45 AM   #1
B16CRXVTEC
B16CRXVTEC's Avatar
Default Speed Sensor? Speedometer?
I have a 89 honda crx si stock.
Ok I replace my clutch over the weekend. When I drop the transmission down I forgot to unhook the speed sensor (the plug thatís hooked on to the Transmission)
So everything is put back together. But when im driving the Speedometer doesnít work? So I donít know how fast I am going?
Does anyone know what I can do to fix this problem? Im thinking I need to replace the speed sensor but im not sure? Any information is greatly appreciated.
B16CRXVTEC is offline   Reply With Quote
Old 10-03-2011, 07:08 AM   #2
crx_si-r
crx_si-r's Avatar
carlos zapien c_zapien
Send a message via AIM to crx_si-r
Default Re: Speed Sensor? Speedometer?
did you check to make sure the clip is still holding the speed-o cable in place?
CJ's Tuck Harnesses
CRX LOG
Instagram c_zapien
crx_si-r is offline   Reply With Quote
Old 10-03-2011, 07:31 AM   #3
B16CRXVTEC
B16CRXVTEC's Avatar
do u mean if i check to make sure if the sensor was plug onto the transmission? yes numerous of time.
what i havent checked was to make sure that the sensor is plug onto the back of the cluster? does that make any sense? lol
Old 10-03-2011, 08:04 AM   #4
skill178
1991 Honda Civic
My Garage
skill178's Avatar
these cars dont have a sensor on the tranny, its cable. if the cables pulld out it wont turn. the cable hooks to a sensor behind the gauge cluster. check the cable at the tranny first. easier then taking out the cluster.
skill178 is offline   Reply With Quote
Old 10-03-2011, 08:19 AM   #5
4drEF
4drEF's Avatar
When you disconnect the cable from the transmission, it is only a small wire clipthat holds it into the gear drive that is bolted into the tranny.
After you have it disconnected, you can spin the wire inside the cable and the needle on your speedo should move.
All of my posts should be considered for being made into a sticky.
4drEF is offline   Reply With Quote
Old 10-03-2011, 08:22 AM   #6
B16CRXVTEC
B16CRXVTEC's Avatar
I've already checked the cable thats hooked onto the tranny. i've unpluged it and repluged it back but it didnt work? so i should probably remove the cluster and check the back of it?
Old 10-03-2011, 08:24 AM   #7
B16CRXVTEC
B16CRXVTEC's Avatar
can you connect this plug onto the back motor mount?
Old 10-03-2011, 08:25 AM   #8
B16CRXVTEC
B16CRXVTEC's Avatar
confuse now?
Old 10-03-2011, 09:08 AM   #9
4drEF
4drEF's Avatar
Remove the retaining clip.
Pull cable out of gear drive.
Cable is like the brake line on a bicycle, your emergency brake, your throttle cable, or clutch cable.
The black part you can see in the pic is the cable sheath. Inside of that is the actual cable.
After you disconnect the cable from the gear drive, you can spin the cable.
Old 10-03-2011, 09:13 AM   #10
ewok1
ewok1's Avatar
jus take off ur cluster, sounds like when u dropped ur tranny the cable pulled outa or cluster .its not that difficult
Originally Posted by B16CRXVTEC View Post
confuse now?
"THE JUNKIES KREW" ©
"CALI LOVE"©
"The Few The Proud The NWP REFUGEE CAMP"
ewok1 is offline   Reply With Quote
Old 10-03-2011, 09:16 AM   #11
4drEF
4drEF's Avatar
From other posts -
The cable inside the sheath.
How the gear drive mounts to the tranny:
Speed pulser test.
Also shows the speedo cable hooking up to the back of the cluster.
Old 10-04-2011, 06:19 AM   #12
B16CRXVTEC
B16CRXVTEC's Avatar
From other posts -
Speed pulser test.
I can pull the Cable inside the sheath all the way out? is this consider broken? should i get a new Speed cable?
Old 10-04-2011, 07:07 AM   #13
OneBadTurboCRV
OneBadTurboCRV's Avatar
No, you can do that so you can lube it/clean it if need be... unless you have a sprung part, burrs, or something that would destroy anything.
'98 CRV EX
'13 Civic Si
OneBadTurboCRV is offline   Reply With Quote
Old 10-04-2011, 07:42 AM   #14
B16CRXVTEC
B16CRXVTEC's Avatar
ok so yesterday when i got home i pulled the speedsenor off of the transmission. took the cluster out and pulled off the plug thats plugged into the cluster.
I replugged the senor back onto the transmission and also made sure that the cable was sticking out of the plug before plugging it back on the cluster.
but speedometer still didnt work?
is there a special way to plug the speedsensor into the tranny?
Old 10-04-2011, 07:59 AM   #15
4drEF
4drEF's Avatar
Really? so you took it apart and put it back together and it still doesn't work.
AMAZING! WHAT A SHOCKER!
You did ZERO testing with everything apart and you didn't replace any parts.
Why would it be any different when you put it back together?
You don't follow directions very well so I'm wondering what the point is to even try helping you.
First, there isn't a speed sensor on the transmission.
I have no idea why you removed it from the transmission anyway.
Remove cable from gear drive.
Spin cable and watch speedo for movement.
Old 10-04-2011, 08:30 AM   #16
B16CRXVTEC
B16CRXVTEC's Avatar
the reason why the speedomoeter is not working is because when we drop the transmission we forgot to unhook the plug thats connected to the transmission. so when we drop the tranny the plug was stuck onto the tranny.
your right.. i dont follow direction well. for one im just trying to get this done myself instead of taking it to a shop. im no mechanic. and its also hard to do something when your not sure what your referring to...
Remove cable from gear drive. <== where is that located?
Spin cable and watch speedo for movement. <= which cable do i spin? where can i see the speedo movement?
sorry
Old 10-04-2011, 08:34 AM   #17
fallrivercolin
1993 Honda Civic
fallrivercolin's Avatar
cboutilier
Send a message via MSN to fallrivercolin
sorry
Pull cable out of transmission. Spin cable by hand. Look for speedo movement, well on the speedo
ED9, CG3, AB7 (gone), EH2 (gone)
fallrivercolin is offline   Reply With Quote
Old 10-04-2011, 10:18 AM   #18
OneBadTurboCRV
I still have no clue what and why you keep calling something a sensor... at this point I think this is a lost cause...
ALL YOUR QUESTIONS HAVE BEEN ANSWERED IN THE ABOVE POSTS... REREAD THIS ENTIRE THREAD!!!
'98 CRV EX
'13 Civic Si
Old 10-04-2011, 11:03 AM   #19
B16CRXVTEC
B16CRXVTEC's Avatar
well thanks for the reply ima just take it to a local shop...
Old 10-04-2011, 11:04 AM   #20
supahamster
works
supahamster is offline   Reply With Quote
Old 10-04-2011, 11:21 AM   #21
B16CRXVTEC
B16CRXVTEC's Avatar
where can i look at the speedo movement? is this on the cluster? lol
Old 10-04-2011, 11:30 AM   #22
4drEF
4drEF's Avatar
Does your computer not show pictures?
Do the words show up on your screen?
Covered all this.
Maybe covered it twice or more!
The speedo needle should move when you spin the cable by hand.
Make sure you have the cable pressed into the sheath properly before spinning.
If you don't know what the cable or the sheath is, then look at the pictures in this post.
I will be looking on the internet for 3D pictures (hope you have 3D glasses) and a pop-up repair manual. Not sure I will find one, but I can't think of anything else to help you.
Regardless if you are a mechanic or not, you have already done more difficult tasks so far.
YOU CAN DO THIS!!!
Old 10-04-2011, 06:27 PM   #23
ef_cowboy
ill have some one roll the car while i push the cable in the trans and stop when u feel it set in...
ef_cowboy is offline   Reply With Quote
2000, civic, clip, crx, ef, honda, problem, problems, sensor, speed, speedometer, tach, tech, work, working
