Skunk2 Coilover sleeves?
Old 09-13-2011, 05:17 PM
95egianp's Avatar
Default Skunk2 Coilover sleeves?
I have Omni Power Coilovers on my EG. Its lowered 1.5 inches, and the ride is ridiculously bumpy. Turns out these are drag Coilovers so there's my problem. Do I have to get a whole new set of Coilovers to have a bit of a softer ride? Or can I get Skunk2 Coilover sleeves, which have a lower spring rate, for a softer ride. (That would also be much cheaper than buying a new set of Coilovers).
Old 09-13-2011, 05:48 PM
apexi_rsx's Avatar
Default Re: Skunk2 Coilover sleeves?
from my experience with coil overs most are a bumpy ride somewhat, but i have felt much worse with drag coilovers. mainly its going to have alot to do with the shock you use. stock struts are deff a NO NO
Old 09-13-2011, 05:57 PM
Sol Del Hon-duh's Avatar
This is what its coming for the Del Sol
http://www.addoway.com/viewad/SKUNK2...A-CIVIC-245239
Old 09-13-2011, 06:23 PM
95egianp's Avatar
I have full coilovers, so the shocks are not stock. Basically I am wondering if the skunk2 coilover sleeves will fit on the Omni Power's.
Old 09-13-2011, 06:31 PM
Ohhhhhhh lol good question then
Old 09-13-2011, 07:04 PM
Master Detailer
98civdx's Avatar
Has much more to do with the spring rates, then being a coilover.
OP, the sleeve will NOT work, you basicly already have it. The spring on the other hand may fit. But, I wouldn't being using skunk2 springs.
Old 09-13-2011, 07:34 PM
ej1b18c1's Avatar
IMO skunk2 is a crappy spring/coilover but that's just based on my experience.
Old 09-13-2011, 07:57 PM
Master Detailer
98civdx's Avatar
X2.
<------ Has skunk2 sleeves.
jdmCD695
06-21-2008 08:47 PM
eg6sittingon57cs
08-10-2007 09:02 PM
vyxx-ct
Honda Civic (2001 - 2005)
10-02-2006 03:21 PM
Richard.
Suspension & Brakes
12
08-16-2005 03:07 PM
sexyaccord
05-31-2002 03:35 PM
Quick Reply: Skunk2 Coilover sleeves?
