Brake lights and horn doesn’t work. Please help
Old 02-05-2019, 10:36 PM
Daltond99's Avatar
Default Brake lights and horn doesn’t work. Please help
Hi everybody,
i just purchased my first car amd it and it is a 1999 Honda Civic. I noticed that the brake light and the horn do not work. Also the cruise control will not engage. I checked the fuses and it’s working. I also checked the switch and it’s making contact. Whenever I press the horn button I can hear the relay click on but it doesn’t produce any sound. My tail lights, hazards, turn signals and head lights all work but no brake lights.
Old 02-06-2019, 03:26 AM
pontiacman63383's Avatar
Default Re: Brake lights and horn doesn’t work. Please help
The horn and the brake lights are both powered off of fuse 52 in the under hood fuse box. Use a test light a make sure you have power at all times at the fuse. then check for power in and out of the brake switch. White and green wire going in to the switch should have power at all times and green and white wire will have power with the pedal pushed. If that all checks out you need to check power at the bulbs. As for the horn, if you hear the relay click you need to check for power at the horn itself. check those out and then we can focus on the cruse after.
Old 02-06-2019, 03:17 PM
mk378's Avatar
I have had it happen where every one of the brake light bulbs are burnt out. Whenever a light on a car doesn't light up, always check the bulb first.
Old 02-06-2019, 04:54 PM
Daltond99's Avatar
alright so my constant on the switch has power but the other does not
Old 02-06-2019, 06:53 PM
Daltond99's Avatar
I have fixed the issue. It’s looks like the problem was a loose connection in the rear panel. Thank you for you replies and all the help
heato
07-12-2012 12:06 PM
Type-Spaz
10-02-2011 04:44 PM
keepitngga1
07-18-2008 10:26 PM
cmyrex
07-12-2006 04:27 PM
b16a2pwr
02-14-2004 02:28 PM
Quick Reply: Brake lights and horn doesn’t work. Please help
