Old 09-08-2011, 02:16 AM   #1
brucepick
brucepick's Avatar
Default Alternator connector pinout - for alt cutout switch?
Any hints on setting up an Alternator cutout switch for Gen 6?
A connector pinout would be good to have.
I don't want to just yank the connector. I want to be able to electrically disable the alt while driving (say under heavy throttle or a hill climb) and bring it back on when less load on the engine.
Yes my HX has plenty power but its an mpg project car. I drive 50-55 mi. to work each way and it doesn't need to run the alt at 13.x volts the whole way, as long as I'm not running a bunch of accessories.
Driving a '97 Civic HX 5-spd: VTEC-E Lean Burn coupe.
Wifemobile: '96 Accord 5-spd, 4-dr, F22B2
brucepick is offline   Reply With Quote
Old 09-08-2011, 05:55 PM   #2
brucepick
brucepick's Avatar
Default Re: Alternator connector pinout - for alt cutout switch?
bump
Old 09-08-2011, 06:04 PM   #3
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
Don't guess, troubleshoot.
Old 09-09-2011, 08:42 PM   #4
MrMike
MrMike's Avatar
Send a message via AIM to MrMike
This is a good idea. Let us know how it works out once you figure it out. I'd say you'd pick up 3-4mpg losing the drag the alternator puts on the motor.
MrMike is offline   Reply With Quote
Old 09-09-2011, 10:41 PM   #5
grumblemarc
The Grumpiest
1996 Honda Civic
grumblemarc's Avatar
iTrader Rating: (3)
Send a message via AIM to grumblemarc Send a message via Yahoo to grumblemarc Send a message via Skype™ to grumblemarc
Until you forget to flip the switch one day.
FAQs!--How to Turbocharge your Civic--Want a faster Civic?-- Random DIYs
The words "Help!" or "Best" in your posts shows you are clueless and that you are extremely lazy.
grumblemarc is offline   Reply With Quote
Old 09-10-2011, 02:37 AM   #6
NotAJDMFanBoy
The system is going to keep the battery charged at like 12.5 volts. Would running the alternator at higher load, increasing the drag more but for a shorter period benefit?
I know I heard not to run an alternator without the battery attached. Something about how the electricity has to flow somewhere and without anywhere to go it will damage the alternator. This is probably what you're trying to fix I assume?
NotAJDMFanBoy is offline   Reply With Quote
Old 09-11-2011, 03:44 AM   #7
brucepick
brucepick's Avatar
One thing I learned is that the ELD (Electrical Load Detector) plus ECM do cut the alternator electrically when certain conditions are met. Basically, that is: low electrical load, including headlights must be off, speed below 50 mph (rpms seem to have no effect), and engine not in fuel cut mode (coasting in gear with foot off gas).
[EDIT - correction: It may instead run the alt at a lower voltage, somewhere between 12.0-12.5. Watching the voltage on a digital gauge, I can't tell if it's totally cutting the alt or running at lower voltage.]
Supposedly it does this by grounding the white/green wire going to the "C" connector. I just haven't had time to chase it down and try it. Not sure if I really want to go grounding a wire with voltage in it though...
Old 09-11-2011, 04:16 AM   #8
HondaPartsHero
Technical Hero
HondaPartsHero's Avatar
Ignore the 3 pin diagram unless yours is a Canadian model with this style.
OBD1/2 SOHC/DOHC VTEC HARNESS
MINI ME SUBHARNESS
02 EXTENSION HARNESS
Hondapartshero.net
HondaPartsHero is offline   Reply With Quote
Old 09-11-2011, 04:56 AM   #9
fleabag
1998 Honda Civic
Funny thing.... If you want to improve your fuel economy without removing the alternator belt, might I suggest you get a battery tender and charge your car? I discovered that putting my car battery on a battery tender improved my fuel economy by around 10% since the car didn't feel obligated to charge the battery like it did previously. Your idea won't save you fuel because the car will still try to charge it one way or another. Letting the alternator float charge at 13.5v will protect your battery. It's not the voltage but the amperage draw that increases your fuel consumption.
WANT TO BUY '92-'95 CX/VX Transmission (Interested in both working or broken ones!!!)http://hondamarketplace.com/showthread.php?t=2758129 WTB:D16Y5 engine http://www.hondamarketplace.com/show...6#post44127066
fleabag is offline   Reply With Quote
Old 12-01-2011, 04:51 PM   #10
brucepick
brucepick's Avatar
Thanks to RonJ@HT and to HondaPartsHero for the diagrams. I will try put a switch in the line between Fuse 15 and the alternator. Black/white at the fuse, black/yellow at the alternator.
Sorry - I can't decipher the OBD2 pinouts above. Don't know if my car is OBD2A or OBD2B. Messing with the ECM/PCM connectors scares me. Lotsa wires in a small space. But I might be able to access the wire at the underdash fuse panel.
To those discussing whether it will save gas, and should I charge it from an outlet etc...
Yes I'd charge it from an outlet if running for any significant time without the alt. Will cost a few bucks though - my nice automatic charger disappeared from the garage, so I'll need a new one. Dang.
I don't doubt that doing this right will save fuel. Not huge amounts, but I've been doing a lot of little things and they all add up. Been getting 47-48 mpg in CT, USA in November. Got a solid 50 through the month of September, much nicer weather.
I also want to run the headlights off a second deep cycle battery because I run the lights nearly always in winter. I figure a decent size Optima yellow top, fully charged from a/c, would power the headlights for a good three hours. Doing that will take that load off the alternator, and when appropriate I can cut the alt completely. I can charge it up overnight.
Old 12-20-2011, 07:39 AM   #11
California98Civ
1998 Honda Civic
I'm on the same road with you, brucepic. I just sent a PM. I started a thread on this same topic, not realizing you had too. I searched threads but I was looking for a "kill switch" and this uses the word "cutout" -- same thing but different words maybe hid the post when I searched. Anyway, I'll execute this mod on my 98 DX probably this week and then post back about it.
And kudos to RonJ@HT for the diagrams!
California98Civ is offline   Reply With Quote
97, accord, alt, alternator, car, civic, connector, honda, pin, pinout, plug, plugs, round, switching, tech
