Old 09-20-2011, 06:05 PM   #1
spraymaster
spraymaster's Avatar
Default H22A in EK..WHAT AXLES???
WHAT AXLES DO I PUT FOR DRIVER SIDE? PRELUDE OR EK DON'T WORK, HOW DO I LOOK THEM UP??? PLZZZZ HELPPPP
spraymaster is offline   Reply With Quote
Old 09-20-2011, 06:24 PM   #2
apexi_rsx
Send a message via AIM to apexi_rsx
Default Re: H22A in EK..WHAT AXLES???
http://cgi.ebay.com/ebaymotors/ek-h2...item3cbc29744a your using integra front spindles im assuming as he said integra drive side with 90-93 Honda Accord Ex or Lx model midshaft. Acura Integra passenger side axle that has been cut down 1/2" on the shaft and has an Accord 90+ Inner joint put on it. Raxles.com sells this 1 custom axle. its a hybrid kind of axle with the f22 inner and a integra outter.
06 Rsx Type S I/H/E ...14.0@101
97 civic 4dr turbo
apexi_rsx is offline   Reply With Quote
Old 09-20-2011, 06:24 PM   #3
DELshaneSOL
DELshaneSOL's Avatar
caukasn invasn
94 integra on the driver side.
or custom axles from hasport or raxles.
b16a del sol T
Originally Posted by JdmJah View Post
i think cylinder one might have a bad valve or something because it dosent get as hot as it should like the rest of the cylinders
DELshaneSOL is offline   Reply With Quote
Old 09-20-2011, 07:18 PM   #4
spraymaster
thanks fellas, i gatta try that... so if i get a axle for a 94 integra driver side, it will fit perfect??
Old 09-20-2011, 08:40 PM   #5
Mfoehrkolb
Mfoehrkolb's Avatar
Send a message via AIM to Mfoehrkolb
I am using AVID mounts, and just normal 32mm spindles... I use DA axles (not gen3)... DA specific axles are about half inch or more longer than the gen 3 and it clears up a lot of axle problems.
I have got reman ones with lifetime warranty... so next time i break or next time they start clicking... just free replacment... eff it..
but yeah... avid mounts and DA axles with the C clip widened a bit into the trans... no problems what so ever... and cheap.
Originally Posted by SovXietday View Post
Judging by his fab skills, I'm sure he'd be happy to show you his dyno graph that he drew in crayon.
Mfoehrkolb is offline   Reply With Quote
Old 09-20-2011, 08:45 PM   #6
kozanatos
kozanatos's Avatar
I thought you use driveshafts?
//koz
kozanatos is offline   Reply With Quote
Old 09-20-2011, 08:53 PM   #7
Mfoehrkolb
Mfoehrkolb's Avatar
--- http://www.traxxas.ru/products/nitro...veshaft_02.jpg
you mean that? lol... i think your right! 8x
Old 09-20-2011, 08:56 PM   #8
kozanatos
kozanatos's Avatar
Yeah that ! I take up two lanes and I had to build my frame out and use lambo doors, kind of a difficult swap for an ek.
Huh? "I like carrots, but carrots can kill me. Im going to go eat some carrots" type of logic here
//koz
Old 09-20-2011, 09:11 PM   #9
Mfoehrkolb
Mfoehrkolb's Avatar
--- DO NOT use gen 3 axles. They are shorter than the DA axles. You want the extra length to prevent any of the binding issues and pop outs.
Old 09-21-2011, 05:00 AM   #10
spraymaster
So 90 integra axles???
Old 09-21-2011, 05:25 AM   #11
fallrivercolin
1993 Honda Civic
fallrivercolin's Avatar
cboutilier
Send a message via MSN to fallrivercolin
yes. 90-93 Integra axles with accord inners
ED9, CG3, AB7 (gone), EH2 (gone)
fallrivercolin is offline   Reply With Quote
Old 09-21-2011, 09:08 AM   #12
Mfoehrkolb
Mfoehrkolb's Avatar
--- 90-93 is DA... so yeah. Just use those, and for the transmission side, you want to widen the C clip some so it's a lot more secured inside the trans. People have problems with popping out (i never did)... The combination of longer axles and widen the C clip never gave me an issue.
You do not need to use the accord, or prelude inners. Once you get into that, it becomes a bit more of a task to swap axles etc. Which going by this thread, you are kinda lost as it is with this h swap process. Simplicity is where its at when it comes to mechanical parts... straight up DA axle, widened C clip. Done.
Old 09-21-2011, 01:16 PM   #13
spraymaster
Ur not Lyin bout me being new to the H swap scene lol, but one thing I'm still confused on is I looked up DA axles but the inner part of the axle that goes to the midshaft is male, it needs to b female to go in the midshaft, so I assume I have to Change the end of the axle so it goes in???
Old 09-21-2011, 01:19 PM   #14
easy_vtec
easy_vtec's Avatar
Correct. Or go with an aftermarket swap axle. Goodluck!
1992 Civic Cx hatch daily
1992 Civic Cx hatch parting out
1991 Crx Si TGP 100% stock
easy_vtec is offline   Reply With Quote
9093, accord, avid, axles, da, ek, f22b, h2, h22, h22a, honda, integra, open, swap, tech
