d16y8 to d16y5
Old 05-16-2012, 12:26 PM
  #26
Mahalaleel's Avatar
Default Re: d16y8 to d16y5
Bueller?
Bueller?
Old 11-22-2012, 07:42 PM
  #27
ugadawg187's Avatar
Hate to beat up a old thread but need some input. I bought a jdm engine that turned out to be a y5 vtec e & put in my 97 civic ex after the y8 gave out. Its a 5 speed & right now im running the y8 p2p ecu, intake, header, and all sensor with no egr because the y8 didnt have them on the intake. Car idles funny so what needs to be done to make this thing perform correctly?
Old 11-23-2012, 12:14 AM
  #28
rayvo's Avatar
Default Re: 96 ex with hx engine
Originally Posted by jimboc88
and will there be any difference between the 99-00 ecu from the 96?
Your stock Y8 harness will work on the Y5
buy a...
obd2a to obd1 Jumper - 50$
92-95 Civic Ex P28 - $100
Send Ecu to Phearable.net for tune - $80
if you jump it to obd1 you'll bypass O2 sensors, Egr valve, etc.
Old 11-23-2012, 02:41 AM
  #29
ugadawg187's Avatar
Sweet! Thanks alot! 😋
Old 11-24-2012, 12:54 PM
  #30
ugadawg187's Avatar
buy a...
I contacted this place & they told me i would be wasting my money that a chipped obd1 ecu wouldnt solve my problems.
Old 11-24-2012, 02:04 PM
  #31
ExplicitJDM's Avatar
you SHOULD, but you dont have to..
Old 11-25-2012, 09:15 AM
  #32
ugadawg187's Avatar
Kind of smells like the car runs rich sometimes & the O2 sensor in the header has a white tint to it. The person i talked to said a obd1 ecu wouldnt fix the iacv malfunction im having but honestly i dont know whats causing it. I checked it with a multimeter & the TPS while i was at it. I noticed someone else said map sensor but im not throwing a code for that.
Old 11-27-2012, 05:58 AM
  #33
Project Dad's Avatar
the y5 tied to an EX 5 speed would be a little quicker than a y8. still your not talking about much but you can still have the mpg savings and the off the line feel.
I have both but need a car to put them in. I'm picky wanting a '98 ex
Old 02-15-2013, 08:23 PM
  #34
guitarboy1193's Avatar
trying to bring back some attention to this thread; did you ever fix your issue? im having the same problem. 99 ex, previous owner swapped y8 for a y5. i was unaware until after purchase, has been throwing knock sensor CEL since ive had it. So I'm thinking it is a knock sensor, because I've been told that the y8 has two sensors, and the y5 has 1. So i plan on hooking up a knock sensor to the plug that is dangling, and putting it on a spot, near the engine that is warm and vibrates so the sensor feels like it should as if it were in the engine. I already tried a new iacv, and that wasnt the issue. my problem only happens when it is already warm, and the ecu is changing the timing to make it smell like its really rich, hesitate upon giving the car gas, idle really high (1700ish rpm) and jerk while driving in gear.
Sorry for the book, but this has been bugging me for a few months now. Any help would be awesome. Doing the sensor thing tomorrow and going to get my cel reset
Old 03-26-2013, 04:49 PM
  #35
what ecu does it have?
Old 09-27-2014, 06:11 PM
  #36
Justin Lantz's Avatar
I got a 99 honda civic hx should I put the d16y8 heads on it to make it faster if so what do I have to do and need ? thank you
Old 09-29-2014, 11:57 AM
  #37
baller status's Avatar
Not really worth it. Just change the transmission or swap to a B series.
Old 10-22-2021, 06:27 PM
  #38
emilioz97's Avatar
Originally Posted by HondaPartsHero
If you want it to run properly yes. What about the head on the original engine is is good? You can just swap that onto the HX block. Otherwise you have to do some wiring and sensor work to get it to work with the HX ECU.
can I get some clarification can you use a D16y8 ecu for a D16y5 motor swap
Old 10-22-2021, 06:29 PM
  #39
emilioz97's Avatar
i have a quick question that i am not sure about. i have a 96 civic ex with a d16y8 engine. well had a d16y8. i swapped it for a d16y5 engine bcuz the block is bad on the original d16y8 engine. so my question is do i have to replace the ECU for a hx model?? i mean i just switched the engine but i still have the same tranny and intake maifold but just the block and the head are from a hx civic a d16y5.
Im also doing a motor swap with a D16y5 motor getting all wire harness and distributor for the Vtec but I couldn’t find a d16y5 ecu can you use a d16y8 ecu for the motor
Cjfox
03-14-2018 05:37 AM
raider1qaz
12-28-2013 07:45 PM
breakinitout
07-14-2006 10:01 PM
.brad
10-18-2001 07:45 AM
Quick Reply: d16y8 to d16y5
