Old 08-28-2011, 12:31 AM   #1
Jonathang
Default tail lights won't go off???
What in the world??? I can't get the tail lights to go off on my 95 accord. I've tried everything. Had to unhook the battery just so it won't go dead overnight.
Does anyone have ANY idea what the problem is? I looked all around the brake pedal and played with it and no luck.
Jonathang is offline   Reply With Quote
Old 08-28-2011, 12:37 AM   #2
lostforawhile
lostforawhile's Avatar
tim yoak
Send a message via AIM to lostforawhile Send a message via Yahoo to lostforawhile
Default Re: tail lights won't go off???
tail lights or brake lights? there is usually a plastic button which pushes on the brake pedal switch to make them go off, I'm not sure if your year has one, but many Hondas do, the button has a habit of falling out, get down there with a flashlight and look at the brake light switch to see if it's being pushed.
last I heard of Hazma/merkinator, he ran out of gas a block from his house, his 8 second auto civic sucked down an entire tank that fast, he was eaten by starving buzzards while waiting for help, his family is suing Honda for faulty gas gauges
lostforawhile is online now   Reply With Quote
Old 08-28-2011, 06:02 AM   #3
Jonathang
I didn't see anything that looked like a button or switch down there, but then again I'm not exactly sure what I'm supposed to be looking for. lol
I think it is the brake lights but I'm not positive. I just got the car so I'm not sure if the bottom is the brake lights or if the top is the brake lights.
Old 08-28-2011, 06:15 AM   #4
poorman212
Follow the brake pedal arm, along that there should be a switch-you can push on the pedal and see the "plunger" of the switch. On the pedal "arm" there should be a "plug/button" that makes the switch close....if that is gone, there is just a hole in the arm with nothing to close the switch.
46505-SA5-000 -should be the part number at the dealer.
66 Chevelle...89 LX auto...89 LXI 5 Speed
...95 EX auto...07 Pilot 2wd
87 LX 5 Spd (sold )...88 LXI Auto (soon to be sold)
poorman212 is offline   Reply With Quote
Old 08-29-2011, 09:37 PM   #5
Jonathang
Thanks! That was what was wrong. The plug shattered. I'm not sure what to replace it with. Seems like it would be difficult to fit something in there without taking the brake pedal off.
Old 08-30-2011, 03:03 PM   #6
Lost Again
Get the plug from the dealer looks like poorman posted the part number, push on the pedal with one hand use the other to get the plug in the hole. A good thumb push and you are there.
My child arrived just the other day; he came to the world in the usual way
I can explian it to you, I CANNOT understand it for you
Lost Again is offline   Reply With Quote
Old 08-30-2011, 09:35 PM   #7
victorb
I'm driving a 94 Honda Accord. You guys saved me some trouble. My friend also thought it was a fuse, but upon pulling the fuse, for some reason it wouldn't put the car into gear. I looked at the fuse and realized that the fuse was good. Upon googling I found answers to my questions from this forum. I think I've fixed my problem as I've tested it out and it works.
What I did was ended up using two dimes stuck together with some clear sticky, gummy glue, with some gummy glue stuck the side of the dime that will rest on the black hole as described in this topic's tread. I had to push the pedal pretty hard to get it to have enough space for me to put the dimes in. I tested it out and it works fine. I even tested it to make sure the brake and rear light still works and that's fine as well.
I've upload a video to Youtube showing what I've done. It's kind of fast and it maybe jerky, so I am sorry in advice. It's just a close up of what I did.
I hope this helps.
Here's the link to the video, http://bit.ly/brakelightswitchfix
victorb is offline   Reply With Quote
Old 07-25-2012, 03:18 AM   #8
Jreks
I hope this helps.
You sir, are the man.
Jreks is offline   Reply With Quote
Old 07-25-2012, 06:18 AM   #9
tommi
tommi's Avatar
SinisterBredCB
Send a message via AIM to tommi
just get creative and u can fix this with 2 pennies glued together and put in place of that lil plug. vs spending 5 bucks on a lil nylon plug that will just end up shattering again sometime another. or go to the yard and grab a bunch
--Tommi--
tommi is offline   Reply With Quote
Old 07-25-2012, 10:38 PM   #10
lostforawhile
tim yoak
round head stove bolt, the round head of the bolt pushes on the switch, secure with a nut on the opposite side, cheap quick and permanent fix
Old 07-25-2012, 10:45 PM   #11
361 accord
2000 Honda Accord
361 accord's Avatar
facebook.com/361accord epictuning
Send a message via AIM to 361 accord
mine is the most ghetto and therefore badass
2 quarters taped to the lever
CG squad member #001
Originally Posted by cetcivic View Post
I need my injector serviced
Only female need apply
361 accord is offline   Reply With Quote
Old 08-01-2012, 03:56 PM   #12
ZypKode
Send a message via Skype™ to ZypKode
The 2 Coins thing work.Better than buying a New Battery.My Rear Lights on my 96 Acura TL 2.5 now goes out when I get out of the Car. Thanks to whoever came up with this suggestion.
ZypKode is offline   Reply With Quote
46505sa5000, 94, battery, brake, car, civic, honda, lights, loghts, part, picture, shut, switch, tail, turn, wont
