98 integra gsr- call wont run with map sensor plugged in. please help
Old 09-28-2011, 03:43 PM
Lao17's Avatar
Default 98 integra gsr- call wont run with map sensor plugged in. please help
Just bought a 98 gsr integra and it ran like crap so I fixed the timing and it ran better. But I noticed the map sensor wasnt plugged,in so when I plugged it in and go to start the car it dies right away. I already,tried different map sensor and restarting the ecu and both didnt work. And I also tried swap with the tps plugged and that wasnt it either.
Anyone know what the problem is? Thnks for the help
Old 09-29-2011, 06:18 PM
hybridmiklo's Avatar
Default Re: 98 integra gsr- call wont run with map sensor plugged in. please help
The map sensor uses a 5 volt reference from the ecu. CHeck that it gets its 5 volts. Then check the ground. Make sure it has one. If those check out check the signal wire from the sensor plug. That's what the ecu is going to see to determine the amount of fuel to dump. At idle it should be roughly about .8 to 1.0 volts with around 19-21 hg of vacuum.
Old 09-30-2011, 10:21 PM
Lao17's Avatar
Ok. Thanks. Is this the reason my gas mileage is really bad?
Old 10-02-2011, 11:32 AM
idriveahonda's Avatar
Just check and make sure other plugs aren't switched around.
Quite a few of them fit into one another.
mdb4879
07-01-2019 12:33 AM
carlos8
Engine Management and Tuning
12-26-2013 01:15 PM
cleanazcoupe
07-08-2009 09:28 PM
88crxdxfastwhip
01-24-2006 01:52 PM
sleepin91teg
08-05-2004 04:39 AM
Quick Reply: 98 integra gsr- call wont run with map sensor plugged in. please help
