Old 09-05-2011, 10:52 AM   #1
nitro911
1996 Honda Civic
Default Turn signals do not work but the flashers do.
So like the title states my turn signals do not work but when I use the emergency flashers both of them work. All the fuses have been replaced with new ones so I'm not sure where the problem lies. I'm thinking it has to do with the wiring. If anyone knows what to do or where a wiring diagram is at it'd be much appreciated. Also I'm not sure if this is related but my reverse lights do not work either and the bulbs have been replaced with new ones. So any help would be great Thanks.
nitro911 is offline   Reply With Quote
Old 09-05-2011, 11:26 AM   #2
riceordie
1997 Honda Civic
My Garage
riceordie's Avatar
@cburgersnbjs
Default Re: Turn signals do not work but the flashers do.
Check your wiring and also check to make sure your lever for turning your turn signals on is hooked up correctly
riceordie is offline   Reply With Quote
Old 09-05-2011, 11:29 AM   #3
nitro911
1996 Honda Civic
All the other lights work, and all the fuses are new and working as stated.
Old 09-05-2011, 02:52 PM   #4
nitro911
1996 Honda Civic
bump
Old 09-05-2011, 03:22 PM   #5
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
If you hope to get useful replies, then provide all pertinent information about your car and engine:
Don't guess, troubleshoot.
Old 09-06-2011, 10:07 AM   #6
JDM8o9
JDM8o9's Avatar
flasher relay
I so JDM
JDM8o9 is offline   Reply With Quote
Old 09-06-2011, 10:48 AM   #7
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
Originally Posted by JDM8o9 View Post
flasher relay
If this were true, neither the blinkers or hazards would work, right?
Old 09-06-2011, 11:58 PM   #8
nitro911
1996 Honda Civic
I would assume so. But my hazard lights do work and all fuses have been replaced with new ones. So I'm thinking a short somewhere then? I don't know though.
Old 09-07-2011, 01:28 AM   #9
kyosoeg6
kyosoeg6's Avatar
iTrader Rating: (7)
Send a message via AIM to kyosoeg6
i have a feeling the plug or clip just behind the steering wheel is loose but not to a point to where u can see it. unplug it and plug it back in. see if that does anything
1992 Captiva blue SI______ SOLD
00 ITR #-0272 aka DAISY
kyosoeg6 is offline   Reply With Quote
Old 09-07-2011, 02:38 AM   #10
apexi_rsx
Send a message via AIM to apexi_rsx
make sure ur connection by the plugs are good they tend to short out on eks alot i have took a couple extra harness's from junk yards because mine have been starting to pull apart on me.
06 Rsx Type S I/H/E ...14.0@101
97 civic 4dr turbo
apexi_rsx is offline   Reply With Quote
1996, blinker, blinkers, civic, dont, ep3, flashers, honda, integra, lights, make, signals, turn, ur, work, working
