Honda-Tech Breather Box/Catch can/breather box thread.
Old 10-27-2011, 06:54 PM
  #76
v8killaz's Avatar
Default Re: Honda-Tech Breather Box/Catch can/breather box thread.
nice. i wouldnt trust myself welding inside the vc though. something falls off and ruins my head
Old 10-27-2011, 08:11 PM
  #77
igorka_91's Avatar
Thanks. Everything is tacked in multiple places so i am not worried about it. Now were can i get 10an braided line for cheap. 15 feet of it.
Old 10-28-2011, 09:56 AM
  #78
yzracer323's Avatar
nice
Old 01-13-2012, 01:16 AM
  #79
m3tech95's Avatar
this is one of the best breather/catch setup threads ive seen in a long time....i am now in the market for a 6 port -10AN 1 gallon setup......
Old 01-13-2012, 05:43 AM
  #80
OG Fabricator
weiRtech's Avatar
here is mine i made a year ago with baffles inside.
Old 03-22-2012, 08:44 PM
  #81
gutted-dx's Avatar
If I vent both back ports, do I need to vent the head? The motor is a DD B20vtec.
Old 03-23-2012, 06:07 AM
  #82
kp
kp's Avatar
In the simplest terms I can think of:
If your VC is vented to your catch can and the catch can is vented, you don't need to vent your VC.
Old 03-23-2012, 03:27 PM
  #83
vtechjunkie's Avatar
So why the numerous holes, rather than using a hole-saw to cut the hole?
Old 09-17-2012, 06:03 PM
  #84
b18c5 power's Avatar
Everybody does either the two plug on each side of the oil filter (and plug the oem nipple breather + the oem breather hole <or use the oem breather as a drain back ) and some add vc breather as well or not or a combo of both ! Anyway, confused yet lol !!
OK now what about using the oem nipple and oem breather hole and run two lines (out of the oem hole+nipple )to the catch can instead , this would work right?Could not be worst than the oem breather !
Old 09-21-2012, 07:36 PM
  #85
FabChild's Avatar
Welded up a valve cover for a friend of mine.
Old 09-21-2012, 09:54 PM
  #86
revtechmotorworks's Avatar
Nice work! On the breather boxes!
Old 04-13-2013, 10:52 AM
  #87
Zero2Sixty's Avatar
does anybody know what car to get a freeze plug for so i can plug the factory catch can hole?
Old 04-13-2013, 12:51 PM
  #88
I'm really 2slow
2fast4u831's Avatar
http://www.brfittings.com/
go under catch can and accessories.
Old 04-13-2013, 01:28 PM
  #89
ej1 rep's Avatar
Heres my first one where I didn't **** up any of the welds too bad. Not done yet, there is a perforated piece of metal about 5/8" down from the top. Where is the Cheapest place to get AL AN fittings?
Old 04-13-2013, 04:52 PM
  #90
SovXietday's Avatar
Jegs/Summit
Old 04-16-2013, 12:06 PM
  #91
LD_EGSICK's Avatar
I made this a couple of years ago.
Prayoonto Racing Turbo Integra:
Made a box
-welded -AN fittings on the valve cover
-Mocked up the box for mounting points and for the -AN fittings
Done....
Prayoonto Racing All Motor Civic:
-AN fittings on the back of the Valve cover
Rolled a piece of aluminum/made it kinda big so we wouldn't have to drain it until after the race.
Done
Installed.... also now its on the other side due to our new Gangsta Lean setup.
Made this for my s2000 AE86 a couple years ago to
Coolant Overflow Tank
Installed
coolant full also to set at highest point to help with getting rid of air pockets.
Old 04-16-2013, 09:31 PM
  #92
a1320honda's Avatar
Heres the one i made for my car. Baffled inside with 2x -12 AN in and 1x -8an as the return. Havent had much use on it yet but so far so good. The valve cover is also baffled.
slammeddime
03-20-2013 12:34 PM
brenden747
10-04-2011 08:30 AM
horn12007
10-20-2010 07:04 AM
black92DA
08-02-2010 08:43 PM
Rus1an
02-28-2007 04:11 PM
Quick Reply: Honda-Tech Breather Box/Catch can/breather box thread.
