Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Prelude
Old 09-03-2011, 05:16 AM   #1
street_ride14
1993 Honda Prelude
street_ride14's Avatar
Default knocking sound as soon as the wheels rotate
Hey guys, help me figure this one out..
There's a knocking sound shortly after I take off from a stand still, the sound becomes apparent after speeds of a whopping 3 mph. The noise is not there when the steering wheel is turned while standing in one place, but is there when turning and moving. Engine revs without problems and without noises.
Sound developed over the last week, no sounds before.
I've double and triple checked my suspension and nothing is loose, all bushings and ball joints are fairly new, no vibrations from wheel bearings.
Both axles are 1 month old (AutoZone//Duralast brand), but still .. could this be an axle issue?
Nothing is visibly broken, bent, loose, or damaged.
What does this sound like ?
street_ride14 is offline   Reply With Quote
Old 09-03-2011, 12:38 PM   #2
minilogoguy18
Default Re: knocking sound as soon as the wheels rotate
Myself and others I know have had horrible experiences with advance and autozone axles, they're terrible. They all started leaking grease past the bands on the boots, even re banding them didn't stop it, you made sure none of the joints are leaking?
93 BB2 - JDM H22a/T2W4 Euro R transmission
Originally Posted by PirateMcFred View Post
Everyone's ****'s broken and they can't find a Helm Manual to read.
minilogoguy18 is offline   Reply With Quote
Old 09-03-2011, 12:58 PM   #3
snobordboy
Moderator
snobordboy's Avatar
Send a message via AIM to snobordboy
Transmission? Bearing in the halfshaft? Wheel bearings? Loose lug nuts? Cracked brake pad?
I can name things all day long. Throw the car on a lift, or 4 good jack stands, and let it run at idle in first, see if you can tell where the noise comes from.
'93 Prelude SI H23VTEC 11.6:1 M2B4, 12.93 @ 108.21 MPH.
'02 Subaru WRX HKS, Invidia, Volk CE-28N, lots of Sti parts. Great winter beater.
'06 RSX Type-S Bone stock - for now
'11 GMC Sierra 4X4 - pulls stuff
snobordboy is offline   Reply With Quote
Old 10-16-2011, 03:27 PM   #4
shamu1
I have a similar problem and need help as well. I don't mean to hijack the thread but I'm a new user and cannot create a new thread.
I have 1999 Honda Civic Si with 94k miles. It has a b18b1 from previous owner
The problem is: When I decelerate or brake from about 45mph or higher I hear a sort of knocking/chugging sound coming from the passenger front wheel area. It sounds like a fast knock and as I slow down it gradually slows down as well. As the car comes to rest the knocking sound stops as well with 3 or 4 last knocks.
I recently had the alignment, balancing and tire rotation done at Meineke. They forgot to put one of the nuts on the passenger side wheel and I drove the car about 10 miles before realizing. I promptly replaced the nut with a new one. When the nut was off, I would hear sort of a knock/clunk when the car would be about to stop. However, the sound went away when i replaced the nut.
The sound i'm having now is kind of like a very fast knock when decelerating from 45mph or more. The car does not vibrate, shake or goes to one side at any speed. The steering feels pretty smooth as well.
I'm thinking it might be a wheel bearing, but I though a bad bearing would make a loud grinding sort of sound.
My rims on the Si are all perfect as well, no bends or anything that I can see.
Also, there is no knocking at all when the car is parked and I rev the engine. I revved it up to past 5k and let it slow down there was absolutely no knock. I have had an oil change done less than 500 miles ago as well.
I will greatly appreciate all your help. Thank you.
shamu1 is offline   Reply With Quote
Old 10-16-2011, 04:54 PM   #5
godslayer
2000 Honda Prelude
godslayer's Avatar
Originally Posted by shamu1 View Post
yada yada yada Civic yada yada
This is the Prelude section of the forums. You might want to wander over to the General or Civic sections to hijack some other thread.
Frank Corona
godslayer is offline   Reply With Quote
Old 10-18-2011, 07:17 PM   #6
boost4life1
I have a similar problem. I thought for sure it was the axle but I replaced it and the knocking is still there. I'm stumped now so let me know if u figure anything out.
boost4life1 is offline   Reply With Quote
Old 10-19-2011, 04:39 AM   #7
bigblue7t6
2001 Honda Prelude
Also perhaps check your motor and transmission mounts, maybe one of them is giving up allowing the engine to twist upon take off, maybe see if there is shiny metal on your header/down pipe where it goes past the cross member. I had a knocking sound in mine after I pulled my engine and put it back in because the bolt from my front motor mount worked its way out and allowed things to shift around in there. Good luck.
bigblue7t6 is offline   Reply With Quote
Old 10-19-2011, 07:11 AM   #8
typemismatch
Honda owns me
typemismatch's Avatar
Potentially radius arms or their bushings?
1992 Prelude S - 469hp/340tq@15psi - 12.46@117mph
2007 Civic Si - FG2 - almost stock (DD)
92 EG H2B - build thread http://www.honda-tech.com/showthread.php?t=2944704
typemismatch is offline   Reply With Quote
Old 10-21-2011, 09:01 PM   #9
integra15
integra15's Avatar
Autozone, cardone, etc axles suck. One thing that is worth going OEM on.
integra15 is offline   Reply With Quote
Old 02-26-2014, 12:39 PM   #10
xduB95preludeSi
what ended up being the solution? i just drove my car today after trying to uninstall my front struts (without success) and noticed a weird noise when the wheels rotate. it happens at any speed and sounds like something is definitely rubbing. what should i check?
xduB95preludeSi is offline   Reply With Quote
Old 02-27-2014, 06:48 AM   #11
snobordboy
Moderator
snobordboy's Avatar
You should probably go over everything on the front end of the car again, especially if you were not successfull at changing struts, something is probably loose or damaged. Might be a good idea to just have the car towed to a shop and have someone with more mechanical skill do it as well, for the safety of yourself and everyone else on the road.
Old 03-13-2014, 08:23 PM   #12
93prelude23
Mine was making that same noise I changed the rack n pinoin n it went away
93prelude23 is offline   Reply With Quote
Old 04-22-2014, 05:51 AM   #13
street_ride14
1993 Honda Prelude
The problem was resolved a while ago, but just wanted to update this thread.
Lets blame the 'shop' on this one.
So the shop that I went to for my hub/wheel-bearing replacement on my front knuckles did not press in the new hub/wheel-bearing assembly all the way on the driver's side knuckle. Took me a while to figure this out, but when comparing the spacing of the passenger side knuckle/hub assembly, I could see that the driver's side was not pressed in all the way, about 7mm off, thus leading to bearing vibrations and noise while driving.
Took the knuckle back to the shop and had them press in the hub/wheel-bearing assembly further, problem solved.
93, audio, bearing, civic, knocking, moving, noise, prelude, rotates, rotating, rotation, sound, subaru, thumping, tire, wheel
Similar Threads
Knocking sound from rear tire in 2009 Civic EX AFTurboGirl Honda Civic (2006 - Current) 2 05-19-2014 03:17 PM
Rotational clunking while driving straight chipmunkbug Honda Civic/Del Sol (1992 - 2000) 10 09-16-2013 03:33 PM
Still have knocking sound after a few repairs 06mmDc5 Acura RSX DC5 & Honda Civic EP3 4 08-13-2013 09:15 AM
Popping Noise from steering wheel/column when turning side to side dth0ng69 Honda Civic/Del Sol (1992 - 2000) 0 04-26-2013 08:10 AM
Wheel bearing like noise, but not the wheel bearing. What else has same symptoms? bambbrose Honda Accord (1990 - 2002) 13 09-04-2012 02:40 PM
