Old 08-28-2011, 08:50 PM   #1
WingedMan
Default Methods to stop coolant leak from water pump weep hole
94 Honda Accord LX 5 speed manual 4 cylinder non VTEC has air conditioning
I recently did an oil and filter change using hydrallic jack to raise car under cross beam under the engine
The next day car driven developed a small drip leak of antifreeze from weep hole of water pump that occurs after car warmed up, and drips for a few minutes after car parked and turned off.
The water pump makes no noticable noise.
Has happened subsequently in same manner every time I drive the car, leak so small not had to add any coolant
Wondering if I jarred the car and water pump when raising or lowering the car resulting in breaking the seal in the water pump, or loosening the bolts on the water pump. I am not wanting to replace the water pump, so maybe I could just take off the top part of the timing belt cover and tighten down the bolts on the water pump and hopefully stop this leak. Am I making sense??????
I am trying to find an inexpensive fix for this problem
WingedMan is offline   Reply With Quote
Old 08-28-2011, 09:40 PM   #2
Nicefeet
Default Re: Methods to stop coolant leak from water pump weep hole
If it's leaking from the weep hole the internal seal has gone bad
Nicefeet is offline   Reply With Quote
Old 08-28-2011, 09:46 PM   #3
GhostAccord
1996 Honda Accord
GhostAccord's Avatar
There is no bolt that can be tightened to stop an internal seal leak in the water pump. Replacement is really the best option.
GhostAccord is offline   Reply With Quote
Old 08-29-2011, 06:00 AM   #4
Steve Z
Steve Zee
Exactly right. Time to change the pump out. While your at it, you might want to consider replacing the timing and balancer belts while you're in there. You can buy a complete set including both belts, tensioners, seals and water pump, gaskets etc.. for about $110. It's only going to get worse and spray coolant all over everything.
1995 Accord LX 2.2 auto
Steve Z is offline   Reply With Quote
Old 08-29-2011, 07:45 AM   #5
h0p3l355dork
110 dollars?! WHERE?! I've been checking all around for a timing belt kit and another HT member who works at a dealer quoted me 330 dollars for the whole kit. Granted my car is the 99 accord v6. Is it that big of a price difference?
h0p3l355dork is offline   Reply With Quote
Old 08-29-2011, 08:25 AM   #6
Rowdy Rod
I bought mine at Advance auto parts for a 4 cyl for 110.00. STOP trying to buy parts at dealers. Try Napa or Orielys.
Rowdy Rod is offline   Reply With Quote
Old 08-30-2011, 04:12 AM   #7
Steve Z
Steve Zee
Here's the kit foryour car (1999 Accord). I assumed it was a EX V6 but never the less $330 is more than double as you can see. It's the same as for my F22B2, $105
http://www.fcpimport.com/products/ho...hondaaccordkit
Old 09-27-2011, 12:43 PM   #8
WingedMan
I spoke to a long time Honda mechanic told me small leak from water pump weep hole is normal, not to worry about it since water pump not making any noise either.
Same info in Honda shop manual.
Therefore, since I do not drive this car far or often and my lack of money for this matter, I am delaying this repair.
Old 09-27-2011, 02:36 PM   #9
Steve Z
Steve Zee
Hmmmm, that just doesn't sound right to me. Whenever a water pump starts to weep its only going to get worse and eventually start spraying coolant all over the place and after that (and worse) overheat the motor. I'm sorry to be obtuse but it is NOT normal for your waterpump to leak coolant under any circumstances. The fact that the pump is not making noise is meaningless.
Old 09-27-2011, 03:00 PM   #10
GhostAccord
1996 Honda Accord
Actually small amount of coolant from the weep hole, even when brand new, is normal. However, a stream of coolant leaving a puddle is not considered normal weeping. That is excessive and will require replacement. If the op is vigilant and keeps an eye on his coolant temps and level he should be OK for a while.
Hopefully he practices due diligence and puts a collection bucket under his car when ever he parks. Because we all know how F#@king annoying those people are who knowingly leak coolant all over the place.
Old 09-27-2011, 03:10 PM   #11
redbull-1
redbull-1's Avatar
Heehee....
redbull-1 is offline   Reply With Quote
accord, coolant, cylinder, hole, honda, leak, leaking, magna, oil, prelude, pump, water, waterpump, weep, works
