00 civic si b16 problem
Old 09-12-2011, 05:15 PM
oleskooljoker's Avatar
Default 00 civic si b16 problem
i have some knowledge on hondas and a little on DOHC but first its a stock b16a2 original engine. 137,xxx miles. i bought it used from a dealer with a brand new head with about 10,000 miles on it and it has a DC header, 2 1/4 piping all the way back to a stock tip and a cat. AEM cold air intake. i think thats it but anyway........
it is showing codes for misfire on cylinders 2 and 4 and showed 3 until i erased the codes but it will probably show again idk. random and multiple misfires. i have already changed the plugs, wires, distributor cap and rotor, and ignition coil.
that still didnt do anything. it has no power what so ever that it should have. it bogs down when going up a hill and i barely if not hit only 85 on the interstate so yeah.....
i need some help! its my dd and i need something to do to fix the problem and have the power it needs back. any info?
Old 09-12-2011, 05:54 PM
fcm
Old Fart
fcm's Avatar
Default Re: 00 civic si b16 problem
Multiple random misfires is almost always due to a fuel issue.
When was the last time the fuel filter was changed?
I would do a fuel pressure test, or just install a fuel pressure gauge, they are as cheap as $20... http://www.ebay.com/sch/i.html?_from...All-Categories 94
Old 09-12-2011, 05:57 PM
i have no idea. i havent touched the fuel filter yet
Old 09-14-2011, 03:33 PM
ive changed the filter and still have the same results as before. any other ideas? i know it had pressure cause i forgot to release the pressure and shot out when i loosened it the top bolt off the filter.
even when im slowly rolling in 2nd gear at about 4500 rpm and floor it....it still bogs way down and i gradually get up. slowly.....
Old 09-14-2011, 08:12 PM
hybridmiklo's Avatar
You need to check the fuel pressure. With and without the fuel regulator vacuum.
Old 09-15-2011, 08:52 AM
How much pressure should I have?
Old 09-17-2011, 10:21 AM
xxSOLxx's Avatar
I had the same problem in my f22 accord ran really shity. I ended up getting it checked out my mechanic said I had blown a piston ring in cylinder one..
Old 09-17-2011, 11:24 AM
yeah imma have a mechanic look at it in a couple of days and tell me exactly whats wrong with it but hope it aint that. what did you do?
Old 09-18-2011, 06:16 PM
yeah still trying to fix that but now just the other day while driving at a high rpm just around 5 grand right before vtec there was a noise that started and sounded like someone was rubbing sand paper on the engine and its horrible and loud! it doesnt do it anytime below that. but when in neutral i can rev it up past that and wont hear it. a drivetrain problem??? any help?
Old 06-07-2012, 11:07 AM
Si_ek9's Avatar
I have the same problem on my b16a2 it is throwing a cel light on cylinder 2 however it runs good and every once in a while it will start misfiring and I've notices when the Ac was on it would start doing it even more.with Ac off the rpms were at 1 and with it on they were at 3 idk the problem replaced my plugs and wires was told that the distributor was still good any other ideas?
ribal_gh
08-15-2014 06:04 PM
yanxu
12
08-08-2010 09:57 AM
Wish2345
38
05-16-2010 09:46 PM
pimpchickpcfl
11
05-10-2009 11:00 AM
Design
01-10-2005 10:12 PM
Quick Reply: 00 civic si b16 problem
