1997 Civic LX won't start
Old 09-09-2011, 12:19 PM
pintobean11's Avatar
Icon6 1997 Civic LX won't start
I drove the car to lunch and came out to start the car and it did not crank at all. When I turned the key on everything worked but the car did not want to turn over. Luckily I was on a incline so I was able to pop start. Could this be a relay?
Old 09-09-2011, 12:35 PM
Former User's Avatar
Default Re: 1997 Civic LX won't start
Dead battery?
Rubber stopper at top of clutch pedal fall out?
Old 09-09-2011, 12:41 PM
Definetely not the battery, but I did just have to replace the plastic piece for my brakes so that may it.
Old 09-09-2011, 02:29 PM
Yep, it's for sure that piece there. How in the **** do I fix that?
Old 09-09-2011, 02:49 PM
Buy a new stopper or hot glue a coin over the hole.
Old 09-09-2011, 03:33 PM
It seems very difficult to try and even get up in there. I have a stopper that I use that fits perfect it's just a matter of getting up in there.
Old 09-09-2011, 03:40 PM
The Grumpiest
grumblemarc's Avatar
Pull the seat back and get on your back. Easy. Getting back up. Not so easy.
Old 09-09-2011, 04:09 PM
This^
Old 09-11-2011, 07:16 AM
God, that was such a bitch to work on. I rigged the shlt out of it with 3 zip ties. Let's see how long this holds up.
Old 10-09-2011, 04:23 PM
tgreyboy46's Avatar
I just repaired my 94 Del Sol today. Civic should be similar. It wasn't that bad. I got the pedal stopper from the Honda dealer for 50 cents a piece. I have now replaced all 3 (1 that controls starter signal, 1 that controls cruise control & the brake light). By far this was the worst one. Tried to get to it without pulling the clutch pedal assembly, but I couldn't get to it with my finger. I ended up pulling clutch pedal assembly. Took me about 2 hours being an Old man of 52. Laying on your back is a pain.
Now, for how I did it.
First thing remove the driver's seat and then the plastic kick panel under the steering wheel. Then remove the cotter pin and 1/4" pin holding clevis on the clutch master cylinder. Remove the 2 nuts with a 12mm socket that hold the clutch master cylinder to firewall and push it back into engine compartment. The one you can't see, I removed with a 1/4" socket set/12mm. Next thing is to remove Upper bolt above clutch switches. You have to strain to see it, but it can be removed with a 12mm socket and long extension. When it drops down, disconnect the two plugs on the switches & remove from car. You will see the hole where the stopper needs to be installed. If you have any more questions, you can email me at teddyg@***.net I will post pictures as soon as I figure it out.
Old 10-09-2011, 04:37 PM
tgreyboy46's Avatar
I have pictures, but can't figure out how to post. If you need them, email me.
Old 10-09-2011, 04:58 PM
Upload your pictures at PhotoBucket and then copy and paste the IMG code for each picture into your post.
Civic_EF9_89
11-29-2009 11:08 AM
SwiftTypeR
01-03-2008 06:46 AM
Adampops
08-05-2003 03:43 PM
kent
11
04-16-2003 08:08 PM
Quick Reply: 1997 Civic LX won't start
