Old 08-30-2011, 06:02 PM   #1
zeez74
Default Need Help with 2000 Accord SRS Code
Hello all...
What a great forum you have here!
I've scoured the internet for clues to the code I'm getting from my Honda Accord, but have been unable to determine what the code is telling me. Can anyone here help out?
...thanks in advance for any assistance you can provide!
2000 Accord SRS light always on. Tried clearing the SRS light by jumpering the MES connector but the light is still on. I jumpered the service connector pins 8 to 13 (brown and black wires), turned the key on and got the following:
-SRS light on for 6 seconds
-3 or 4 really fast flashes
-5 long flashes
-3 short flashes
-light on solid
Is this a code 53 or is the 3 or 4 really fast flashes significant.
zeez74 is offline   Reply With Quote
Old 08-31-2011, 04:17 AM   #2
zeez74
Default Re: Need Help with 2000 Accord SRS Code
I found the SR codes in another thread. I'm posting here for future reference.
SRS:
1-1 Open in the Driver’s Airbag Inflator
1-2 Increased Resistance in Driver’s Airbag Inflator
1-3 Short to Another Wire in Driver’s Airbag Inflator or Decreased Resistance
1-4 Short to Power in Driver’s Airbag Inflator
1-5 Short to Ground in Driver’s Airbag Inflator
2-1 Open in the Passenger’s Airbag Inflator
2-2 Increased Resistance in Passenger’s Airbag Inflator
2-3 Short to Another Wire in Passenger’s Airbag Inflator or Decreased Resistance
2-4 Short to Power in Passenger’s Airbag Inflator
2-5 Short to Ground in Passenger’s Airbag Inflator
3-1 Open in Driver’s Seat Belt Tensioner
3-2 Increased Resistance in Driver’s Seat Belt Tensioner
3-3 Short to Another Wire in Driver’s Seat Belt Tensioner or Decreased Resistance
3-4 Short to Power in Driver’s Seat Belt Tensioner
3-5 Short to Ground in Driver’s Seat Belt Tensioner
4-1 Open in Passenger’s Seat Belt Tensioner
4-2 Increased Resistance in Passenger’s Seat Belt Tensioner
4-3 Short to Another Wire in Passenger’s Seat Belt Tensioner or Decreased Resistance
4-4 Short to Power in Passenger’s Seat Belt Tensioner
4-5 Short to Ground in Passenger’s Seat Belt Tensioner
5-1 Internal Failure of the SRS unit
5-2 Internal Failure of the SRS unit
5-3 Internal Failure of the SRS unit
5-4 Internal Failure of the SRS unit
5-5 Internal Failure of the SRS unit
6-1 Internal Failure of the SRS unit
6-2 Internal Failure of the SRS unit
6-3 Internal Failure of the SRS unit
6-4 Internal Failure of the SRS unit
7-1 Internal Failure of the SRS unit
7-2 Internal Failure of the SRS unit
7-3 Internal Failure of the SRS unit
8-1 Internal Failure of the SRS unit
8-2 Internal Failure of the SRS unit
8-3 Internal Failure of the SRS unit
8-4 Internal Failure of the SRS unit
8-5 Internal Failure of the SRS unit
8-6 Internal Failure of the SRS unit
9-1 Faulty SRS Indicator Circuit or Faulty SRS Power Supply
9-2 Faulty SRS Power Supply
10-1 SRS Replacement Code
Old 08-31-2011, 04:32 AM   #3
TheMuffinMan
He knows where you live!
TheMuffinMan's Avatar
iTrader Rating: (1)
Originally Posted by zeez74 View Post
Nice to know that there are 18 codes that mean the exact same thing to whoever developed thsi system.
They don't necessarily mean the same thing just because their publicized description is identical. Most likely it references individual components in the SRS unit itself - possibly sections of the IC board or individual chips/capacitors/etc.
Personally, given it is an OBDII vehicle, I would take it by Honda and have them run their scanner against it to pull a more specific code and description.
Long flashes indicate the first digit and short flashes indicate the second digit. I've got a feeling, since the SRS light will come on solid when you first start the car, the light didn't blink because it was initializing the system. The code presented (Assuming that's what it is) is 53.
2004 NFR S2000
Originally Posted by slomofo
I think TheMuffinMan is Chuck Norris. Seriously, you can't find the TheMuffinMan,TheMuffinMan finds you.
TheMuffinMan is offline   Reply With Quote
Old 08-31-2011, 06:23 AM   #4
zeez74
Thanks MM. I actually took it into a Honda dealership. Here is their exact response on my invoice:
- No communicating with Honda Diagnostic System (HDS)
Possible SRS unit will need to trace wires
Diag to start 198.00 may be more depends on time takes to diag -
Maybe I'm wrong, but I felt like I was getting screwed, so I left. I had a very hard time believing that they were unable to communicate with the car.
I guess I could take it to another dealership...not sure yet.
Old 08-31-2011, 06:32 AM   #5
TheMuffinMan
iTrader Rating: (1)
Given that, its possible the entire unit and/or its communication ports are toast. You can replace a SRS unit yourself without any issue, but I would recommend buying a BNIB OEM Honda one from Majestic Honda online or similar. Turn off the vehicle, have the battery unplugged and give it some time to drain the power, then simply unbolt and swap the units. I did my fiancee's '07 Accord like this when her airbags deployed. The unit itself was ~$200 IIRC and only took about an hour to swap it. I would imagine yours is in a similar location behind the dashboard.
2004 NFR S2000
Old 08-04-2013, 09:33 AM   #6
eyobest
Icon3 Re: Need Help with 2000 Accord SRS Code
I was having the same issue. My Honda civic 2005 LX automatic has its airbag light on for a couple of weeks. I first tried to reset it but was unsuccessful so I checked the battery and it was bad. So after I changed the battery the light was still on. I tried to reset it using the paper clip method but still same. I found out the code was 5-2 (internal failure of SRS unit). So I decided to change the SRS unit and changed it but the light never came off. I also tried changing the instrument panel just if that helps but still same. Then I found out that the alternator might cause srs code but when it was checked the alternator was fine (14.4 volt with ignition on). The code is 5-2. Anyone has any idea? The Honda dealers couldn't figure it out so they say they need to replace the entire front for $2000 + labor. That is expensive. If anyone has any idea help please.
Thanks.
eyobest is offline   Reply With Quote
Old 03-13-2014, 10:32 AM   #7
pentaccordtec
Thanks.
Do you still have this car/ problem? I've recently figured out a good way of getting down to the problem with the srs errors in these cars. It could take a while, but not nearly as crazy as replacing all of the things you decided to :/
pentaccordtec is offline   Reply With Quote
101, 2000, 2002, 2005, 45, 53, 61, 71, accord, airbag, code, codes, find, honda, srs
